w140 S600 sensors PO156 and PO130 - PLZ HELPP!!! - Mercedes-Benz Forum
post #1 of 21 (permalink) Old 01-23-2010, 04:13 PM Thread Starter
Date registered: Aug 2006
Please help !!?
My baby 1996 S600 failed smog check - Passed emission check but failed Functional computer check - here is reading of OBD fault codes.
PO156 02 sensor fault (Bank 2 Sensor 2)
PO130 02 sensor fault (Bank 1 Sensor 1)
Here is another thing, occasionally my gas tank indicator will start blinking along with PCE and ESP light ON, plus the check engine light (Last certified tech just reset it and said not to worry - just need to replace 02 sensors) but now engine is making "wrong" noise and sluggish or i say it feels druggish on acceleration - feels like engine is bumping - when reversing it's especially noticeable. Tomorrow I'm replacing sensors - any tips what else to check? Thans you all
unSobill320 is offline
post #2 of 21 (permalink) Old 01-23-2010, 08:06 PM
iss
iss's Avatar
Date registered: Aug 2009
Vehicle: 1998 Mercedes-Benz S500
Quoted: 12 Post(s)
after replacing the sensors do not forget to erase the codes!!! and then scan again, just in case.
Oh MAN!!! Every second i am older and older!
iss is offline
post #3 of 21 (permalink) Old 01-23-2010, 08:40 PM
MBs600v121998's Avatar
Date registered: Jul 2007
Vehicle: 1996 Mercedes-Benz S 600 L (W140)
Send a message via MSN to MBs600v121998 Send a message via Yahoo to MBs600v121998
Originally Posted by unSobill320 View Post
Please help !!?
Sorry to hear what you are facing, The S600 Beast needs a little care
Just replace the Sensors, and then make another test.. erase the Codes, and see if there is any Stored Codes.. then you should Worry..
Things will be Fine. dont Give Up
Gott sei Dank.
Ich habe eine wunderbare 1996 V-12 Mercedes-Benz S 600 L (W140).
Sie ist brillant-silber und schwarzem Leder von innen.
VIN ist WDB1400571A291571
Sales Bezeichnung S 600 L (1996)
Engine-Nr. 120982 12 000709
Transmission 722621 00 003522
MBs600v121998 is offline
post #4 of 21 (permalink) Old 01-24-2010, 02:05 PM Thread Starter
thanks for support fellow benzorz
Just wondering if I bough this 2 sensors for both banks - will the work or i need two different sensors?
1996-1998 Mercedes Benz S600 Oxygen Sensor : eBay Motors (item 270403767216 end time Jan-31-10 19:23:37 PST)
post #5 of 21 (permalink) Old 01-25-2010, 09:12 AM Thread Starter
replaced and reset sensors - now check engine light is flashing... should i drive it for 30 more miles before computer resets itself?
post #6 of 21 (permalink) Old 01-25-2010, 04:23 PM
Date registered: Mar 2004
Vehicle: 1997 S600 (sold)
Quoted: 14 Post(s)
Flashing check engine light typically means a misfiring condition. Check fault codes and see what's coming up. If it seems to run OK, I think I would continue to drive it and see if things get better.
No other symptoms, now? You said it didn't seem to be running right and felt sluggish before. How are your long term fuel trims? They can be read with an OBDII code reader. Are the new O2 sensors behaving properly? You can observe the real time signals with the more advanced OBDII code readers.
Brett
Brett San Diego is offline
post #7 of 21 (permalink) Old 01-25-2010, 07:29 PM Thread Starter
Thank YOU for reply
I have not checked long term fuel trims but my buddy who installed sensors mentioned car is misfiring...
also car has smell of gas in the cabin upon moderate acceleration and when driving upwards or climbing hills.
post #8 of 21 (permalink) Old 02-07-2011, 03:49 PM Thread Starter
I'm still not able to prepare OBDII sensors, i've tried everything i think i can try...
Car is leaking and gas smell inside the car gets stronger with every month...
I'm so dissapointed and sad - i'm located in LA and there's not a single adequate honest body shop around to look into my problems... I was able to extend my registration with referee as i've spent over $1000 and nothing have changed with OBDII sensors.. arghh not sure what i will do next year. Screaming for help
post #9 of 21 (permalink) Old 02-07-2011, 04:27 PM
Quoted: 14 Post(s)
Wow. It's been a year since your initial post.
I have more questions. What kind of fault codes are you getting now? What do you mean by you are not able to "prepare" OBDII sensors? Do you have a flashing check engine light indicating a misfire? Do you still have the flashing fuel gauge light, which indicates a gross leak in the evaporative emissions system? Have you monitored your O2 sensor signals with an OBDII scanner? Beyond all this, is it running poorly?
Brett
post #10 of 21 (permalink) Old 02-07-2011, 07:09 PM Thread Starter
I know... i've been battling over this for so long, spent so much without results, thanks for reply.
I dont have OBDII scanner, No flashing check engine lights or any other lights for this matter.
Last time fault codes were, not sure how to check again:
no flashing fuel gauge light - its just sometimes acting weird - when im its 1/3 empty sometimes it drops down completely red and then slowly moving up to 1/3 again...
Car running fine - just takes over 10min for RPM to drop to 5 when just starting cold.
Oh also i'm driving in Winter mode - not sure if that's matter - in Summer mode car seems to have problems shifting to higher gear. Car would accelerate to lets say 35 on really high RPM and RPM would never drop for some reason
Also my shocks or suspension is in trouble i feel - car feel too rough on bumps and sometimes rough on sharp turns. Here's all my symptoms doctor
    W140 S600 v. W220 S55 AMG/S600 W140FTW W140 S-Class 51 08-10-2010 06:57 PM
    WTB '94 S600 Mas Air Sensors Dariusz For Sale/Wanted/Trade/Giveaway 2 12-20-2009 06:43 PM
    '94 S600 Mas Air Sensors Dariusz For Sale/Wanted/Trade/Giveaway 0 12-15-2009 10:38 PM
    2002 S600 Problem - Doesn't Go - Plz Help keilind3 General Mercedes-Benz 5 07-24-2008 12:01 PM
    2002 S600 Problem - Doesn't Go Plz Help keilind3 W220 S-Class 2 07-23-2008 06:31 PM
