OBDII code P1519 RH Adjustable Camshaft Timing Solenoid - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 07-25-2010, 09:14 PM Thread Starter
Date registered: Dec 2009
Vehicle: 1996 W140 S500 Coupe
Question OBDII code P1519 RH Adjustable Camshaft Timing Solenoid
Hello all,
I am hoping that someone out here has a resolution for the problem that I am having. I am having the code P1519 pull up on my 96 S500 Coupe. I want to replace the solenoid, but I feel like a total idiot and have absolutely no idea where the solenoid is. If anybody has a pic of the location, part number, or any advice that would help me out with this would be very appreciated. I have cleared the code once already, but it came back. Thanks in advance for your help!
stratt95 is offline
post #2 of 5 (permalink) Old 07-26-2010, 09:51 AM
jhodg5ck's Avatar
Date registered: Sep 2002
Vehicle: Depends on the day!
Quoted: 16 Post(s)
Send a message via AIM to jhodg5ck
what's the build date on your car?
Check your harness, may not be the CS.
BTW, it's on the front of your engine, in front of the cam.. Small/round assembly w/ a two pole connection.
You'll also need a container of special goo to seal it.
Jonathan
Blue Ridge Mercedes/AMG East
Jonathan Hodgman
http://www.blueridgemb.com/
Enthusiast Service, Restoration & Tuning.
Authorized RENNtech Dealer & Installer
Follow Us on Facebook!
Located in the Atlanta area
87 Hammer Wagon 6.0L 32V
87 Hammer 6.0L 32V
86 560SEL AMG 6.0 32V
etc....
Mercedes Repair Atlanta
jhodg5ck is offline
post #3 of 5 (permalink) Old 07-30-2010, 12:38 AM Thread Starter
The build date was 08/95. I figured out the problem though. After taking the solenoid off, and reading back on the service history. An actual MB mechanic didn't put the bolt back into the armature so it was loose and ruined the solenoid. Luckily the cam was unscathed. Guess it could have been worse. Ordered the parts and she will be back on the road in a few days. Thanks for the advice. It is always appreciated.
stratt95 is offline
post #4 of 5 (permalink) Old 06-10-2011, 03:56 PM
donald1111's Avatar
Date registered: Jan 2007
Vehicle: 2010 E350
Hi
I am having the same problem that you had a while ago. You asked for the location of the 1519 solenoid, but I did not see where it was located. I read that you corrected it.
Please explain where I can find it.
Thanks,
Donald
Hello all,
donald1111 is offline
post #5 of 5 (permalink) Old 06-10-2011, 04:26 PM Thread Starter
Hey Donald,
You can find the solenoid on the front of the head. If it is still an OEM part, it looks like the bottom of a black cup. It will be a gold color if it's been replaced in the past. It will have one plug in it with two wires coming out of it. You have to buy Mercedes black sealant when reinstalling the new one. Hope this helps.
stratt95 is offline
Trouble Code P1519 - Adjustable Camshaft Timing Solenoid Dimitris R129 SL-Class 31 10-04-2013 08:38 AM
Engine code 1341 camshaft position solenoid / sensor fountainpenracing W202 C-Class 6 05-13-2011 07:59 PM
Obdii P0410, P0105, P1519 toddau R170 SLK-Class 5 02-28-2007 03:15 PM
1993 Benz 300SE Camshaft Timing Adjust Solenoid Sensor dbmoylan W140 S-Class 3 01-29-2007 01:11 PM
camshaft timing solenoid? jjcarr W202 C-Class 2 07-16-2006 05:34 PM
