Hi, after taking the driver's door panel apart and re-assembling, the one-touch up & down no longer works on that door. The battery was not disconnected and the other 3 windows still work as usual. I'm assuming that this simply means that the window needs to 're-learn' the top & bottom position to re-enable the one-touch feature. However, using general feedback on the procedure, I put the key in the ignition and turn to position 1 (accessory power), then roll up the window, and push the switch up (the first click for up/down, not 2nd click for one-touch up/down) for 15s or 20s. Same for down.
Unfortunately it is having no effect. I have tried the 2nd position (one-touch) both up & down; I have tried pressing it for 30s. Is there any special trick to resetting / re-learning the one-touch up & down on a W140? Should the key not be in the ignition? Or did I break something else while I was in the door there?
TIA, Andy
