1997 S320 Location of HVAC Fan Blower Motor - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 05-31-2011, 07:48 AM Thread Starter
Date registered: Jun 2010
Vehicle: 2004 Mercedes Benz CL500 and 1997 Mercedez Benz S320
Send a message via Yahoo to smartfinds Send a message via Skype™ to smartfinds
Hello,
Does anyone know how to get to the hvac fan blower motor in a 1997 S320?
Not sure how to get to it and where it is located. Any feedback is greatly appreciated.
Thanks.
Melih ("may-lee") Oztalay, CEO
SmartFinds Internet Marketing
Tel: (248) 568-2241
http://www.smartfindsmarketing.com
http://www.smartfindsgeographicmarketing.com
smartfinds is offline
post #2 of 11 (permalink) Old 05-31-2011, 07:59 AM
Vehicle: 1995 S500 coupe, 1990 Mazda Miata
Quoted: 14 Post(s)
Pop the hood, and just forward of the cowl (where the wipers are) you'll see a large plastic cover that extends from the passenger side almost to the driver's side. There are several large phillips head screws holding it down. The blower motor is on the passenger side beneath the cabin filter which is under the large cover.
95Scoupe is offline
post #3 of 11 (permalink) Old 05-31-2011, 11:45 AM
Date registered: Mar 2004
Vehicle: 1997 S600 (sold)
Quoted: 14 Post(s)
Are you having problems with your blower?
Brett
Brett San Diego is offline
post #4 of 11 (permalink) Old 05-31-2011, 04:28 PM Thread Starter
Hi 95Coupe,
Thanks for your feedback, that was right on target. I have access to the blower now. After this it is a matter of figuring out what is wrong. Not sure if it is the actual blower or maybe one of the other electronic parts (eg resistor or speed regulator).
As I get any updates worth sharing I will pass it along.
Tel: (248) 568-2241
post #5 of 11 (permalink) Old 05-31-2011, 05:11 PM
Quoted: 14 Post(s)
You might try giving the impellar a little push start when it's supposed to be running. Mine came on; I bit the bullet and bought a new motor. The regulator bolts right on to the motor; the leads connect directly to the motor, and is suspect as well.
95Scoupe is offline
post #6 of 11 (permalink) Old 05-31-2011, 05:26 PM Thread Starter
Hi 95Coupe,
I just ran some tests and few things came up.
The blower is working confirmed after removing he cover and the filter
What was interesting is that the air coming inside the car was working slightly better, which then raised the question if the filter (or other filters) may be hampering air to flow through the blower.
I vacuumed the filter on both sides, put it all back together and started the car. The air was running better already, but unclear if at the level it should be.
1. Since I bought this car used I don't know how hard the air is suppose to blow even at a "max" setting. My perspective is that it is not blowing as hard has it could. Certainly hard to ear the air blowing. Any thoughts on this?
2. Not sure how to test if the regulator is hindering the blower from turning faster, which would be related to the above question?
3. Any other filters that I should now about that may be hindering air flow?
Thanks for any thoughts on the above.
Tel: (248) 568-2241
post #7 of 11 (permalink) Old 05-31-2011, 08:32 PM
Date registered: Apr 2010
Vehicle: 1998 S600 LWB 2011 GLK 350 4matic 2013 Sprinter 2500
To complete your visual fan inspection, it shouildn't stop to abruptly when de-energized. At high speed, they move an impressive amount of air. Could be vacuum damper problems, but don't forget to check the filter above the passenger footwell.
napaAl is offline
post #8 of 11 (permalink) Old 05-31-2011, 10:00 PM
Quoted: 14 Post(s)
Does it stay running at low speed even when you turn it up to max? Max should deliver very high flow. That is blower regulator failure. Very common.
Just replace the filter. It's cheap.
Brett
post #9 of 11 (permalink) Old 06-01-2011, 08:25 AM
Quoted: 14 Post(s)
I don't have my CD service manual at work, but there might be a procedure for checking motor RPM per voltage input. Quite right that it might be the controller. I can check tonight. +1 on the air output being very good when everything is correct.
95Scoupe is offline
post #10 of 11 (permalink) Old 06-02-2011, 12:38 PM
Date registered: May 2011
I had to change my blower regulator on both my parents' car and mine. It's veeeery common apparently.
If you had the fan set to max, you wouldn't want to be anywhere near the fan because it blows so hard. Imagine sitting in-front of a real fan.
Darius_ is offline
    94 S350D HVAC Blower motor problems. csd6612 W140 S-Class 4 07-30-2008 09:07 AM
    HVAC/CCU Troubles? Don't forget about the blower motor... trinary W123 E,CE,D,CD,TD,TE Class 3 03-26-2008 07:25 PM
    Location Of The Blower Motor, 86/ 560SEC Blacksea W126 S,SE,SEC,SEL,SD,SDL Class 2 07-14-2006 10:04 AM
    Location of the blower motor. mykg4orce W201 190-Class 6 09-12-2004 07:17 AM
    W140 blower motor location? nav_bhandher W140 S-Class 5 07-26-2004 11:18 PM
