how to change oil filter? - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 04-26-2010, 09:28 PM Thread Starter
Date registered: Aug 2009
Vehicle: 94 S320 4speed
Quoted: 2 Post(s)
As a non-mechanic, I have changed screw on oil filters, but dont understand how mercedes' works. Can anyone explain to me? Or I'll have to let dealer do it.
(W140). I can do the rest with an extractor. Thanks.
sclass200812 is offline
post #2 of 14 (permalink) Old 04-27-2010, 11:20 AM
mslchief's Avatar
Date registered: Dec 2006
Vehicle: 1987 560SL - 1994 S420 - 2005 S55 AMG
Remove the airfilters, and on the passenger side of the engine near the fender you will see the oil filter canister. Remove the top bolt and pull out. Its rather long, about 6 inches. Bend a piece of coat hanger into a small "J" type hook and insert it into the bolt hole, hook the side , and pull. Flip the small wire up and pull out the oil filter. Replace with new one and reassemble. Most quality oil filters come with a new copper washer for the oil pan drain bolt and new o rings for the filter cap. Apply a light coat of oil to the o rings during reassembly. I don't know the torque value for the bolt, I just tighten it up.
mslchief is offline
post #3 of 14 (permalink) Old 04-27-2010, 11:53 AM
Date registered: Jan 2010
Vehicle: 1995 S320 SWB, 1997 S420 LWB
His car is a s320 with m104 and will have the oil filter on the driver's side near the firewall...it has a black cap you'll need a special MB tool to open it properly but people use generic tools....
drcane is offline
post #4 of 14 (permalink) Old 04-27-2010, 07:18 PM
Date registered: Aug 2005
Vehicle: 99 S320 (Sold at 280,000 miles) 2010 S550, 2008 C300
Quoted: 4 Post(s)
Correct, oil filter on driver's side near firewall. Use Oil filter "Cap B" size, available at WalMart or any auto shop. Works just fine.
Getting there in a W140 is only half the fun....
the return trip is the other half!
Kiawah is offline
post #5 of 14 (permalink) Old 04-28-2010, 04:08 AM
bobs's Avatar
Date registered: Dec 2007
Vehicle: '97 S320 (LWB), '01 E320
It's a piece of cake to do. Like others have said, get hold of a filter wrench. If you can't find one at your local auto parts store, go a Harley-Davidson or BMW motorcycle dealer and get one there. They're all the same size!
The only other word of advice I can offer is to put paper towels around the area when you remove the cap. The filter will stay attached to it while you pull it out and will almost always drip oil on the engine.
Once you have it out, you can simply pull the filter cartridge off of the cap. If you look at your new filter, you will see one end has a hole and one does not. The end without the hole is the one that goes in the cap. Push it in until it snaps into place. Don't forget to replace the rubber o-ring as well. Then all you have to do is put the cap/filter assembly back in its housing and tighten it back up. I start by screwing down by hand as far as it will go and then torquing to 25 nm.
"It's not about how fast you can go, but how well you can go fast."
'97 S320 (LWB), Ruby Red Metallic/Tan, 75k miles
'01 E320, Black/Charcoal, 105k miles
Gone but not forgotten. . .
'97 S420V, Smoke Silver Metallic/Tan, (RIP 22 Oct 2012, 178627 miles) He gave his life to save mine.
bobs is offline
post #6 of 14 (permalink) Old 04-28-2010, 06:30 AM
MBs600v121998's Avatar
Date registered: Jul 2007
Vehicle: 1996 Mercedes-Benz S 600 L (W140)
Send a message via MSN to MBs600v121998 Send a message via Yahoo to MBs600v121998
There it is marked in the following picture, but zou need to remove the Air filter like mentioned.
Check this for the whole Procedure.
http://www.benzworld.org/forums/w140...0-got-2-a.html
Gott sei Dank.
Ich habe eine wunderbare 1996 V-12 Mercedes-Benz S 600 L (W140).
Sie ist brillant-silber und schwarzem Leder von innen.
VIN ist WDB1400571A291571
Sales Bezeichnung S 600 L (1996)
Engine-Nr. 120982 12 000709
Transmission 722621 00 003522
MBs600v121998 is offline
post #7 of 14 (permalink) Old 04-28-2010, 10:07 AM
Vehicle: 1997 E320, 1997 S320
like drcane mentioned above, your oil filter is located on driver's side near the firewall, next to the brake fluid reservoir. it's a little tight in there, but not too bad. you can buy an cap-style filter wrench at any autoparts store, i think they cost around $5-6, or you can just buy the mb one from your dealer for more than that. if you have a strong grip you might be able to unscrew the filter cap without the use of any tools, and just tighten it with your hands. personally i don't use the wrench, i just tighten with my hands by using a small towel to increase grip. also don't forget to change the filter cap o-ring, the oil filter kit comes with the o-ring. if you are sucking oil than you don't have to worry about replacing drain plug washer, but if draining than replace the copper washer also
p.s. did you ever replace the spark plugs? what did you end up using?
tirona is offline
post #8 of 14 (permalink) Old 04-28-2010, 05:47 PM
Sorry MBs600v121998 you are incorrect. Your car is a 600 and his car is a 320 with m104 6 inline....
drcane is offline
post #9 of 14 (permalink) Old 04-28-2010, 06:08 PM
yellow arrow in the attached m104 pic (taken from "m104 engine" yahoo image search) points to where oil filter is located.
tirona is offline
post #10 of 14 (permalink) Old 04-28-2010, 07:36 PM
Thanks tirona, nice clean engine What do you use? I envy that....
drcane is offline
    Oil/Oil filter change B180 CDI N1KSX W245 B-Class 11 04-13-2011 08:17 AM
    C240 Oil Change, Air Filter change atiqraza W203 C-Class 4 04-29-2010 11:27 AM
    1981 240D oil change oil filter assembly ? 50 cool 50 W123 E,CE,D,CD,TD,TE Class 3 04-23-2010 06:54 PM
    Oil Change: How do you get the Oil Filter Black Cap off?? UniquelySanFrancisco W163 M-Class 25 07-05-2009 09:13 PM
    Just did my Oil change & air filter change. What else does Service B entail? RaleighMB W210 E-Class 5 03-07-2009 07:39 PM
