S320 running rough after timing cover reseal - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 06-16-2009, 06:22 PM Thread Starter
Date registered: May 2008
Vehicle: 1994 Mercedes-Benz S320 SWB
Send a message via AIM to adam94
I replace my timing cover seal the other day along with the belt tensioner, Everything went back together good but once I started the car the idle was very unstable... like a slight miss
In park the rpms are at 700 to 750
When I put the car in gear it gets really bad and the rpms go from 500 to 750
I checked if the spark plug wires were plugged in all the way and they were fine and in the correct order.
All sensors are plugged in and were functional before the repair.
I checked for vacuum leaks with carburator cleaner and I could not find anything
The wiring harness looks to be in alright condition.
What could it be?
adam94 is offline
post #2 of 4 (permalink) Old 06-16-2009, 09:06 PM
BENZBOSS's Avatar
Vehicle: 1999 S500 1999 S420 1994 S320 1994 E320
Vacuum leak,check around ETA.Disconect the battery for 1 minute.
http://mercedes-bulgaria.com/
BENZBOSS is offline
post #3 of 4 (permalink) Old 06-17-2009, 03:14 PM Thread Starter
what is the ETA?
adam94 is offline
post #4 of 4 (permalink) Old 06-17-2009, 04:33 PM
stox's Avatar
Date registered: Dec 2004
Vehicle: 1996 C36, 1995 S500 Coupe, 1985 190E 2.3
Send a message via Yahoo to stox
ETA=Electronic Throttle Actuator. What used to be called a throttle body until it became servo controlled.
stox is offline
    M104 Timing Cover Reseal !!!HELP!!! adam94 W140 S-Class 3 06-14-2009 04:28 PM
    104 engine timing chain cover reseal procedure cpiad W210 E-Class 26 05-27-2009 04:31 AM
    1994 E320 reseal top cam/timing cover hantour W124 E,CE,D,TD Class 7 02-06-2009 02:41 PM
    timing chain allignment on a 1994 s320 er7383noc General Mercedes-Benz 0 12-22-2008 08:23 PM
    96 S320 ROUGH idle & running anhtuanle W140 S-Class 22 05-14-2008 10:55 AM
