Dash warning light - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 03-09-2010, 08:08 PM Thread Starter
Date registered: Jan 2007
Vehicle: 1999 S600 33K, 1994 E320 Cabriolet 13K, 2001 500SL 15K
Dash warning light
I haven't driven my car for a couple months and the battery got low so it would not turn over fast enough to start so I plugged in the Battery Tender (a low voltage charger installed at the battery) so after a day it was charged and I started it perfectly but the ASR,BAS and ride control light are all lit when I start it. I put my code reader on it and it says no stored codes. I have to drive it tomorrow and am wondering if these will go away after I drive it a bit - would a low battery cause these to set on even though there are no codes or pending codes stored?
JohnMichael is offline
post #2 of 5 (permalink) Old 03-09-2010, 08:10 PM
~BANNED~
Date registered: Sep 2007
Vehicle: 99 Merc S420 (80k Mi) 07 Lexus LS460 (21k Miles)
A low battery can cause very strange malfunctions. You need to plug into a star computer and have these codes reset. I would also do a battery load test to see if your battery is still good. It might need replacement.
mr.xpowerseller is offline
post #3 of 5 (permalink) Old 03-10-2010, 04:06 AM
syljua's Avatar
Date registered: Sep 2004
Vehicle: 1998, C140, CL500
Quoted: 46 Post(s)
Originally Posted by JohnMichael View Post
I but the ASR,BAS and ride control light are all lit when I start it.
After your have disconnected the battery (and reconnected), your steering angle sensor
has to be calibrated. Turn steering wheel one full round to each extent, and the lights
will go out.
br,
syljua
C140 CL500 1998
W123 230E 1984
syljua is offline
post #4 of 5 (permalink) Old 03-10-2010, 09:05 PM Thread Starter
As soon as I backed out of my garage the lights went out so maybe turning the wheel as I had to do to must have done the trick. Went on a 90 mile trip and car ran perfect with no lights coming on. Thanks to those who answered my post!
post #5 of 5 (permalink) Old 03-11-2010, 05:11 PM
~BANNED~
You should still do a battery load test. Any AutoZone or Advance Auto Parts store will do it for free.
    Spanner warning light on dash thumpergorvan V-Class 3 04-02-2011 12:50 AM
    Dash warning light help pauloDingle BenzWorld Help 0 01-03-2010 06:05 AM
    Brake warning light on dash ... cause ?? TJ R170 SLK-Class 4 08-25-2009 10:00 AM
    warning light on dash mistawes V-Class 3 08-11-2009 04:53 AM
    what is this dash warning light? tocproducer W123 E,CE,D,CD,TD,TE Class 3 10-02-2005 01:39 PM
