radiator flush? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 12-24-2010, 04:36 PM Thread Starter
Hypnotismo's Avatar
Date registered: Feb 2010
Vehicle: Sold, in the market.
radiator flush?
Hello 140 section, i need to flush the radiator in my sisters s320 1995. Knowing mercedes, there is probably some complication with this. After searching, I didn't find much so... what should I look out for? How much coolant/antifreeze is needed exactly? What coolant/antifreeze is needed exactly (yes there are a few different kinds... i think). Any help is greatly appreciated since oilstop wants like $50 bucks to do it... and im cheap.
1994 SL500 R129 (Silver/Blue Leather) _I am really the only one that drives it anymore. --FOR SALE!
2001 E320 Estate (Silver/Ash Leather) _Mother's
1988 260E Custom Sound System, tint, and cheapy paint job, so many memories! - SOLD
1986 420SEL - RIP 1/29/11
http://www.youtube.com/watch?v=xViYiPH9R9Y
http://www.youtube.com/watch?v=cGgNhzl4fr4
Hypnotismo is offline
post #2 of 4 (permalink) Old 12-24-2010, 04:48 PM
Date registered: Sep 2008
Vehicle: 1999 S500 W220
There is only one coolant for all mercedes, buy it from Merc dealer or from online sales who stock the mercedes product (around $23 for 4 ltr plus delivery). Normal mix is 50/50 coolant to distilled water and this should last for 3 years for temps above -30 deg c. I think for the S320 there is a valve at bottom of radiator to drain otherwise disconnect bottom hose. A good shop will do a pressure test and a back flush to clean any scale. If you have been using the MB coolant there should not be any scale. The capacity is usually around 11ltr and around 6 ltr for exchange. The price you have been quoted seems cheap and I suspect it is a quick drain and refill with non genuine coolant that will need to replaced in 1 to 2 years. If you want accurate info on DIY post vin and I can provide data for your car from WIS system.
peterstar is offline
post #3 of 4 (permalink) Old 12-25-2010, 11:17 AM
aam
Greek God of the R129
aam's Avatar
Date registered: Dec 2004
Vehicle: SL500-500SEL-190E
Quoted: 171 Post(s)
In USA only MB or Zerex G05 nothing else is approved.
You will need about one gallon and a half, mixed with water 50/50
After draining flushing etc.
I drain fill with water, drive.. after a few days I drain again refill it.
Put the antifreeze first in, then add the water.
That is if where you are the temperature is not freezing.
Regards,
aam.
aam is offline
post #4 of 4 (permalink) Old 12-26-2010, 01:14 PM
z168's Avatar
Date registered: Oct 2005
Vehicle: M62
Quoted: 82 Post(s)
here you go
its $20-ish from the stealer
Deutsche Tourenwagen Meisterschaft
z168 is offline
    Radiator flush ? 300sd W126 S,SE,SEC,SEL,SD,SDL Class 5 08-15-2007 01:25 PM
    Radiator Flush nobby R/C107 SL/SLC Class 10 06-25-2007 11:42 PM
    Does anyone flush their radiator? B-McD R/C107 SL/SLC Class 7 04-17-2007 06:14 AM
    Radiator flush Kingorcus W126 S,SE,SEC,SEL,SD,SDL Class 6 07-05-2005 06:16 AM
    Radiator Flush Aniversary SL R129 SL-Class 1 07-17-2004 08:49 PM
