Transmission Fluid (how to add and check) - Mercedes-Benz Forum
post #1 of 17 (permalink) Old 05-19-2010, 04:01 PM Thread Starter
vvee12's Avatar
Date registered: Nov 2007
Vehicle: 1997 Mercedes 600 Coupe & 1995 500 Coupe, 2004 Yamaha R1 200hp 360 pounds
Send a message via Yahoo to vvee12 Send a message via Skype™ to vvee12
I have a feeling my tranny fluid is low on my 97 600 (its the 5 speed tranny) but I am curious how to check the levels (it doesnt have a dipstick) and how to add fluid (what type and brand).
Any help would be appreciated
CL600 V12 Coupe
vvee12 is offline
post #2 of 17 (permalink) Old 05-19-2010, 04:04 PM
eddie a's Avatar
Date registered: Jul 2008
Vehicle: 84 500 SEL ...94 S420..... 95 S500.... 96 S500 95 S600
Quoted: 25 Post(s)
The dealer sells one that is universal..it was $48.00..I bought one and havent had to use it yet...
eddie a is offline
post #3 of 17 (permalink) Old 05-19-2010, 04:35 PM Thread Starter
vvee12's Avatar
yes thanks but how do you check or add fluid?
CL600 V12 Coupe
vvee12 is offline
post #4 of 17 (permalink) Old 05-19-2010, 05:06 PM
iss
iss's Avatar
Date registered: Aug 2009
Vehicle: 1998 Mercedes-Benz S500
Quoted: 12 Post(s)
start the car and drive for about 5-10min then stop and park do not turn off the engine(must running) then find your transmission tube, it should be behind your engine by the back wall.Thats the place that you check your oil and fill your oil up. Good luck and also you should by a dip-stick or make your own
Oh MAN!!! Every second i am older and older!
iss is offline
post #5 of 17 (permalink) Old 05-19-2010, 10:54 PM Thread Starter
vvee12's Avatar
so are you saying that I should use the SAME dipstick from the oil? Will it be the same readings (meaning is the oil dipstick the same size as a tranny dipstick)?
CL600 V12 Coupe
vvee12 is offline
post #6 of 17 (permalink) Old 05-19-2010, 11:47 PM
iss
iss's Avatar
Quoted: 12 Post(s)
nooooo! the oil one is only for the engine oil!!! and its about 18-25 in. long ,but you need about 50 in. long and its fit to ALL 722.xxx trannys.(universal.) or take a flex cable about 50 in. long and make the mesurment at the and like i post on a pic.
iss is offline
post #7 of 17 (permalink) Old 05-19-2010, 11:54 PM
iss
iss's Avatar
Quoted: 12 Post(s)
here is mo info: PeachPartsWiki: 722.6 Transmission Fluid and Filter Change
iss is offline
post #8 of 17 (permalink) Old 05-20-2010, 12:17 AM
Date registered: Mar 2010
Vehicle: 1995 Mercedes-Benz S420 (W140), 1997 BMW 740iL (E38), 2011 C300 Luxury (W204)
Quoted: 2 Post(s)
Do not use the same dipstick. The motor oil dipstick is for the motor oil. You'll need to buy a new transmission dipstick or make your own. Or buy it off Eddie a, I'm assuming that is what he is trying to suggest.
If the previous owner never DIH(Did it himself) and there doesn't exist a dipstick, then you'll have to do the above. Also, I believe the cap is a one-time use thing, so unless you have a dipstick or something to cap it, don't check the fluid level yet. The cap that says FOR MB SHOP ONLY, I think, breaks off once you take it off.
The PO of my car did his own transmission fluid change I think, I have the transmission fluid dipstick, but I've seen those caps that break off from other posts. Hope this helps.
Sinned420 is offline
post #9 of 17 (permalink) Old 05-20-2010, 12:21 AM
MBs600v121998's Avatar
Date registered: Jul 2007
Vehicle: 1996 Mercedes-Benz S 600 L (W140)
Send a message via MSN to MBs600v121998 Send a message via Yahoo to MBs600v121998
Yes my V12 friend, that sucks, about no Dipstick aviable !
Check my attachement for full chart tables of the filling amount .. ofcourse if you have the Dipstick..
One more thing.
What is your transmission number ?
is it 722.362 or
722.621 or
765.940 ?
And good luck Buddy
File Type: pdf Check oil level in automatic transmission and correct if necessary.pdf (104.8 KB, 2974 views)
Gott sei Dank.
Ich habe eine wunderbare 1996 V-12 Mercedes-Benz S 600 L (W140).
Sie ist brillant-silber und schwarzem Leder von innen.
VIN ist WDB1400571A291571
Sales Bezeichnung S 600 L (1996)
Engine-Nr. 120982 12 000709
Transmission 722621 00 003522
MBs600v121998 is offline
post #10 of 17 (permalink) Old 05-20-2010, 01:55 AM
TasmanianDevil's Avatar
Vehicle: 1994 Benz S320 SWB / 1986 Porsche 911 Targa / 1998 Benz CL 500
Quoted: 4 Post(s)
One more thing.
is it 722.362 or
722.621 or
765.940 ?
And good luck Buddy
Nice Attachment! Do you happen to have something similar to this for the 722.508 ?
Thanks.
TasmanianDevil is offline
    how to add transmission fluid stormybmw W163 M-Class 4 08-02-2009 10:15 PM
    URGENT: where do I add auto transmission fluid for 420 SEL uspassport W126 S,SE,SEC,SEL,SD,SDL Class 2 08-10-2005 12:01 AM
    How do you check the transmission fluid? fredrice R170 SLK-Class 5 01-22-2004 02:34 PM
    How often should I check my transmission fluid? Four Door Monster W126 S,SE,SEC,SEL,SD,SDL Class 8 02-14-2003 02:06 PM
    CHECK TRANSMISSION FLUID? CAN YOU TELL ME HOW? ZO FITNESS R170 SLK-Class 3 10-22-2001 10:16 AM
