Transmission - Conductor Plate replacement - Page 2 - Mercedes-Benz Forum
post #11 of 36 (permalink) Old 07-27-2011, 06:59 PM
iss
iss's Avatar
Date registered: Aug 2009
Vehicle: 1998 Mercedes-Benz S500
Quoted: 12 Post(s)
Originally Posted by michobebe View Post
Thanks iss !!! Wasn't expecting too see such wonderful artistic skills!! Thanks a lot!
So the speed sensors are on it, othewise the solenoid is the only thing I need to install on it? the switch and oil temperature sensors aren't to be touched, right ?
How advanced skills does moving the solenoid need?
look at my pics. and fallow step by step as i numbered the pics. i also put few pics. how to drain the torque converter( you need this if you wonna change it tranny oil). And now is important: remove the plastic cups from solenoids, remove bolts and holders, careful by hand remove solenoids and only then u can remove conductor plate of the valve body. put new plate no the body (careful) , solenoids ,holders,screw ,cups and.... you know any questions-welcome!!! Mr. B
ID:	388671   Click image for larger version
ID:	388672   Click image for larger version
ID:	388673   Click image for larger version
ID:	388674   Click image for larger version
Oh MAN!!! Every second i am older and older!
iss is offline
post #12 of 36 (permalink) Old 07-27-2011, 07:01 PM
iss
iss's Avatar
Quoted: 12 Post(s)
more
ID:	388676   Click image for larger version
ID:	388677   Click image for larger version
ID:	388678   Click image for larger version
ID:	388679   Click image for larger version
Fast960 likes this.
iss is offline
post #13 of 36 (permalink) Old 07-27-2011, 07:05 PM
iss
iss's Avatar
Quoted: 12 Post(s)
and more
ID:	388686   Click image for larger version
ID:	388687   Click image for larger version
ID:	388688   Click image for larger version
ID:	388689   Click image for larger version
iss is offline
post #14 of 36 (permalink) Old 07-27-2011, 07:06 PM
iss
iss's Avatar
Quoted: 12 Post(s)
one more
iss is offline
post #15 of 36 (permalink) Old 07-27-2011, 07:17 PM Thread Starter
michobebe's Avatar
Date registered: Jan 2011
Vehicle: S500v 4Matic 2003 - S600 V12 1998 - E320 4Matic 1999
W O W
Hats Off
Let me digest these precious pictures and information!
Thank you!
michobebe is offline
post #16 of 36 (permalink) Old 07-27-2011, 07:38 PM
iss
iss's Avatar
Quoted: 12 Post(s)
no problem!!! i learned all this by my self 2 yers ago and it took me to fix my LIMP MODE a 6 (six) month!!!!!!!! Thanks W140 forum for many help. Now 1.6 years im driving with not a single problem. (so far) if you wonet you can check all my post on the W140 forum-may help.!!!!!
iss is offline
post #17 of 36 (permalink) Old 09-01-2011, 07:45 PM
Date registered: Apr 2009
Vehicle: 2001 Mercedes-Benz CLK 320
Ive got the same issue ..... today i changed the adapter plug unfortunately I dont have a carsoft to reset....i am weary of taking it to a dealer to have it reset only for the same problem to occur or should I just change everything like u did here and then get it reset.
vabeanz is offline
post #18 of 36 (permalink) Old 09-01-2011, 08:54 PM
~BANNED~
Vehicle: 2008 C200K (W204) & 1998 SL500 (R129) Imperial Red
Quoted: 25 Post(s)
Would this information help fix a "no reverse gear" issue?
The Mercedes Transmission is something I am VERY scared of lol
MafiaDON is offline
post #19 of 36 (permalink) Old 09-01-2011, 10:12 PM
unbugai's Avatar
Date registered: Aug 2005
Vehicle: 1996 Mercedes-Benz S500
yeah im on the same boat ive started getting the po743-torque converter clutch solenoid circuit.....
would you guys recommend i change the solenoid or just go with a new conductor plate and get all 6 solenoids i believe itll all run me around 3 to 4 hundred???
or what else could be throwing this code???
unbugai is offline
post #20 of 36 (permalink) Old 09-01-2011, 10:38 PM
nhzruthless818's Avatar
Date registered: Jun 2008
Vehicle: 1997 S500V
Quoted: 50 Post(s)
do the speed sensors come with the conductor plate? also it is perfect time to change up some of the seals while you take the valve body out i didn't do mine and no its poring
to get the valve body recondition was $1000 and to get a full tranny and torque converter rebuild is $2000 (including valve repairs $2k for me at my cousins shop )
nhzruthless818 is offline
  • Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
    Replaced the transmission conductor plate gurunutkins W210 E-Class 19 07-20-2013 01:57 PM
    Transmission Problem - Conductor plate NOLA911 General Mercedes-Benz 14 09-17-2011 10:46 PM
    98 E300 TD transmission service - conductor plate ghardy W210 E-Class 4 09-09-2010 09:58 AM
    How much for a Transmission Conductor Plate gusdogg W203 C-Class 4 04-10-2008 07:47 AM
    Transmission Problem, conductor plate? BNZLVR C208/A208 CLK-Class 3 10-31-2007 05:25 PM
