Spark plugs? - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 12-15-2009, 07:09 PM Thread Starter
El Prez's Avatar
Date registered: Jan 2009
Vehicle: 1996 S500 and 2002 S600
Send a message via Skype™ to El Prez
Spark plugs?
Can I use the same spark plugs that I put into my 1992 500SEL - NGK BKR6E for my 1995 S320?
2001 S430 - The Silver Bullet - sold - Jan 2013
1996 S500 - The New Kid On The Block
1995 S320 - The Graceful Grey Girl - sold - Feb 2011
1992 500 SEL - The Big Black Beautiful Beast - deceased Jan 2010
El Prez is offline
post #2 of 12 (permalink) Old 12-15-2009, 07:19 PM
4benzes's Avatar
Vehicle: 2111 GLK 2000,2003 ML 350,2006 R350,1996 300D, 2001 C
Send a message via AIM to 4benzes
You actually had the wrong plugs in your 92....they called for
Standard BKR5ES 2460 .032
V-Power BKR5E 7938 .032
G-Power BKR5EGP 7090 .032
Iridium IX BKR5EIX 6341 .032
The 95 calls for the same plug
4benzes is offline
post #3 of 12 (permalink) Old 12-15-2009, 07:29 PM Thread Starter
El Prez's Avatar
Thanks for that. The BKR6E 6962 were recommended on the forum so I went with them, hopefully they will be ok?!
El Prez is offline
post #4 of 12 (permalink) Old 12-15-2009, 09:50 PM
Date registered: Dec 2006
Vehicle: 1997 E320, 1997 S320
on the s320 (m104) ALWAYS use copper plugs (bosch F8DC4 or equivalent), and also replace the 3 connectors (coil to plug), they cost only $6/piece and should be replaced every time you replace the spark plugs (40k miles). replacing spark plugs on s320 is so easy anyways, takes me about 10 min for whole job and i'm not a mechanic
tirona is offline
post #5 of 12 (permalink) Old 12-15-2009, 11:20 PM
W140 Moderator
Merc-S600's Avatar
Date registered: Aug 2007
Vehicle: Merc 93 W140 S600 / Merc-05-413CDI-Sprinter Turbo / Merc-09 B180-CDI / Holden Rodeo RA 3.5L V6 <
Quoted: 364 Post(s)
Those NGK -BKR6E are the Superior Plug to the Bosch , i had the Bosch in mine but ript them out after just a few Days as the Car just didnt Start the Way it does with the NGK Plug ,Exellent for the 5.0Litre Engine anyway ,dont know if they are any good for the 6 Cylinder Engines .
Why is it the Wrong Plug in the Beginning when it goes Better,much much better with NGK than Bosch ?.
Ciao
OK,next Question : Why did i choose NGK over Bosch ? I Originaly had NGK's in the Engine ,as i tought (Naturally) that Bosch was the better choice for the Car ,i installed Bosch Plugs ,for my Surprise ,The Car Hesitated a second or so on Starting the Engine, so out they wend and in another New Set off NGK's <This is why NGK's is Best and also some People told me too that they are a Better Plug ,I do belive it after my Experience .
nathanD.rector likes this.
>->->- My-S600 ->->->-
Driving a W140 & everything else feels like is standing still .
Everything you like to know about the W140's
>>>> " http://www.mb-w140.de/ " <<<< .
==============ALL AUSTRALIAN W140 OWNERS ,CLICK ME:==============
Merc-S600 is online now
post #6 of 12 (permalink) Old 12-16-2009, 02:07 AM
Date registered: Dec 2008
Vehicle: 1993 MB 300SE
So the Bosch Fusion Iridium plugs I have in my '93 300SE are not as good as normal copper ones?
mb380fahrer is offline
post #7 of 12 (permalink) Old 12-16-2009, 08:17 AM
well, if you have no problems keep them, if there is problems then you know where to first look
tirona is offline
post #8 of 12 (permalink) Old 12-16-2009, 10:26 AM
bayhas's Avatar
Date registered: Oct 2005
Vehicle: SL55, 300SE, GL450, Daytona 955i
Quoted: 293 Post(s)
Send a message via MSN to bayhas Send a message via Yahoo to bayhas
exactly...
none the less, anything other than copper top plugs will show signs of early failure in the form of misfire...
so as Tirona said, keep em for now, but replace them with the first sign of misfire...
Garage:
Mercedes-Benz, W140 S Class S320 (AKA 300SE)
Mercedes-Benz, R230 SL Class SL55 (///AMG)
Mercedes-Benz, X164 GL CLass GL450
Triumph Daytona 955i
Former Mercs:
R129 SL Class SL500 (passed on) - W163 M Class ML430 Designo (for sale) - W140 S Class 500SEL(sold) - W140 S Class S320(sold) - W140 S Class S500(sold) - W140 S Class 500SEL(sold) - W201 190E 2.3(sold)
bayhas is offline
post #9 of 12 (permalink) Old 12-17-2009, 10:15 AM
Thanks for the tip. Actually I was a bit disappointed when I put them in to replace very worn plugs when I bought the car. The new plugs didn't make the difference I expected and the engine is vibrating at idle just a bit, at least sometimes. Seems like I'll be changing plugs again. How are those NGK V power? Better question, what plugs are the best for the 93?
post #10 of 12 (permalink) Old 12-17-2009, 11:13 AM
bayhas's Avatar
Quoted: 293 Post(s)
Bosch are the OEM plugs...
Garage:
Former Mercs:
bayhas is offline
    how to replace spark plugs and where are the plugs in 1994 c280? poorsenti W202 C-Class 4 05-02-2011 09:30 AM
    Spark Plugs & Spark Plug Wire Reccomendations danger450 R170 SLK-Class 2 02-19-2009 07:02 PM
    What Spark Plugs? Spark Plug gap? Spark plug used? hilarushi W210 E-Class 4 03-30-2007 12:42 AM
    Glow Plugs or Spark Plugs?? Are they the same thing? sudha W123 E,CE,D,CD,TD,TE Class 4 11-30-2005 11:27 PM
    Spark plugs, who's work best, and how about Platinum or Iridium plugs? Bruce R. W201 190-Class 2 07-11-2003 05:25 AM
