Electric Seat Repair - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 01-06-2010, 04:33 PM Thread Starter
Disco Dan's Avatar
Date registered: Sep 2009
Vehicle: 1997 S280
Post Electric Seat Repair
Electric Seat Repair:
One of the functions of my drivers seat was not working and was getting to me so I set about to find out why and fix it.
I needed to remove the seat bottom to gain access to the motors - easier said than done! To remove the seat bottom, four bolts two on each side need to be removed. The two on the rear sides require the seat to be moved fwd/bkw until a hole in the frame lines up with the bolts - thankfully that feature worked! Although to get at the ones closest to the centre of the car required the seat be unbolted and tilted to gain access. Be careful of the wire cable and the wiring loom when moving the while seat around!
Here is a picture of my drivers seat with seat bottom removed:
The front of the seat bottom raises and lowers but the rear does not. So I took a look at the motor:
The motor was working however a gear had broken into three parts inside the box:
Now i know what is wrong, I can try and find a replacement gear and get the seat working.
If anyone has this part I would love to hear from you!
"I don't understand bus lanes. Why do poor people have to get to places quicker than I do?"
"Speed has never killed anyone. Suddenly becoming stationary - that's what gets you."
Jeremy Clarkson.
Disco Dan is offline
post #2 of 2 (permalink) Old 01-06-2010, 08:12 PM
jfamondone's Avatar
Date registered: Mar 2006
Vehicle: 2007 ML 350 Iridium Silver/ Ash (Sold)
Post
Hello, I had a broken PLASTIC gear on my drivers seat that would not allow the seat to stay in the highest position.
I had the dealer remove the seat and try to repair, my gear was NOT a piece that you can buy as a part and replace.
I purchased 2 used front seats, had the dealer remove the piece from the old seat that I needed and fix my seat. WORKS GREAT!
In your picture you show 4 round motors where your gear is broken, I have 8 of those motors, are they all the same for each function? If they are, I will remove 1 motor and send it to you so you can replace the gear or just install the motor I send you.
Let me know if you want it, I will be glad to send it to you.
ID:	283296   Click image for larger version
2007 ML350, Iridium Silver/ Ash MB Tex
1996 S320LWB, Brilliant Silver Metallic / Gray Leather (SOLD)
2004 S500, Black / Charcoal Leather (SOLD)
2006 C230 Sport, Granite Grey / Black MB-Tex / Leather (SOLD)
2003 E320, Brilliant Silver Metallic / Charcoal Leather (SOLD)
2002 ML320, Everest Green Metallic / Java Leather (SOLD)
jfamondone is offline
    Electric seat not working... Sunray C208/A208 CLK-Class 17 04-18-2010 10:13 AM
    Need help with electric seat dmjay65 C208/A208 CLK-Class 1 09-20-2009 09:59 AM
    E320 1997 electric rear sunshade how to repair rcozzarelli W210 E-Class 4 01-28-2009 02:55 PM
    Electric seat - manual seat ianrandom W126 S,SE,SEC,SEL,SD,SDL Class 5 08-14-2008 03:42 PM
    Electric Seat Problem kingy R129 SL-Class 1 01-24-2005 10:43 AM
