1995 S600 w140 dead battery - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-16-2011, 01:27 PM Thread Starter
Date registered: Feb 2009
Dead battery in boot of s600 v12.
To get in boot to replace or remove to charge battery you will need spare charged battery and jump leads or jump pack.
You need a piece of metal same thickness and width/shape of fuse but 25mm longer making up.
Unlock door with key.
Open bonnet.
Remove fusebox cover.
Remove fuse 17.
Put in made fuse.
Connect live jump lead to made fuse and earth other cable on body somewhere.
Press key fob to unlock central locking.
Open boot.
remove jump leads.
Remove made fuse and replace original fuse.
Charge or replace battery from boot.
pjm1000 is offline
post #2 of 4 (permalink) Old 05-16-2011, 01:58 PM
~BANNED~
Date registered: Jan 2011
Vehicle: 2008 C200K (W204) & 1998 SL500 (R129) Imperial Red
Quoted: 25 Post(s)
Interesting trick..
But doesn't the boot just open mechanically with the key?
My boot does, no need for all this trouble. Iv take my PSE pump out completely, and manage to lock and unlock the boot normally..
What would be the point of this?
MafiaDON is offline
post #3 of 4 (permalink) Old 05-16-2011, 04:59 PM
chuckindetroit's Avatar
Date registered: Jun 2003
Vehicle: 1986 560SEL, 1986 560SEL, 1992 500SEL, 1999 S500
Also extremely dangerous, connecting a basically unlimited source of current to your electrical system without any overcurent protection. Can you say "Burnt wiring harness"?
chuckindetroit is offline
post #4 of 4 (permalink) Old 05-16-2011, 05:13 PM
jcvollmuth's Avatar
Date registered: Dec 2010
Vehicle: 1995 s500, 2004 s500, 1991 190e
http://www.benzworld.org/forums/w140...ss-urgent.html
just a related thread, could help some people out.
jcvollmuth is offline
    1995 E320 went in limp home mode with dead battery douglasfelliott General Mercedes-Benz 0 11-16-2010 05:24 PM
    About to buy a W140 1995 S600 coupe SteinwaySteve W140 S-Class 10 10-06-2010 07:59 PM
    1995 S600 Limp Mode After Battery Reset npatel219 W140 S-Class 2 06-04-2010 08:12 AM
    W140.076/ 1995 S600 Combination Relay Help techywizz W140 S-Class 0 01-25-2010 08:50 AM
    1995 S600 Read the link via W140 section lesrrt For Sale/Wanted/Trade/Giveaway 0 10-18-2007 06:29 AM
