017 Crankshaft position sensor L5 - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 05-02-2010, 03:22 PM Thread Starter
Date registered: Apr 2010
Vehicle: S 420 Coupe, 500 sec, A 150
Current fault: 017 Crankshaft position sensor L5. Still get this code, i have changed the sensor three times now,.... ??? Could it be a EZL fault ? Engine stall, hard to start, cold/warm. w 420 coupe.
gekkkk is offline
post #2 of 8 (permalink) Old 05-02-2010, 09:50 PM
Date registered: Mar 2004
Vehicle: 1997 S600 (sold)
Quoted: 12 Post(s)
Have you checked wiring to the sensor? Might want to examine mounting of the sensor. It needs to have a close tolerance to the ring gear. Possibly check ring gear for issues.
Brett
Brett San Diego is offline
post #3 of 8 (permalink) Old 05-02-2010, 11:00 PM
MBs600v121998's Avatar
Date registered: Jul 2007
Vehicle: 1996 Mercedes-Benz S 600 L (W140)
Send a message via MSN to MBs600v121998 Send a message via Yahoo to MBs600v121998
Brett
Mr. Brett is right
I had the same error, and after i bought the sensor, the problem was with the wirings !
Can you give me Mr. Brett a picture or the scientefic name of a gear Ring to check it .
And thanks for everything
Gott sei Dank.
Ich habe eine wunderbare 1996 V-12 Mercedes-Benz S 600 L (W140).
Sie ist brillant-silber und schwarzem Leder von innen.
VIN ist WDB1400571A291571
Sales Bezeichnung S 600 L (1996)
Engine-Nr. 120982 12 000709
Transmission 722621 00 003522
MBs600v121998 is offline
post #4 of 8 (permalink) Old 05-03-2010, 06:55 AM Thread Starter
Sensor mounting and ring gear looks ok. Might be the EZL who is burning the crankshaft sensor ??? Dont know how much power EZL is sending to the Crankshaft sensor,.....
gekkkk is offline
post #5 of 8 (permalink) Old 05-03-2010, 10:40 AM
Quoted: 12 Post(s)
Yeah, could be the EZL as well. I would think you'd want to rule out wiring before buying an EZL.
Brett
post #6 of 8 (permalink) Old 05-03-2010, 10:47 AM
Quoted: 12 Post(s)
I don't have pictures. The ring gear is the big gear mounted to the engine output shaft that the starter engages to start the engine. The teeth on this gear are used by the crankshaft position sensor (CPS) to sense the rotation of the crankshaft. At one particular position, there are 2 teeth missing on the gear. These missing teeth mark top dead center for cylinder #1. The CPS senses the missing teeth, and the computer uses this information to time the engine spark properly.
Brett
post #7 of 8 (permalink) Old 05-03-2010, 01:16 PM
Brett
Thank you Sir.
Gott sei Dank.
post #8 of 8 (permalink) Old 05-03-2010, 01:52 PM Thread Starter
Wiring looks ok. The car has lived his life in the garage,..used only 4-5 times a year,..its a old car but it looks like a new. No damage-codes on the EZL, but maybe its broken anyway ??? Do a broken EZL always give a fault-code ?
gekkkk is offline
    Crankshaft Position Sensor Nasier W220 S-Class 4 07-12-2010 06:53 AM
    Crankshaft Position Sensor / Camshaft Position Sensor to3033 W140 S-Class 4 03-26-2010 01:15 PM
    Crankshaft Position Sensor okiloveu W210 E-Class 6 11-12-2009 11:30 AM
    Cam Position Sensor Or Crankshaft Position Sensor? Ryanoscerous W210 E-Class 8 04-02-2009 05:18 PM
    crankshaft position sensor mcavs W220 S-Class 9 04-13-2008 05:00 PM
