blower fan starting to make noise.. what should i do - Mercedes-Benz Forum
post #1 of 26 (permalink) Old 02-27-2010, 11:07 PM Thread Starter
Date registered: May 2009
Vehicle: 1999 Black S320.. 278,000 and still pulling strong
Exclamation blower fan starting to make noise.. what should i do
hello again everyone well i have been having a noise coming from my blower fan.. its a ticking noise and only makes the sound when the heat or ac is on... when i accelerate the noise gets louder but it is a constant sound.,, i know its the blower fan.. but what should i do.. is it a quick fix or do i need to replace the whole unit??
thanks for the help guy
by the way the noise is very anooyinggg
vaser21 is offline
post #2 of 26 (permalink) Old 02-28-2010, 12:22 AM
samosali's Avatar
Date registered: Nov 2007
Vehicle: W140 Mercedes 500 SE, 1992, European, 400.000 km
Quoted: 207 Post(s)
you must check the blower (fan) itself. it is easy, only 6 screws to remove. search this forum for "blower" or "cabin filter" and you will find instructions how to get access to the blower. most probably all four screws of the blower are losen and the fan touches something. Or maybe something else is going on, it is almost impossible to guess.
All I wish for Christmas is a smooth idle.
samosali is offline
post #3 of 26 (permalink) Old 02-28-2010, 02:08 AM
Date registered: Jul 2005
Vehicle: W220 S320 CDI 2005; W140 S280 1994 (Sold Nov. 2012)
Mine went through a phase of making a noise every time I turned left! The motor, as I recall, is mounted on screws with rubber bushes so that there is some flexibilty. In my case, the fan moved a fraction under - I guess - a centrifugal force, when manoeuvring, so that it touched the nearest bit of fan casing. I simply untightened, repositioned and retightened and haven't had a problem since. You can't move the motor much at all, but you only need a gnat's whisker.
The fact that your fan makes more noise when you accelerate suggests that the fan swings back a fraction (or perhaps sideways, since it will respond like a gyroscope) and touches the casing more. Could be a very simple fix.
Good luck,
Mike
MikeJT is offline
post #4 of 26 (permalink) Old 02-28-2010, 05:41 AM
Merc600sec's Avatar
Date registered: Mar 2004
Vehicle: SEC 600 V12 2dr COUPE (RHD) One of the chosen few.
Send a message via MSN to Merc600sec Send a message via Yahoo to Merc600sec
Fan touches surfaces when the filter is no longer giving full flow.. as it pulls air it rises if there is not sufficient air .. change the filter .. or take it out to see if you still have noise.. if you do .. bottom bearing is wearing... needs lubrication...
Torque isn't cheap
Merc600sec is offline
post #5 of 26 (permalink) Old 02-28-2010, 10:10 AM Thread Starter
thanks guyss i will check it soon... but merc600 which filter the regular airfliter or the charcoal filter
vaser21 is offline
post #6 of 26 (permalink) Old 02-28-2010, 10:29 AM
Date registered: Feb 2010
Vehicle: 90 300SL, 94 SL600, 99 E320 Wagon, 01 S500, 04CL55, 07GL450, 66 230SL
Quoted: 4 Post(s)
He's talking about the pollen filter that sits just above the blower motor.
ph2ocraft is offline
post #7 of 26 (permalink) Old 02-28-2010, 03:54 PM
Date registered: Sep 2009
Vehicle: nothing broken. finally!
yeah that filter also has 2 types: regular and charcoal activated, not to be confused with the big one near the firewall
get the regular one. the other one is just money wasted
vw phaeton. when vw copies mercedes, but forces you to service it next to golfs and jettas
gyrate is offline
post #8 of 26 (permalink) Old 02-28-2010, 07:41 PM
eddie a's Avatar
Date registered: Jul 2008
Vehicle: 84 500 SEL ...94 S420..... 95 S500.... 96 S500 95 S600
Quoted: 25 Post(s)
Blower motor noise?
Remove the complete assembly and inspect it,could have a cracked or broken cage or blower motor could be moving up and down from getting worn out causing it to rub at curtain times.Check all screws for tightness and theres not much else that it could be...
eddie a is offline
post #9 of 26 (permalink) Old 03-02-2010, 02:24 PM Thread Starter
hey guys took everything apart... found a small pointy leaf in the blower fan took it out but sure enough the noise started again... so today i took it all apart again tightend the screwa which were not even really loose and i also saw that the filter had alot of debris in it so i vaccumed it out and reasemmbled everything looks like no more noisee yayaya
vaser21 is offline
post #10 of 26 (permalink) Old 03-02-2010, 05:15 PM
MBCluster's Avatar
Vehicle: 1992 500SEL
Quoted: 5 Post(s)
I would also recommend immediate inspection. Mine did the same thing, it was the brushes bottoming out. Then the noise went away as the metal wore away, finally seizing the rotor, then blowing the thermo-switch. A nice $750 lesson nobody needs to learn! Check squeeky blower motors ASAP!
Good luck!
MBCluster is offline
    Blower fan noise? kevinj W220 S-Class 4 01-30-2009 01:41 AM
    ventilation blower/fan noise stillee W140 S-Class 7 05-04-2006 08:14 AM
    heater fan/ blower noise? phoenix44 W163 M-Class 1 11-14-2004 08:06 AM
    IRREGULAR BLOWER FAN NOISE @START UP 86 420 sel W126 S,SE,SEC,SEL,SD,SDL Class 3 07-28-2004 09:21 PM
    Fan blower motor making noise azatrum W201 190-Class 7 02-18-2004 04:55 AM
