Key won't turn in ignition! - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W140 S-Class
Old 12-21-2009, 10:59 AM   #1 (permalink)
mickey_m79's Avatar
Date registered: Aug 2007
Vehicle: 92 400se sold,92 500sl sold,98 ls400 sold,95 325ci sold,91 500sl,92 300se,95 740i,03 escalade esv
I've searched this but haven't been able to find any info on it. The other day I parked my car and got back in to get it out of the driveway and I put the key in the ignition but the key won't turn. I've tried it with the other key I have and it still doesn't work.
Does anyone know if theres a sensor or a relay somewhere that might be affecting this?
I have already disconnected the battery for an hour and a half but it didn't work. I also tried playing with the steering wheel and pressing in the brake pedal too but that didn't work.
Thnx
mickey_m79 is offline   Reply With Quote
Old 12-21-2009, 03:18 PM   #2 (permalink)
Merc600sec's Avatar
Date registered: Mar 2004
Vehicle: SEC 600 V12 2dr COUPE (RHD) One of the chosen few.
Send a message via MSN to Merc600sec Send a message via Yahoo to Merc600sec
Check the trans position it has a lock out.Try this... foot brake on shift lever to N then back to P then try the key
Torque isn't cheap
Merc600sec is offline   Reply With Quote
Old 12-21-2009, 05:06 PM   #3 (permalink)
Date registered: Dec 2007
Try this
Try turning the steering wheel slightly, then try turning the key again. Mine (1999 S-500) sometimes will not turn-on either and this solves the problem.
quakercity is offline   Reply With Quote
Old 12-21-2009, 05:11 PM   #4 (permalink)
Date registered: Jul 2004
What year is the car?
deanyel is offline   Reply With Quote
Old 12-21-2009, 08:00 PM   #5 (permalink)
mickey_m79's Avatar
Sorry forgot to mention I have a 1992 300se.
I am wondering maybe I can remove the ignition and somehow release it. Is it easy for a DYI? I saw a youtube video where the guy used a special tool to remove it but I have a feeling you can remove it yourself without the tool.
Old 12-21-2009, 08:10 PM   #6 (permalink)
You have the old style tumbler which is fairly easy to replace and fairly inexpensive, under a hundred dollars ususally. You can try lubricating it. Eventually it will grab your key and not let go of it and then you're in for a more expensive fix. You do need a special tool.
Old 12-22-2009, 01:58 AM   #7 (permalink)
mickey_m79's Avatar
Thank you guys,I am going to attempt all of the above and will keep everyone posted,I have a feeling its a simple fix,the car is parked on upwards hill so it might need a little push or movement to release the lock somehow.
Old 12-22-2009, 03:57 AM   #8 (permalink)
Date registered: Jul 2005
Vehicle: W140 S280 1994
Thnx
Like Merc600sec says, I think that this is a mechanical lock-out which is connected to the gear selector position. A pin prevents the key turning if you're not in P or N. It could be that friction in that system is preventing the pin withdrawing but I don't know how it is activated at the gear selector end of the mechanism. I believe that there is something like a Bowden cable moving the pin at the ignition switch end. Personally, I would try spraying IPA or switch cleaner into the key hole - something that leaves no residue.
Good luck,
Mike
MikeJT is offline   Reply With Quote
Old 12-22-2009, 05:02 PM   #9 (permalink)
mickey_m79's Avatar
To update everyone:
I tried putting my foot on the brake pedal and shifting the gear from park to neutral and back but the gear selector shifter won't move.I do not want to apply too much pressure and risk breaking the gear shifter. I also lubricated the keyhole and it still didn't work.
In order to remove the ignition from the column I am undrstood that you need to put the key and turn the key to a position before you can remove the tumbler, unfortunatley my key does not move at all in the ignition so this can be difficult.
I removed the cover underneathe the sterring wheel and I can see the igntition as well as that cable that has the lock mechanism from underneath.I am wonder if there is a way to remove the ignition from underneath the steering wheel or disconnecting the cable connected to the pin lock,maybe this will work.
Any suggestions? Thnx
Old 12-23-2009, 01:19 AM   #10 (permalink)
Have a look at this link - it may help. Maybe you could jump straight to step 7.
http://www.benzworld.org/forums/w140...ml#post3027664
Mike
Bookmarks
Help!!!!!!!!!!!!!! key won't turn ignition leetec W210 E-Class 84 03-16-2013 01:10 PM
Ignition key won't turn! danny13 W163 M-Class 9 11-05-2011 02:56 PM
'86 190e Ignition key problem- the key won't turn Guest (MBNZ) W201 190 Class 7 04-13-2010 03:35 PM
IGNITION kEY WILL NOT TURN double nickle General Mercedes-Benz 4 07-12-2007 09:09 AM
Ignition key didn't turn. meariesguy W220 S-Class 0 07-05-2006 02:43 PM
