Fuel Sending Unit Repair? - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 11-08-2009, 06:53 PM Thread Starter
edong's Avatar
Date registered: Feb 2006
Vehicle: 1996 S420, 1992 300E
Quoted: 2 Post(s)
Is there a way to fix the fuel sending unit on a 1996 S420. My gauge sometimes show erratic fuel level and very slow to move from empty to the right level.. I am trying to see if there is a way to clean the old one before I buy a new one.
edong is offline
post #2 of 11 (permalink) Old 11-08-2009, 08:00 PM
Date registered: Jul 2004
Quoted: 312 Post(s)
Don't know but I've always wanted to try that, perhaps soaking in lacquer thinner to dissolve the crud and varnish. You've got nothing to lose if it's gone.
deanyel is online now
post #3 of 11 (permalink) Old 11-08-2009, 08:27 PM
~BANNED~
Date registered: Sep 2004
Vehicle: 1996 S600 1991 560SEL 1995 S500 2009 S550
yes it is possible to be cleaned, but you can only inspect the sending unit ones you take it out of the tank. Normally those things don't cost much.
cool is offline
post #4 of 11 (permalink) Old 11-08-2009, 08:48 PM
~BANNED~
Date registered: Aug 2008
Vehicle: 93 300se,92 300se,93 600 sel,92 500 sel,79 500slc,02 1.8t bug,01 a8,01 s80 t6,96 bmw 740il,86 rx7
Send a message via Yahoo to phamilton01
It can be cleaned, I did it on my cl. Just be careful removing the clip. There is a special tool to remove the locking ring that gets brittle. Loves to break. be slow about removing and you will be ok. Dont soak in thinner tho, use a good degreaser and follow up with c.l.r. it works great!
phamilton01 is offline
post #5 of 11 (permalink) Old 11-09-2009, 08:09 PM Thread Starter
edong's Avatar
Quoted: 2 Post(s)
Thank you all for the help. What kind of special tool do I need to remove the clip? Is the clip available from the dealer in case I break it?
edong is offline
post #6 of 11 (permalink) Old 11-10-2009, 06:25 AM
Quoted: 312 Post(s)
For some reason this is an exception to that rule - later V8s are well over $200. I can remember buying 124 fuel sending units for $30 just a few years ago.
post #7 of 11 (permalink) Old 11-10-2009, 10:19 AM
~BANNED~
The w140 is the exception to the rule. If that doest work i have a sender, Your welcome to it. The tool is aval from the dealer. If you wanna spend alot of money. I can show you how to make one if your interested. The sender i have is from a 95 s500. Im not sure the year of your car but see if it will work and get back to me.
Pat
post #8 of 11 (permalink) Old 11-10-2009, 01:56 PM
Quoted: 312 Post(s)
The 1995 is completely different part for some reason - and well less than half the price of the 96-.
post #9 of 11 (permalink) Old 11-10-2009, 02:26 PM
~BANNED~
The part number may be diff but i think its the same part.Ill do a interchange on it.
post #10 of 11 (permalink) Old 11-10-2009, 02:53 PM
Quoted: 312 Post(s)
The parts don't even look remotely similar, which is not say they don't interchange, have to get them side by side.
    The Ultimate Solution to the Fuel Gauge/Fuel Sending Unit Problem jengel111 W163 M-Class 4 03-10-2013 11:22 AM
    Fuel sending unit ?? unlukky C208/A208 CLK-Class 13 02-18-2010 02:40 AM
    Fuel gage sending unit jaybro W202 C36 AMG, C43 AMG 5 06-08-2009 04:51 AM
    Fuel Sending unit... JBowers W126 S,SE,SEC,SEL,SD,SDL Class 6 12-11-2008 04:41 PM
    Anyone had a bad fuel sending unit??? 4benzes W163 M-Class 8 07-03-2002 10:37 AM
