HELP!!! ASR LIMP MODE S320 - Mercedes-Benz Forum
post #1 of 24 (permalink) Old 02-22-2010, 02:33 PM Thread Starter
Date registered: Jan 2010
Vehicle: 1995 S320 SWB, 1997 S420 LWB
MY '95 S320 has been plagued with ASR limp mode from cold start. I rewired my ETA with military grade wire thanks to v12uburalles.com (wires were unbelievably bare with little insulation). I replaced the Maf sensor and brake light switch. After putting back the ETA, the car has high idle and the ASR light is still on and in limp mode. I'm going to replace the wiring harness but what else should I check? Has anybody been successful in erasing limp mode with a home brew code reader or does the steeler have to reset it with STAR?
drcane is offline
post #2 of 24 (permalink) Old 02-24-2010, 12:48 PM Thread Starter
Post
Originally Posted by drcane View Post
MY '95 S320 has been plagued with ASR limp mode from cold start. I rewired my ETA with military grade wire thanks to v12uburalles.com (wires were unbelievably bare with little insulation). I replaced the Maf sensor and brake light switch. After putting back the ETA, the car has very high idle and the ASR light is still on and in limp mode. I'm going to replace the wiring harness but what else should I check? Has anybody been successful in erasing limp mode with a home brew code reader or does the steeler have to reset it with STAR?
To do:
-ETA rebuild (maybe its a potentiometer problem)
-Neutral Safety Switch
-Wire harness (doesnt look bad)
-ASR Module???
drcane is offline
post #3 of 24 (permalink) Old 02-24-2010, 01:28 PM
Date registered: Jul 2004
Quoted: 306 Post(s)
You bought a car with ASR, one of the most troubled systems in the history of the company, if not the automobile. I have a 95 S320 w/o ASR and I can't buy a problem - feel like the Maytag repairman. You need to learn how to read the codes yourself, both on the 38 pin and the OBDII - DIY code reading is one of the great strengths on your year/model. A 220 would be out of the flying pan into the fire.
deanyel is online now
post #4 of 24 (permalink) Old 02-24-2010, 09:52 PM
Quoted: 306 Post(s)
ETS, electronic traction system, was standard on the 95 S320s, works only throught the brake system, rarely a problem. If you like the 220s go for it.
post #5 of 24 (permalink) Old 04-02-2010, 08:19 PM Thread Starter
Unhappy 3 months gone
Ok guys please some ideas....I've replaced the wiring harness. I've also had my throttle body rebuilt by bba reman. My car still has ASR light and is still in limp mode.
I have been unable to do the relearn procedure as it is obviously in limp mode. Could it be that bba did not do a good job rebuilding the throttle body actuator or the EA/CC/ISC control module N4/1 still needs relearning?....thanks for all your help guys
drcane is offline
post #6 of 24 (permalink) Old 04-03-2010, 03:39 AM
Date registered: Oct 2005
Vehicle: 500SE-92
Sounds troublesome, I don't know if I can help with anything, but I also have ASR, and it usually sets off just after starting, and I have to restart the car, and it is alright.
Do you hav a permanent ASR light on?
Anyway, I think I read somewhere that ASR is voltage sensitive, and have come to the conclusion on my car that it usually sets off, when the car has been standing for some days, and the battery is a little "drained" (don't know why, but this car drains the battery dry in 7-10 days if left standing).
porky500 is offline
post #7 of 24 (permalink) Old 04-03-2010, 07:23 AM Thread Starter
Thanks for the response...I thought it was the battery and bought a new one too but no change at all. I usually disconnect it so the alarm system doesn't drain it. Yes I have permanent ASR light from start up.... I will try and clear all error codes and bridge pin 1 and 6 and see if this helps....will post results. By the way porky500 I used to have that symptom before and restart would fix it but now no more so beware it is coming soon....
drcane is offline
post #8 of 24 (permalink) Old 04-05-2010, 02:50 PM Thread Starter
Ok guys....
I've tried the 1,6 pin jump and it didnt get me out of limp mode. When I clear all the error codes and start the car, the ASR and ABS light both come on, but restart and ABS goes away but ASR is still on...
On PIN 4- HFM SFI Engine control module (N3/4) I get:
DTC 8 CC or EA indicates "limp home" mode
DTC 42 CAN communication from ASR control module(N30/1) faulty.
DTC 45 Fuel safety shut off of electronic accelerator or cruise control active
On PIN 6- ASR/SPS control module N47-1 I get:
DTC 30 ASR only CAN data bus to EA/CC/ISC control module interrupted
DTC 40 SPS P valve Y10 (maybe why my steering is hard? What is P valve?)
On PIN 7- EA/CC/ISC control module (N4/1)
DTC 3 EA/CC/ISC actuator (M16/1) Reference potentiometer (M16/1r1) (voltage supply), Reference potentiometer (M16/3r1), Actual value potentiometer (M16/3r2), Safety contact switch (M16/3s1), Closed throttle position switch (M16/1s2), Actuator motor (M16/1m1), Magnetic clutch (M16/1k1), Reset not accomplished (actuator adaptation).
....I'm beginning to think bba reman didnt fix my actuator or my EA/CC/ISC, ASR and HFM engine control modules are fried? Any ideas guys please would be highly appreciated....
drcane is offline
post #9 of 24 (permalink) Old 04-07-2010, 02:19 PM Thread Starter
looks like its the modules
Ok guys....
....I'm beginning to think bba reman didnt fix my actuator or my EA/CC/ISC module N4/1, ASR/SPS module N47/1 and HFM engine control module N3/4 are fried? Any ideas guys please would be highly appreciated....
Ok guys according to STAR TekInfo, and STAR TekInfo the codes suggest I should test my EA/CC/ISC module N4/1, ASR/SPS module N47/1 and HFM engine control module N3/4 using an ohmmeter....I will post results. Seems like I'm talking to myself but hope this will be helpful to someone.... If the modules are bad I hope I can have them refurbished rather than get used ones that would need to be coded by the dealer....at this point I highly suggest nobody should try the 1,6 pin jump....
drcane is offline
post #10 of 24 (permalink) Old 04-09-2010, 11:36 AM Thread Starter
UPDATE:
Ok guys I pulled out the modules and the ASR module is bad. It's supposed to hold between 55-65 Ω and it was 21 Ω. The EA/CC/ISC control module N4/1 was ok holding steady at 120Ω. It's supposed to be between 115-125Ω. Looking to see if I can get this ASR unit refurbished or get a replacement....I will check the HFM engine control module N3/4 tomorrow, I ran out of time....where can I get a good ASR module part number 0155455632 ? Bba reman wants $425 to refurbish it. If I get a good used one does it need to be coded by the dealer like an engine module does? Somebody please?
drcane is offline
    asr light and limp mode kaju W140 S-Class 11 05-12-2011 04:07 PM
    ASR Light comes on and car goes into Limp Mode masaki@japan R129 SL-Class 51 05-02-2009 02:34 PM
    ASR-fault. Limp mode Eirik 400 SE W140 S-Class 39 05-02-2009 12:34 PM
    Limp mode and ASR quick fix! :D kevinpuri W140 S-Class 0 10-07-2007 03:20 PM
    Limp home mode due to ASR fault bayhas W140 S-Class 0 12-02-2005 11:09 PM
