Need help removing CD changer in trunk - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 07-01-2010, 10:46 AM Thread Starter
Date registered: Oct 2008
Vehicle: 1999 S420, 2005 ML500
I upgraded my headunit so the cd changer is not in use. How do I remove it? I have fumbled all around that carpeted box in the trunk and cannot figure it out. Simple steps for dummies appreciated, thanks.
m_tyson is offline
post #2 of 14 (permalink) Old 07-01-2010, 05:18 PM
Date registered: May 2010
Vehicle: 1997 s600
You can pull up trunk carpet and there is a gray insulation mat that runs up against the cd changer. There are 2 flaps cut into the material.Pull up the flaps and there are 2 screws that need to be removed. You can then pull up the changer and unplug the connector and remove it. At least that is the procedure on my 97, let me know how you make out.
limelight is offline
post #3 of 14 (permalink) Old 07-01-2010, 08:47 PM
Date registered: Apr 2010
Vehicle: 1998 S600 LWB 2011 GLK 350 4matic 2013 Sprinter 2500
You could also take a ride up to Napa and have a low tech mechanic like me remove it for immediate re-use.
napaAl is offline
post #4 of 14 (permalink) Old 07-02-2010, 01:00 AM
bayhas's Avatar
Date registered: Oct 2005
Vehicle: SL55, 300SE, GL450, Daytona 955i
Quoted: 303 Post(s)
Send a message via MSN to bayhas Send a message via Yahoo to bayhas
wanna sell the bracket?
Garage:
Mercedes-Benz, W140 S Class S320 (AKA 300SE)
Mercedes-Benz, R230 SL Class SL55 (///AMG)
Mercedes-Benz, X164 GL CLass GL450
Triumph Daytona 955i
Former Mercs:
R129 SL Class SL500 (passed on) - W163 M Class ML430 Designo (for sale) - W140 S Class 500SEL(sold) - W140 S Class S320(sold) - W140 S Class S500(sold) - W140 S Class 500SEL(sold) - W201 190E 2.3(sold)
bayhas is offline
post #5 of 14 (permalink) Old 07-02-2010, 11:35 AM Thread Starter
Thanks for the responses.
Napa, you are welcome to the changer. Bayhas, you can have the bracket, assuming I figure out what it is and I don't break it. If anyone wants the Becker headunit, let me know. It had a buggy fiber optic volume control. I would just want you guys to cover my shipping and paypal fees.
Thanks for the instructions, limelight. I pulled up the gray flaps but don't see any screws. There are 2 hex-shaped openings. The carpeted box is already loose; I can lift it about an inch, and slide it back a bit, but it won't come out. Do I have to remove the side trunk covering (that hides the amp) in order to get the box out? Pictures below. Still stumped...
Thanks for the help.
ID:	317208   Click image for larger version
m_tyson is offline
post #6 of 14 (permalink) Old 07-02-2010, 12:21 PM
bayhas's Avatar
Quoted: 303 Post(s)
I ll take a picture of mine later tonight...
Garage:
Former Mercs:
bayhas is offline
post #7 of 14 (permalink) Old 07-02-2010, 12:57 PM
Vehicle: 1997 s600
Your changer style is definitely different than mine.Those two holes under the flaps are for the inserts for the screws that are for my style mounting bracket.
Looks like you have to remove the gray carpet box around it to see the mounting screws? Dunno. Perhaps a small mirror under there would be helpful.
post #8 of 14 (permalink) Old 07-02-2010, 02:57 PM
Date registered: Jun 2010
Vehicle: 2001 SL500
Here is the STAR bulletin for the MY 2000 Telephone/CD Changer Installation. This maybe helpful in figuring out how yours is mounted. It looks like the mounting screws for the bracket are very close to the changer so you'll have to take the wheel well panel out. Sorry but I wasn't able to locate the MY 1999 documentation.
Hope this is of some help.
Ken
kmitchell is offline
post #9 of 14 (permalink) Old 07-08-2010, 12:17 PM Thread Starter
Got it out!
m_tyson is offline
post #10 of 14 (permalink) Old 07-08-2010, 02:15 PM
Date registered: Mar 2004
Vehicle: 1997 S600 (sold)
Quoted: 14 Post(s)
Pretty sure that box is not a factory item.
Brett
Brett San Diego is offline
removing cd changer in trunk on 2000 s-class s600 high123bid Audio & Telematics Forum 1 12-06-2009 02:45 PM
Removing cd changer...help mikelmco Audio & Telematics Forum 10 05-17-2008 05:04 PM
Removing CD Changer 16falcon R170 SLK-Class 2 04-08-2007 05:35 PM
Removing cd changer Darknessarises Audio & Telematics Forum 0 03-30-2006 02:54 PM
Car radio question: Is IP-bus changer control compatable with the stock CD changer in the trunk? DaveS R170 SLK-Class 1 04-04-2004 12:52 PM
