1995 S320 W140 mirror part - Mercedes-Benz Forum
post #1 of 17 (permalink) Old 09-04-2011, 05:36 PM Thread Starter
Date registered: Sep 2011
1995 S320 W140 mirror part ***PHOTO ADDED***
Hi,
first post. Located in New Zealand.
My Father has recently purchased a 1995 W140 S320.
The right hand wing mirror was vibrating and close inspection revealed that one of the metal cast parts within the casing had broken and been glued back together.
We have managed to get the mirror apart and remove the offending part.
It would appear to be a cast metal ring that has two steel pins pressed into it and is (was) attached to the arm that parks the mirror and the pivot for the mirror glass adjustment. It also has one end of the sleeved spring connect to it. It has been broken in two places.
The only number I can find on it is 222 310.
Can any one tell me if this part is available separately & from where.
Dealers seem to want to sell the full mirror unit at a significant cost.
Thanks,
Myles
928Myles is offline
post #2 of 17 (permalink) Old 09-04-2011, 05:42 PM
~BANNED~
Date registered: Jan 2011
Vehicle: 2008 C200K (W204) & 1998 SL500 (R129) Imperial Red
Quoted: 25 Post(s)
mirrors are usually sold as a whole unit.. even at the breakers..
It is very difficult to source that part, I am also looking for that exact one lol
MafiaDON is offline
post #3 of 17 (permalink) Old 09-04-2011, 05:53 PM
Mercedes mechanic's Avatar
Date registered: Mar 2011
Vehicle: Timeship, see you yesterday, but you already knew that.
Where?
In the area's marked?
Top five reasons I posted in your topic:
1. You're talking about god, there has never been any god of any kind. EVER!
2. I just have a general dislike of you.
3. I am trying to tell you how to fix your Mercedes and you are not listening.
4. I'm flirting with Jody.
5. You're just to dumb to own a Mercedes, and should go buy a Honda.
Mercedes mechanic is offline
post #4 of 17 (permalink) Old 09-04-2011, 06:21 PM Thread Starter
The metal ring that attached through the two shiny pins shown in your photographs is broken where your bottom red arrow indicates and the diagonally opposite corner to this position.
Thanks for the responses.
Myles
928Myles is offline
post #5 of 17 (permalink) Old 09-04-2011, 06:30 PM
Top piece.
# 140 811 02 41 or 140 811 04 41
Bottom.
# 140 811 01 35
post #6 of 17 (permalink) Old 09-04-2011, 07:30 PM Thread Starter
Thanks for the response.
Just to be sure, the broken piece does not appear in the above photo's but is a 'off square' ring approx 10mm thick & 60mm by 100mm with a hook midway along the wider end on the outside of the ring and a pivot almost opposite on the inside of the ring.
The long pin (hinge) runs from the hook end of the ring to the beefier side with the numbers on it.
The short pin runs along about 60% of the lenght opposite the long pin.
Hope this helps, without photo capability at the moment.
Thanks,
Myles
928Myles is offline
post #7 of 17 (permalink) Old 09-05-2011, 03:04 AM Thread Starter
I have managed to upload a picture of the broken part. Hope it helps confirm the part needed.
Myles
928Myles is offline
post #8 of 17 (permalink) Old 11-04-2011, 02:14 PM Thread Starter
No luck with relacement - help needed for parts source
Hi,
I have searched NZ for a replacement mirror - all to no avail. Can anyone on this forum point me to a breaker who would have the right mirror. A photo of the cover is below. Everyone I could find in NZ has a different shape and wireing.
The cover has a sort of rib or step around it (horizontally).
Thanks
928Myles is offline
post #9 of 17 (permalink) Old 11-04-2011, 02:24 PM
Do you still have your original cover?
post #10 of 17 (permalink) Old 11-04-2011, 04:33 PM Thread Starter
Still have everything in working order except the broken ring shown in post 7. The ideal would be to get a replacement ring from a mirror that has some other part broken. (Especially true when sourcing from the states as postage can be quite steep).
I suspect that the other side has suffered a similar fate so would like to source one for the other side as well.
Cheers, Myles
928Myles is offline
1995 S320 Dimming rearview mirror salernoc W140 S-Class 7 05-07-2015 07:32 AM
1995 S320 SWB W140 Driver Door Removal gunner58 General Mercedes-Benz 2 08-18-2011 08:07 PM
Spark plugs for W140 S320 1995 apollonios W140 S-Class 2 07-24-2009 10:32 AM
1995 S320 w140 HELP!!!!!!! ilovemyBenz W140 S-Class 6 03-12-2009 11:13 AM
Wood wheel for 1995 W140 S320 lilbee45 W140 S-Class 12 07-16-2006 09:23 AM
