Speedometer Cluster Replacement - Mercedes-Benz Forum
post #1 of 19 (permalink) Old 04-02-2010, 10:16 AM Thread Starter
mslchief's Avatar
Date registered: Dec 2006
Vehicle: 1987 560SL - 1994 S420 - 2005 S55 AMG
Well, the odometer is dead on my 1994 S420. I saw a few instrument clusters on Ebay and most have the digital odometer vs. the analog one I currently have. Is there any issue with replacing the 94's cluster with a 95 or 96? I know I could order the gears for the VDO odometer, but replacing the cluster would update the interior and be less work. Also, anyone know if the replacement cluster would read my current miles, say off the computer, or would it retain the miles from the donor mercedes?
mslchief is offline
post #2 of 19 (permalink) Old 04-02-2010, 10:37 AM
Date registered: Jun 2009
Vehicle: 1x 98 S500, 1x 07 S550
There's a few places that do VDO repair real well. Just off the top of my head:
Lauderdale Speedometer and Compass
Palo Alto Speedometer: Repair, Restoration, and Sales of Automobile Gauges
and Beckman Technologies <-- these guys also do great work on ECUs and the proverbial climate control units
I've used each at least once, your mileage may vary. If you want to swap years, they're certainly the ones to tell you. I know 97-99 CAN be interchangale, depending on the PROM versions.
Good luck!
Remember - "There's nothing like the ride of a well tuned 140 - NOTHING" - Baxnet
geebee is offline
post #3 of 19 (permalink) Old 04-02-2010, 10:51 AM Thread Starter
mslchief's Avatar
I gotwith Lauderdale and the price is $255 plus shipping. I think I'm going to go with ebay. Has anyone tried installing the digital odometer in place of the analog one?
Tanks GeeBee
mslchief is offline
post #4 of 19 (permalink) Old 04-02-2010, 10:53 AM
Can you post a link to the one you're considering? I'm curious what they look like
Thanks!
geebee is offline
post #5 of 19 (permalink) Old 04-02-2010, 11:06 AM Thread Starter
mslchief's Avatar
I can't right now. Our work computers block ebay. If you go to ebay type 's420 instrument cluster' in the search bar. Most of the ones that come up are the digital ones.
mslchief is offline
post #6 of 19 (permalink) Old 04-02-2010, 12:55 PM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T and others
The early analog speedometers can be replaced with the digital type I think up to mid nieties. If you look at this page it will describe the three different styles. The digital cluster will show the miles of the donor car, it can be reprogrammed but not by you.
MBCluster.com Mercedes W140 Instrument Cluster Repair Homepage
Peter Guenther is offline
post #7 of 19 (permalink) Old 04-02-2010, 07:57 PM
Haku's Avatar
Date registered: Nov 2006
Vehicle: 1996 S320 (Kuro) 1998 S600 (Weiss)
Quoted: 4 Post(s)
Send a message via MSN to Haku
I was wondering the same thing and found a donor cluster to test with (retain the mileage or not) - alas - no - i just gave me the readout of the milage of the car it had come out of and not mine
Haku is offline
post #8 of 19 (permalink) Old 04-04-2010, 06:43 AM
MBCluster's Avatar
Date registered: Feb 2010
Vehicle: 1992 500SEL
Quoted: 5 Post(s)
For the old mechanical odometer types, If you're getting the dash-flash issue then your power circuitry is fried. Actually that flashing is driven by the seatbelt warning light circuitry feeding back power into the instruments, that's why the flash rhythm looks so familiar.
If your odometer/speedometer has stopped ticking, then that's another problem. Rare, but your odometer drivers are fried. That is fixable. I have heard of the broken gear issue, but have never personally seen it on a 140 or 129. These guys have the gears :
Odometer Gears | 72 Croatan Road | Newport News, VA 23606 | 757.593.3478
Reprogramming the digitals was historically done at the factory, even the dealer didn't do it. This company says they can sell you the equipment to do it, looks interesting :
SMELECOM
MBCluster is offline
post #9 of 19 (permalink) Old 04-10-2010, 06:09 AM Thread Starter
mslchief's Avatar
Exclamation Photos of Speedometer Replacement
I got the replacement cluster from Ebay and it looked great. The connections on the back are the same - just the two pairs, round and square, on the left and right side, are reversed. The connectors plugged in without issue. When I started the car all the gauges came to life and the odometer works.
Details for the photos.
First, here is my orginal Cluster. I removed it by going through the air vent.
Next here is the donor, digital, replacement
Remove the 2 screws at the top. Mine needed a crosstip #1, the donor cluster uses a #10 torx
I also took out the 5 screws along the bottom, however this is not required for cluster removal. I had to look. The back will flip up
Here is detail photo of the speedometer prong connectors.
Cut 5 pieces of stiff cardboard, like junk mail flyer.
Insert one between each of the 5 tabs and the white clip.
Flip the back down if you opened it and reattach a few screws before removing the clear plastic face.
Hold the 2 pieces and alternately tug the two apart. The warning light labels will probably fall out. They slide back in, no problem.
Here is the speedometer. Take out 3 screws with crosstip or if digital torx screwdiver
Speedometer removed. Here is a detail of the back side.
Reverse order for reinstallion.
Bad news, the digital cluster does not plug and play with the orginal. I need to use the entire donor instrument group.
I have the following isues with the donor cluster.
First the gas gauge reserve and fuel red and yellow lights flash on and off every second and all the warning lights on the right side or passenger side of the cluster stay on all the time.
Can I repair this fault?
ID:	301300   Click image for larger version
ID:	301301   Click image for larger version
ID:	301302   Click image for larger version
ID:	301303   Click image for larger version
ID:	301305   Click image for larger version
ID:	301306   Click image for larger version
ID:	301307   Click image for larger version
ID:	301308   Click image for larger version
mslchief is offline
post #10 of 19 (permalink) Old 04-10-2010, 06:29 AM
MBCluster's Avatar
Quoted: 5 Post(s)
So I take it that the mechanical one you are disassembling is your original, and the digital is the one on Ebay? Also, the digital one is acting up on your car aswell? Interesting.
The digitals are not known to go bad, as they are now the replacement part for the W140s, replacing the older analog types which were prone to failure. If the digital is acting funny, then there is a good chance you have a wiring issue with the car.
The old mechanical ones can fry by themselves, or with some help by either boosting, or by an electrical problem. Especially if any of the positive inputs are flakey and disappear during operation, this will definitely fry it. The digitals are friendlier and you can throw anything at them, and they wont fry, they'll just misbehave, similarly to what you are seeing.
Since your digital is consistantly misbehaving, from what you described, it should be easy to track down the issue. In my FAQ page, there is a pinout of the round connectors identifying + and -. Go through it carefully and verify yours are either good or bad. If you find a problem, its a wiring issue.
  • Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
    W202 Speedometer Cluster kinghais W202 C36 AMG, C43 AMG 2 06-28-2009 07:43 PM
    W202 Speedometer Cluster kinghais W202 C-Class 0 06-24-2009 09:06 PM
    Speedometer/Instrument cluster question psnewman W123 E,CE,D,CD,TD,TE Class 4 12-06-2005 09:33 AM
    AMG speedometer cluster Dr.Grillz W126 S,SE,SEC,SEL,SD,SDL Class 13 05-01-2005 03:12 PM
    Removal of Instrument Cluster (Speedometer) JB1012 W163 M-Class 8 12-26-2002 11:20 AM
