1995 S500 coupe door panel removal - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 11-21-2009, 01:36 PM Thread Starter
Date registered: Apr 2009
I need to remove the door panel on my car it is different from the four door. Does anyone know how to remove this from a coupe. The main problem is the seat switch has some trim around that the sedan does not. I have removed several sedan panels in the past but this trim has stumped me I dont want to damage the wood.
Thanks
Mitch
Racing Porsche is offline
post #2 of 5 (permalink) Old 11-23-2009, 07:28 AM
Date registered: Aug 2009
i removed the door panel on my s600 coupe because my window slider was broken! it was painful until i got it! how to remove the door panel its easy! first unscrew the side door trim on the side where the hinge is! then its all plastic clips around! u dnt have to take out switch first u take the whole panel off with the switch on and then if u need u ll figure it out! once u get all clips out grab the panel and lift it up and it will come off then remove wires from switches etc.... if u need more help PM me !
Djox is offline
post #3 of 5 (permalink) Old 11-23-2009, 06:21 PM Thread Starter
Thanks for the help.
Mitch
post #4 of 5 (permalink) Old 01-08-2010, 04:53 AM
Shane10010's Avatar
Vehicle: 2003 Mercedes S320 CDi (W220)
Hi,
i)
Remove Steel side plates - 8 screws
ii)
a) Open compartment on arm rest
b) remove 3 circular black covers then remove screws
c) Remove felt cover inside compartment and at base of grab handle then remove screw
iii)
Loosten plastic retaining clips around edge of door pad
iv)
Remove triangular inside mirror cover
v)
Remove doorpad and disconnect wiring
You can now:
a) Repair doorpad
b) Remove / replace / repair memory seat switches
c) Remove / replace / repair wood trim
d) Remove / replace / repair door handle
Reverse for installation.
Hope this helps someone.
Shane
In the past:
'76 280S, '79 350SE, '80 230e, '82 Audi 200T, '84 280SE, '85 280SL, '86 230TE, '?? 300TE, 89 560SEC, '92 500SL, '94 S500 Coupe, '96 S320, '98 S500, '00 CLK320, '02 S500, 03 VW GTi. Fair to say we fancy German and Mercedes in particular!
Shane10010 is offline
post #5 of 5 (permalink) Old 01-10-2017, 04:50 AM
Date registered: Feb 2015
Vehicle: 1993 S500 Coupe, 1982 500SL and 1986 190e 2.3-16 Cosworth
Quoted: 14 Post(s)
Yes very useful thank you.... now how do I get the door latch out....
rlambert911 is offline
Removal of Rear door panel on 99 S500 Joey6 W140 S-Class 4 10-06-2010 04:28 PM
S500 W220 Drivers Door Inner panel removal richi_412 W220 S-Class 11 11-13-2009 08:44 PM
1995 S500 Coupe bmdougherty W140 S-Class 1 06-04-2006 05:11 AM
driver's side door panel removal 1995 e320 Mightydoor W124 E,CE,D,TD Class 3 10-04-2005 08:25 PM
c230 coupe door panel removal???? doyle613 W203 C-Class 0 07-14-2005 07:40 AM
