Ignition Switch Help!! 1995 S320 - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 06-16-2010, 06:13 PM Thread Starter
Brian Felts's Avatar
Date registered: Jan 2005
Hey all just replaced a bad ignition switch. Now the car is starting if I have the switch housing away from the part it clips over the steering col. pad where it locks the col. When I clip it back on the col. pad the key will not turn. What would keep this from working? Any tips on what I am doing wrong?
The cable that goes over to the shifter is screwed back on the side?
Thanks for any help
Brian Felts
www.geocities.com/southernohioauto
Brian Felts is offline
post #2 of 11 (permalink) Old 06-16-2010, 06:42 PM Thread Starter
Also it will go in and out of gear just as it should. Just can't get the key to unlock the steering col.
Thanks again
Brian
post #3 of 11 (permalink) Old 06-17-2010, 04:21 AM Thread Starter
I think its because I removed the switch in the 0 position not the 1. What can I do to solve this? I am in a bad way?
Brian Felts
post #4 of 11 (permalink) Old 06-17-2010, 07:55 AM
~BANNED~
Date registered: Aug 2008
Vehicle: 93 300se,92 300se,93 600 sel,92 500 sel,79 500slc,02 1.8t bug,01 a8,01 s80 t6,96 bmw 740il,86 rx7
Send a message via Yahoo to phamilton01
Did the steering col. lock with the key cyl out of the car? Because i heard there is no way you can unlock the col once the lock assembly is removed.
phamilton01 is offline
post #5 of 11 (permalink) Old 06-17-2010, 03:59 PM Thread Starter
No just removed the ignition lock and switch in the 0 position before I knew it had to be in the 1 position.
Brian
post #6 of 11 (permalink) Old 11-23-2011, 10:44 PM
S420L's Avatar
Date registered: Nov 2008
Vehicle: 94 S420L/400SEL
Did you ever manage to get around this problem or do you only drive strait now?
S420L is offline
post #7 of 11 (permalink) Old 11-24-2011, 05:43 AM
television's Avatar
Date registered: Sep 2005
Vehicle: 216 with everything. 2002 SL500 with everything. 2009 SL500 with everything.
Quoted: 148 Post(s)
Do you have this problem
Malcolm
"I thought my vasectomy would keep my wife from getting pregnant but apparently it just changes the color of the baby."
television is offline
post #8 of 11 (permalink) Old 11-24-2011, 06:07 AM
eddie a's Avatar
Date registered: Jul 2008
Vehicle: 84 500 SEL ...94 S420..... 95 S500.... 96 S500 95 S600
Quoted: 25 Post(s)
Yes, Hes having a problem with his ignition, Im not sure exactly what the issue is, he tried explaining it to me but, I was confused. Terek, Television wants to help you..where did you go?
eddie a is offline
post #9 of 11 (permalink) Old 11-24-2011, 08:26 AM
S420L's Avatar
Unfortunately i had someone try to steal my Benz & in the process they screwed up the ignition lock.
I couldn`t turn the lock. So i started to dissasemble it, and remove the entire ignition assembly from the car.
Then i managed to separate the lock assembly, but i couldn`t turn the key to position one so the steering wheel is in the locked position.
So i am trying to source a lock tumbler with key & work out how to disengage the steering wheel lock.
Thanks in advance
S420L is offline
post #10 of 11 (permalink) Old 11-24-2011, 08:56 AM
television's Avatar
Quoted: 148 Post(s)
Looks like the pin will have to be ground off,,I have some info on this and will try and find it.
Someone on here might know a better way or another way
Malcolm
    GenI Ignition tumbler/ ignition switch AzimuthAviation W126 S,SE,SEC,SEL,SD,SDL Class 4 12-07-2010 10:36 PM
    ignition lock cylinder & ignition switch lakeside W164 M-Class 2 07-23-2007 06:55 PM
    1995 Ignition switch gone99 W124 E,CE,D,TD Class 0 01-21-2007 03:41 PM
    1997 S320 W140 Ignition Lock & Switch Removal pbrennan10 W140 S-Class 0 10-07-2005 08:15 AM
    1995 s320 Old Otto W140 S-Class 7 04-30-2005 02:20 PM
