Rear end of car sagging.. help.. - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 06-23-2009, 03:59 PM Thread Starter
smiley_lt's Avatar
Date registered: Apr 2009
Vehicle: 1999 Mercedes S320, 1991 Mercedes 420SEL, 2003 BMW 325I
I have noticed that in the past year or so the rear end of my car is slowly starting to sag.. I was wondering if any of you guys know whether if it is caused by the shocks or springs? The car is a 1999 s320. I have also noticed that with the rear sagging so much that it has cause the front to rise. Would that be the cause of my front tires having its outer tread wear more than the rest of the front tires?
smiley_lt is offline
post #2 of 9 (permalink) Old 06-23-2009, 05:16 PM
The andrew's Avatar
Date registered: May 2008
Vehicle: 1993 W140 500SEL Black/Black, 12014 Ford Fiesta ST Blk/Blk
How many miles on the car?
Shocks, unless self leveling, will not affect ride height.
You may have alignment issues up front, camber or toe problem.
For the most part you may just have tired springs in the rear, a sagging rear will only make it seem like the front has risen, granted your car is not a see-saw at the local park. My neighbor has an S420 96MY, he has a serious case of worn rear springs, top of tire cannot be seen it is slightly tucked up into the wheel well, he does not have self leveling, he does however have 240k miles or so.
"However, not the the aesthetic masterpiece you might have expected for a billion dollars, but all of them, and this one in particular, justifies it's price through sheer attention to detail." -Jeremy Clarkson
Over 184K and it's sweet!
It MUST have been that leather wrapped dash that got 'er going, what else do you have to offer?
The andrew is offline
post #3 of 9 (permalink) Old 06-23-2009, 06:08 PM Thread Starter
smiley_lt's Avatar
The car has about 113,000 miles on it. I'll try to take some pictures of it and post it.
post #4 of 9 (permalink) Old 06-23-2009, 07:17 PM
kevinpuri's Avatar
Date registered: Oct 2005
Vehicle: 93 500 sel - 95 s500
*if your car has self level*
I had the same problem at 250,000 km. It turns out my accumulators were leaking and I was slightly low on fluid. I had both replaced for $600 including labour. My mechanic also told me there is an adjustment for self leveling where you can dial-in the ride hight. Maybe another member will have more info on this.
I doubt by the age of you car that the springs are tired, so this may be a good place to start.
Kevin
There Are a Number of Mechanical Devices Which Increase Sexual Arousal, Particularly In Women. Chief Among These Is The W140 S-Class Mercedes-Benz
Black and Grey '95 S500, Black and Grey two tone interior - Blackberry Metalic '93 500 SEL, Mushroom interior
kevinpuri is offline
post #5 of 9 (permalink) Old 06-23-2009, 09:37 PM
The andrew's Avatar
Kevin
Yes the lever off the swaybar to the valve can be adjusted, a 10mm nut can be loosened and the linkage can slide to attain a desired height.
post #6 of 9 (permalink) Old 06-25-2009, 06:03 AM Thread Starter
smiley_lt's Avatar
My car doesn't have the self leveling shocks. I'm going to replace the rear shocks this weekend and see what results I'll get from it. I figured its about time to replace the rear shocks anyways. I'll have to do it sooner or later. If it rise the rear end of the car back up then my problem is fixed. If it doesn't then I'll proceed to get a set of lowering springs and swap out all the springs. Any suggestion of what brand I should get?? I'm leaning more of Eibach or B&G as of right now if I have to get new springs.
post #7 of 9 (permalink) Old 06-25-2009, 08:02 AM
bayhas's Avatar
Vehicle: SL55, 300SE, GL450, Daytona 955i
Quoted: 278 Post(s)
Send a message via MSN to bayhas Send a message via Yahoo to bayhas
the fron is not raised, replace your rear springs, then do an alignment, and you ll be all set.
Garage:
Mercedes-Benz, W140 S Class S320 (AKA 300SE)
Mercedes-Benz, R230 SL Class SL55 (///AMG)
Mercedes-Benz, X164 GL CLass GL450
Triumph Daytona 955i
Former Mercs:
R129 SL Class SL500 (passed on) - W163 M Class ML430 Designo (for sale) - W140 S Class 500SEL(sold) - W140 S Class S320(sold) - W140 S Class S500(sold) - W140 S Class 500SEL(sold) - W201 190E 2.3(sold)
bayhas is offline
post #8 of 9 (permalink) Old 06-28-2009, 04:21 PM Thread Starter
smiley_lt's Avatar
I swapped out my rear shocks yesterday and you guys were right... the rear shocks has nothing to do with the height of the car... in the following month or so I'm going to try and change the springs depending how busy my schedule looks.. thanks for all your inputs.. by the way.. after swapping out the old shocks with the new one, the ride is a lot more firmer..
post #9 of 9 (permalink) Old 06-29-2009, 12:09 AM
bayhas's Avatar
Quoted: 278 Post(s)
make sure you get the OEM spring compressor when you do the job.
no after market compressor will be able to fully collapse your springs...
Garage:
Former Mercs:
bayhas is offline
    raising sagging rear end (300D) little_r_a W123 E,CE,D,CD,TD,TE Class 14 08-06-2013 02:22 AM
    SL55 Sagging Rear End ltcjmramos R230 SL-Class 5 08-28-2010 04:42 AM
    Sagging rear end of my '97 S420 kxmills W140 S-Class 1 04-02-2007 03:12 PM
    this seems to have cured my sagging rear end issue snik W140 S-Class 0 01-18-2007 06:33 PM
    here is the picture of the sagging rear end interior-magic R129 SL-Class 13 04-29-2006 12:33 AM
