Smell of burning plastic - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 01-07-2010, 06:26 PM Thread Starter
VoD
Date registered: Jun 2009
I have a 98 S320 and have been smelling burning plastic from the front while driving. I turned off the blower to see if that had any impact and it still stunk. What could possibly be melting? Has anyone had a similar experience?
VoD is offline
post #2 of 7 (permalink) Old 01-07-2010, 06:35 PM
Vehicle: 1993 300SEL (Sold) 2007 X5
Quoted: 8 Post(s)
Sometimes something like a plastic bag can get blown under the car and stuck on hot engine parts of the exhaust.
First thing to do would be to inspect the engine bay and underside. Is the car running hot?
NZ Benz is offline
post #3 of 7 (permalink) Old 01-07-2010, 07:08 PM Thread Starter
VoD
No plastic bag and not running hot.
VoD is offline
post #4 of 7 (permalink) Old 01-08-2010, 10:30 AM
Date registered: Jul 2005
Vehicle: W220 S320 CDI 2005; W140 S280 1994 (Sold Nov. 2012)
Is it there while the engine is idling? Did you have any lights on at the time? When you say that you turned off the blower, does that mean you turned it to MIN or that you turned the a/c controller off?
I guess that if it's there while idling and with the a/c off you ought to be able to narrow down the area where it's coming from.
The only time I had a 'smell' it just appeared in the car without any clear origin. I only found the source when the central locking failed - it was the motor of the PSE pump under the rear seat: the nylon plate carrying the motor's brush holders was melting/carbonising.
Good luck,
Mike
MikeJT is offline
post #5 of 7 (permalink) Old 01-10-2010, 09:24 PM
Date registered: Apr 2008
Vehicle: 1995 Mercede-Benz S500
Quoted: 9 Post(s)
This had happen to me awhile back and the thing that was burning was my rear side light. The one that is located in the rear seat next to the rear headrest that lights up when you open the door. The wires was touching and it melted the whole light asymbly and i had to get another replacement from Eddie A. So if you are smelling it i suggest checking out all your interior bulbs where your reading lights are. Check all interior bulbs.
Current:
1995 S500
1993 Volkswagen Corrado SLC VR6
hellah fresh is offline
post #6 of 7 (permalink) Old 01-10-2010, 10:50 PM
bayhas's Avatar
Date registered: Oct 2005
Vehicle: SL55, 300SE, GL450, Daytona 955i
Quoted: 299 Post(s)
Send a message via MSN to bayhas Send a message via Yahoo to bayhas
since you have a 320, does your car leak oil?
Garage:
Mercedes-Benz, W140 S Class S320 (AKA 300SE)
Mercedes-Benz, R230 SL Class SL55 (///AMG)
Mercedes-Benz, X164 GL CLass GL450
Triumph Daytona 955i
Former Mercs:
R129 SL Class SL500 (passed on) - W163 M Class ML430 Designo (for sale) - W140 S Class 500SEL(sold) - W140 S Class S320(sold) - W140 S Class S500(sold) - W140 S Class 500SEL(sold) - W201 190E 2.3(sold)
bayhas is offline
post #7 of 7 (permalink) Old 01-16-2010, 07:13 AM Thread Starter
VoD
Mike JT,
The blower completely off. I looked at the blower near the passengers side hood hinge under the hood and could not smell it there. The headlights on or off. Smell occurs daytime or nighttime, when idling or driving. I will check the PSE pump.
hellah fresh,
Interior lights look fine.
bayhas,
No oil leak.
Is there a blower directly behind the interior center front dash vents?
I would think a fuse would blow prior to a wire or electrical connection overheating.
VoD is offline
    Plastic burning smell smoke coming out on top of radiator astonmartinrapide W203 C-Class 1 03-24-2009 04:49 PM
    Burning smell? jerryatric C209/A209 CLK-Class 0 11-25-2006 07:17 AM
    Burning Smell IT'S NOT THE DRIVER W163 M-Class 2 07-27-2006 03:34 AM
    burning smell... Express W163 M-Class 2 03-26-2006 06:54 PM
    Burning Smell :o( v8mbp W202 C-Class 1 06-17-2003 02:22 PM
