dreaded wiring harness? 94 s350 diesel - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 03-20-2009, 08:45 PM Thread Starter
Date registered: Mar 2009
Vehicle: 1994 S350D
I bought an excellent condition S350 with 109,050 miles that now is beginning to have mutiple warning light indicators (e.g. ABS, SRS, battery indiators) come on. It is starting to run sluggish as well along with the AC not blowing cold, along with a sluggish power steering. Jointly, the cruise or rear window defogger is not working though the later two issues was purchased this way. I am reading alot about the wiring harness defects but don't know exactly where they are located. Does anyone have a photo showing these - preferably an actual photo or photo drawing (not eletrical drawing)? There is one large cable that has a part number ending in 2005 which I think is an engine harness. It starts near the air intake and loops back to the fire wall and down to the injector area. The insulators look good on it so it must of been replaced. If anyone has any guidance please share as I prefer to do this myself versus wrestle with a dealership or MB. I can't even find aftermarket harnesses. I prefer to not go through MB if they will deteriorate again.
thanks in advance
Robert
rhoadrw is offline
post #2 of 4 (permalink) Old 03-28-2009, 10:06 AM
muleears's Avatar
Vehicle: '07 E320 Bluetec, '02 Golf GL, '10 Accent GLS
Quoted: 5 Post(s)
I would like the answer to this also as I am looking at a S350D (yes, I know, rod bender). I thought the decaying harness was straightened out by '94?
Cal
07 E320 Bluetec 99K miles
10 Hyundai Accent (wife's grocery getter)
02 Golf GL Son's college car
Hampton Roads, VA, USA
muleears is offline
post #3 of 4 (permalink) Old 03-28-2009, 04:25 PM
bayhas's Avatar
Date registered: Oct 2005
Vehicle: SL55, 300SE, GL450, Daytona 955i
Quoted: 293 Post(s)
Send a message via MSN to bayhas Send a message via Yahoo to bayhas
no, not until late 95 early 96 when they changed the insulation used...
however, 1992-1995 harnesses you buy from the delaer or made after 97 as a replacement part are already using better plastic insulation.
Garage:
Mercedes-Benz, W140 S Class S320 (AKA 300SE)
Mercedes-Benz, R230 SL Class SL55 (///AMG)
Mercedes-Benz, X164 GL CLass GL450
Triumph Daytona 955i
Former Mercs:
R129 SL Class SL500 (passed on) - W163 M Class ML430 Designo (for sale) - W140 S Class 500SEL(sold) - W140 S Class S320(sold) - W140 S Class S500(sold) - W140 S Class 500SEL(sold) - W201 190E 2.3(sold)
bayhas is offline
post #4 of 4 (permalink) Old 03-28-2009, 04:36 PM
bayhas's Avatar
Quoted: 293 Post(s)
thanks in advance
Robert
All of these problems and you are considering the car to be in excellent contdition?
Anyway, the harness, as the name suggests, is a wiring harness that connects the main components of the upper end of the engine.
Best way to track it, look at the injectors, and check the condition of wires hooked up to them. thats the harness.
From the symptoms you are describing, check your battery and charging system
Garage:
Former Mercs:
bayhas is offline
    The dreaded wiring harness! dealmaker883 W124 E,CE,D,TD Class 9 07-25-2008 01:59 PM
    1992 S350 Diesel 108Benz W140 S-Class 2 02-01-2008 02:18 PM
    Should I expect to have the dreaded wiring harness problem? echandler W140 S-Class 8 01-21-2008 08:36 PM
    1993 600SEL body harness vs. wiring harness Sojourner43 W140 S-Class 6 09-17-2007 11:34 PM
    1994 s350 diesel harleyman07105 W140 S-Class 0 07-13-2005 09:36 PM
