coolant temperature sensor location - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 02-21-2010, 03:19 PM Thread Starter
Date registered: Oct 2007
Vehicle: 1997 s420 (pearl black opal), 2005 c230k (obsidian black)
Im getting a check engine with code P115.
anyone know where the coolant temperature sensor is located on a v8 ?
xhino87 is offline
post #2 of 10 (permalink) Old 02-21-2010, 06:45 PM
eddie a's Avatar
Date registered: Jul 2008
Vehicle: 84 500 SEL ...94 S420..... 95 S500.... 96 S500 95 S600
Quoted: 25 Post(s)
Coolant temp sensor
It is B11/4 on this diagram..
Name:	coolant temp sensor.jpg
eddie a is offline
post #3 of 10 (permalink) Old 02-21-2010, 08:13 PM
benz_300se's Avatar
Date registered: Dec 2007
Vehicle: 93 300se, 94 s420, 98 s420, 95 s500, 97 s500, 96 s320w, 96s320, 99 s420
Quoted: 6 Post(s)
plako you still want that tranny for your s420? apo e ke shit makinen.
w140 nut.
benz_300se is offline
post #4 of 10 (permalink) Old 02-22-2010, 12:33 AM
eddie a's Avatar
Quoted: 25 Post(s)
Speak english 300 Se ...and wheres my NEW Condensor? You can leave it by the door at the shop when you get it..please hurry,spring and summer are right around the corner.Dont make me hound you like an infant .Dont write! Dont call,just drop it off and well be good!
eddie a is offline
post #5 of 10 (permalink) Old 02-22-2010, 10:33 AM Thread Starter
i still have it, i put a new trany in.
btw eddie thanks for that diagram, it was just as i suspected.
xhino87 is offline
post #6 of 10 (permalink) Old 03-07-2010, 09:38 PM Thread Starter
so i changed the coolant sensor on top of the manifold, just like in the diagram but the check engine light is still on, even after disconnecting the battery it came back on.
is there another coolant temperature sensor somewhere?
xhino87 is offline
post #7 of 10 (permalink) Old 05-07-2011, 08:57 PM
Date registered: May 2011
Hi there,
Can someone plz help me ?
I have a 1995 Mercedes C220 and i have the check engine light on.
I took it last week to Autozone to have it diagnosed and they gave me a code(P0116).
They said it is either the Coolant temperuture sensor or the wiring that have a problem.
Whenever i drive on the highway past 50 miles/H, the temperature gauge stays below 80 and if i am in a traffic it start rising past 80.
Also i would like to know where is the coolant sensor located.
I opened up the cover box located right in front of the engine but there's three plugs but i don't know which one it is.
Help please !
aboridjaal is offline
post #8 of 10 (permalink) Old 05-25-2011, 07:28 AM
need prices on coolant sensors in B11/4?????
bzharris is offline
post #9 of 10 (permalink) Old 07-21-2011, 02:35 PM
Date registered: Jul 2011
where's the coolant sensor located for 2001 s500?
i can't find the coolant sensor of my 2001 s500. does somebody know? please help
lylle80 is offline
post #10 of 10 (permalink) Old 07-22-2011, 06:51 AM
hi, do you know how to remove the coolant temperature sensor in a 2001 s500 mb? would really appreciate your help
lylle80 is offline
    Temperature sensor location? Guest (MBNZ) W203 C-Class 5 06-09-2011 01:26 PM
    coolant temperature sensor samosali W140 S-Class 7 09-04-2008 12:34 AM
    temperature sensor location SikSlk99 R170 SLK-Class 9 06-05-2008 12:27 AM
    temperature sensor location help tmryan W201 190-Class 1 05-26-2004 11:41 AM
    Coolant temperature sensor Andrey W124 E,CE,D,TD Class 5 01-29-2003 11:53 AM
