1997 S320 Trunk Lid Won't Close - Mercedes-Benz Forum
post #1 of 17 (permalink) Old 12-26-2010, 09:31 AM Thread Starter
Date registered: Jun 2010
Vehicle: 2004 Mercedes Benz CL500 and 1997 Mercedez Benz S320
Send a message via Yahoo to smartfinds Send a message via Skype™ to smartfinds
Hi,
I have read through a variety of posts and answers about trunk lids and most of them are focused on the automatic pump system that closes the doors and trunk lid.
I have verified that this automatic pump system works. I believe the problem is potentially one of two issues and I cannot seem to be able to solve either.
The lid closes far enough but the latch then doesn't finish closing. The issue could be:
1. The eye of latch is out of position thereby the angle coming into the latch is off to actuate the latch.
2. The actual lock is in a locked (maybe like a anti-theft position) position not allowing the latch to close.
I have not really found any writings of anyone having problems like this or closing the the lid. Most people seem to have problems opening or having issues with the pump system.
Anyone have any further thoughts on this? Thanks for any help.
Melih ("may-lee") Oztalay, CEO
SmartFinds Internet Marketing
Tel: (248) 568-2241
http://www.smartfindsmarketing.com
http://www.smartfindsgeographicmarketing.com
smartfinds is offline
post #2 of 17 (permalink) Old 12-26-2010, 11:19 AM
z168's Avatar
Date registered: Oct 2005
Vehicle: M62
Quoted: 89 Post(s)
you can confirm this by pressing the trunk open button with the trunk lid open. Are there scenarios where you can close the trunk by slamming it shut?
Check here. This might help
Deutsche Tourenwagen Meisterschaft
z168 is offline
post #3 of 17 (permalink) Old 12-26-2010, 11:32 AM
jhodg5ck's Avatar
Date registered: Sep 2002
Vehicle: Depends on the day!
Quoted: 16 Post(s)
Send a message via AIM to jhodg5ck
I've found the mechanism in the chassis likes to loosen up with age, I'd check that alignment and make sure the two bolts are tight.
How have you verified that the trunk closing actuator is getting vacuum?
Jonathan
Blue Ridge Mercedes/AMG East
Jonathan Hodgman
http://www.blueridgemb.com/
Enthusiast Service, Restoration & Tuning.
Authorized RENNtech Dealer & Installer
Follow Us on Facebook!
Located in the Atlanta area
87 Hammer Wagon 6.0L 32V
87 Hammer 6.0L 32V
86 560SEL AMG 6.0 32V
etc....
Mercedes Repair Atlanta
jhodg5ck is offline
post #4 of 17 (permalink) Old 12-26-2010, 02:46 PM
Date registered: Mar 2004
Vehicle: 1997 S600 (sold)
Quoted: 14 Post(s)
I don't understand what you are saying. You'll have to describe (for me, anyway) in gory detail exactly what happens or doesn't happen when you try to close the trunk, starting with what happens when you open the trunk prior to trying to close it again.
You can see if the striker eye hits and rotates the catch mechanism in the lower latch mechanism.
Brett
Brett San Diego is offline
post #5 of 17 (permalink) Old 12-28-2010, 09:18 AM
jcvollmuth's Avatar
Date registered: Dec 2010
Vehicle: 1995 s500, 2004 s500, 1991 190e
happened with my 500
this happened with my 95 s500 two days ago, it wouldnt suck back in but the pump worked just fine, i just pushed the latch back down when the trunk was open and then pressed the open button again, sut it and it worked fine, havent had a problem yet, i also tightened up the latch...
jcvollmuth is offline
post #6 of 17 (permalink) Old 01-04-2011, 05:45 PM Thread Starter
Hello,
I wanted to circle back around to everyone about this problem and let you know the resolution.
After several more attempts on my own and since there was other work to be done on the car that required professional service, I included this as part of the service.
What they found was the there was an alignment problem, adjusted the trunk latch and catch positioning, replaced missing sill clips, and lubed the mechanisms.
Based on the work that was done, I certainly feel this was outside of my personal capabilities, but perhaps this will help someone else in the future.
Thanks for the comments.
Tel: (248) 568-2241
post #7 of 17 (permalink) Old 01-05-2011, 11:21 PM
S666's Avatar
Vehicle: 1997 S666-The Beast
S666 is offline
post #8 of 17 (permalink) Old 01-06-2011, 10:46 AM
97S320Jim's Avatar
Date registered: Mar 2010
Vehicle: 1997 Mercedes Benz S320 SWB
Quoted: 2 Post(s)
Originally Posted by S666 View Post
I find a damn good slam usually does the trick....
Great, now that you're in my trunk, can you tighten that power antenna bolt, again?
Thanks. And, you know how the emergency trunk lock and latch sequence works....
JAC,
SLC, Utah USA
97 S320, 88,300 miles
97S320Jim is offline
post #9 of 17 (permalink) Old 05-26-2012, 10:39 PM
Date registered: May 2012
1997 Mercedes S320 Trunk won't engage in latch
First time to post. Hope I am in the right spot.
My daughter is on the road in her Mercedes S320 1997. Of course it is a holiday weekend. Hoping for a quick fix, to get her on the road again.
The cargo net got caught, in the latch/lock, when she went to close the trunk. (not the first time it has gotten in the way ) She pulled it out, the trunk would not stay shut. Not sure about interior indicator lights being on or off.?
Vacuum pump is working fine. Trunk "latch/lock" is in an open position and will not lock or close over the top piece to keep the trunk closed.
Those two pieces are movable. Like pinchers. They can be pinched in and out but will not grab the top piece, to hold the trunk shut.
Can you really "slam" the trunk? Will it damage the vacuum? Do you wait until it is close to being shut?
Can the latch break? Someone is wanting to take a panel off and fix something that is failing to "engage" the mechanism. A friend. Not our mechanic and I am nervous.
Sherri
sherrimercedesb is offline
post #10 of 17 (permalink) Old 06-06-2012, 11:30 AM
Date registered: Jun 2012
Vehicle: 1997 MB s500
1997 s500 trunk wont open or close
hi,
I have a 1997 s500 and just today started having an issue with the trunk,
i closed the trunk and it did not fully close all the way it stayed open about an inch or so, and wont close, i tried to open it and it wont open either i tried the with the key and with the button inside the car, the handle is sticking out and is not retracting - so now im stuck driving around with my trunck open about an inch, i checked the fuses everything seem OK and the pump sound like its working. can anyone help me with this.
anyone have any similar issues.
i want to try to figure it out rather than having to take it to a dealer.
MAXIMUMmotorCAR is offline
Problems with Trunk Lid Auto-close AND Lock beaverlake C219 CLS-Class 0 01-04-2010 09:45 PM
Quirky Close Assist (1997 S320) VoD General Mercedes-Benz 0 06-15-2009 08:07 AM
Boot (trunk) lid very stiff to close stajon W220 S-Class 4 03-19-2008 11:40 AM
bogus trunk lid? on nice looking s320 waltbald W140 S-Class 5 07-15-2007 01:46 AM
1997 S420 trunk lid wont open Twizted W140 S-Class 0 06-05-2007 02:11 PM
