rubbing noise while turning left.. problem solved.. details inside - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 02-19-2010, 10:27 PM Thread Starter
Date registered: May 2009
Vehicle: 1999 Black S320.. 278,000 and still pulling strong
hey everyone so i had a rubbing noise while turning left sharpley... check the wheel there was no aparent problems,, wheel bearing and ball joint were fine,,, so i found the thread about the sound dampingin material on around trans and driveshaft... turns out that this tends to sag after time.. on the left side one section of the insulation is in the shape of a square.. so this part sticks out from the rest... this piece has no support so it sags down lower than its suppose to,, when you take the sharp left turns the piece beds down from force and rubs against the driveshaft,,, thats why it only happens when turning left,,, there was aparent marks on the shaft that showed it was rubbing,,,, i tried beding the insualtion up but it just wouldnt stay,,, so i got some of the metall bracket with holes in it that comes rolled up like tape(dont know the name of it) turns out there is a crossmember brace directly under the insulation and there is a bolt stickinp up from it,,, so i bent both of the ends of the bracket 90 degreese,,, put the bolt from the cross brace in a hole on the bracket and it held the insulation up nice and tight,, after that,, i put a nut on the bolt to keep the bracket in place an then used a zip tie to secure it to a near by line to make sure it doesnt bend at all.. after all this took it on some sharp corners and no noise,,,, took some thinking but i hope its a permanant fix,,,
hope this helps many people out
o and just for everybodys information i am 17 and i did this without any help form anyone
vaser21 is offline
post #2 of 12 (permalink) Old 02-20-2010, 03:14 AM
Date registered: Dec 2006
Vehicle: 1999 S500 GRAND EDITION (32,800 Miles)
Nice job. Ingenuity is not a function of age.
Telechronos
1999 S500 Grand Edition
1984 380SL
1955 MG TF1500
1969 Factory Stick, Factory Tri-Power, Pontiac Grand Prix SJ
telechronos is offline
post #3 of 12 (permalink) Old 02-20-2010, 07:58 AM
MBs600v121998's Avatar
Date registered: Jul 2007
Vehicle: 1996 Mercedes-Benz S 600 L (W140)
Send a message via MSN to MBs600v121998 Send a message via Yahoo to MBs600v121998
Nice job , Young Man
I am sure you are so happy,
A photo to what you are talking about will help more people
Gott sei Dank.
Ich habe eine wunderbare 1996 V-12 Mercedes-Benz S 600 L (W140).
Sie ist brillant-silber und schwarzem Leder von innen.
VIN ist WDB1400571A291571
Sales Bezeichnung S 600 L (1996)
Engine-Nr. 120982 12 000709
Transmission 722621 00 003522
MBs600v121998 is offline
post #4 of 12 (permalink) Old 02-20-2010, 04:52 PM Thread Starter
got some pics of it
took some pics today.. went to make sure everything was ok
ID:	292071   Click image for larger version
vaser21 is offline
post #5 of 12 (permalink) Old 02-20-2010, 04:52 PM Thread Starter
you can see the marks on the drive shaft from where it was rubbing
vaser21 is offline
post #6 of 12 (permalink) Old 02-20-2010, 06:51 PM
Date registered: Mar 2004
Vehicle: 1997 S600 (sold)
Quoted: 14 Post(s)
nice job.
Brett
Brett San Diego is offline
post #7 of 12 (permalink) Old 02-20-2010, 11:57 PM
Nice Pics,
Thanks for Uploading them
Gott sei Dank.
post #8 of 12 (permalink) Old 02-21-2010, 02:22 AM
Shane10010's Avatar
Date registered: Apr 2009
Vehicle: 2003 Mercedes S320 CDi (W220)
I don't get any noises but my insulation is also rubbing.
Great solution!
In the past:
'76 280S, '79 350SE, '80 230e, '82 Audi 200T, '84 280SE, '85 280SL, '86 230TE, '?? 300TE, 89 560SEC, '92 500SL, '94 S500 Coupe, '96 S320, '98 S500, '00 CLK320, '02 S500, 03 VW GTi. Fair to say we fancy German and Mercedes in particular!
Shane10010 is offline
post #9 of 12 (permalink) Old 10-18-2010, 07:25 AM
Date registered: Sep 2009
Vehicle: 1999 Mercedes Benz S420 45K miles, 2007 Acura MDX, 1997 Honda Del Sol
Hi Vaser,
I have the same thing on mine s420 that you explained. When I am turning left I could hear the rubbing noise. Also when I am driving straight and pull the wheel to the left I could hear it. I checked the front wheel bearings and could not find anything wrong. I found rubbing marks on the shaft and insulation. I am going to fix this issue ASAP. It drives me nuts. Thanks again
germangs is offline
post #10 of 12 (permalink) Old 10-24-2010, 08:28 AM
I was able to locate the same thing. So what I did was pushing the isolation material up and noise is gone. But it may return again because that material will sag eventually. At least I know what causes that. I bought a bearing already and was about to replace it. My friends who own the auto shop were very skeptical about the isolation rubbing the shaft theory. So we lifted the car and found that it actually does rub the shaft around. The rubbing marks were visible. Os We pushed it up around. It was 5 minutes job to do. I drove back home without detecting any rubbing noise.
germangs is offline
    Metal like grinding noise while turning left... ClK55r1d3h C208/A208 CLK-Class 8 10-31-2010 10:54 AM
    faint rubbery rubbing noise when turning Mike Wevrick W220 S-Class 2 02-16-2010 06:37 AM
    03 s600 noise when turning wheel left atv087 W220 S-Class 0 01-31-2010 05:38 PM
    Scraping noise from left front when turning? Kbike W123 E,CE,D,CD,TD,TE Class 2 11-19-2005 02:06 PM
    Screeching noise when turning left bondavi R/C107 SL/SLC Class 1 08-10-2005 04:15 AM
