» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W140 S-Class
Old 11-26-2008, 03:38 AM   #1 (permalink)
Haroundb's Avatar
Date registered: Nov 2006
Vehicle: Mercedes Benz W140 (300SE) 3.2L 1991 Petrol. Import from Japan with Lorinser Mod.
Harsh Shfting?
Harsh shifting without any knocking sounds. So what could that be? Will that be gear mounting? Or will it be coupling (mine is torn and needs replacement)?
Any ideas? I hope it is not the gear needs to be fully replaced.
Haroundb is offline   Reply With Quote
Old 11-26-2008, 08:38 AM   #2 (permalink)
symbolic95's Avatar
Date registered: Aug 2006
Vehicle: 1984 300sd_PanzeR,1994 s320-BehemotH,2004 e320 ...
Check Vacuum modulator at the transmission with MityVac-get metal one from Sears,not cheap plastic.
my 300sd was shifting sooo hard it felt like someone was using a sledge hammer to shift gears,took modulator out,put it back with new o-ring ,now smooth like newer before.
Don't assume ..... ,But know...
symbolic95 is offline   Reply With Quote
Old 11-26-2008, 12:48 PM   #3 (permalink)
Eirik 400 SE's Avatar
Date registered: Jan 2008
Vehicle: 1973 W115 200 /8
hmmm. Could be the same as mine.. Shifts hard into 4th..
2nd and 3rd is smooth.. Gets a little worse when warm..
Not that it's that bad.. But a little annoying ..
1991 W140 400 SE - SOLD !!
1973 W115 200
Eirik 400 SE is offline   Reply With Quote
Old 07-01-2009, 10:07 PM   #4 (permalink)
Haroundb's Avatar
What is the O-Ring?
Old 07-01-2009, 11:39 PM   #5 (permalink)
kingjoon's Avatar
Date registered: Jun 2009
Vehicle: 96 S320L
Send a message via MSN to kingjoon Send a message via Skype™ to kingjoon
Originally Posted by Haroundb View Post
What is the O-Ring?
It is the part that goes into vacuum modulator and its a ring that looks alphabet O..buy a new parts to replace it and check the pressure of transmission fluid for adjustment of your modulater valve which looks alphabet T.
for adjustment check below link;
Transmission Vacuum Modulator Adj. - Mercedes-Benz Club of America Forums
kingjoon is offline   Reply With Quote
Old 07-03-2009, 12:34 AM   #6 (permalink)
TasmanianDevil's Avatar
Date registered: Jul 2008
Vehicle: 1994 Benz S320 SWB 1986 Porsche 911 Targa
Nearly the same except for gears; when on a highway its smooth as silk, kickdowns are perfect but when warm and in traffic it jerks forward when you let go of the gas pedal a bit and let it shift up. Nothing when its shifting down though weird but still not planning to open it up and rebuild it or anything.
Changed modulator, checked hoses, everything seems fine but above mentioned conditions still presist.
TasmanianDevil is offline   Reply With Quote
Old 07-03-2009, 10:09 AM   #7 (permalink)
~BANNED~
Date registered: Sep 2004
Vehicle: 1996 S600 1991 560SEL 1995 S500 2009 S550
check temperature throttle (#117 service shop manual), located on the valve body, that is after assuming you have already done all necessary adjustments of cable and modulator valve.
cool is offline   Reply With Quote
Old 07-03-2009, 01:44 PM   #8 (permalink)
Merc600sec's Avatar
Date registered: Mar 2004
Vehicle: SEC 600 V12 2dr COUPE (RHD) One of the chosen few.
Send a message via MSN to Merc600sec Send a message via Yahoo to Merc600sec
Post
You want to explain this a bit more to this guy??
If you've GOT to have a penis extension,
Have a BIG one.
Torque isn't cheap
Merc600sec is offline   Reply With Quote
Old 07-03-2009, 06:58 PM   #9 (permalink)
~BANNED~
temp throttle is a piece of plastic valve and a super fine (thinner than human hair) spring that is used in regulating the flow of ATF in the valve body based on temperature. If the ATF temp is still cool the valve opens full and when the temperature of ATF starts to increase it regulates/partial restriction to the flow of ATF on the MAZE of the valve body. That is one of the reasons why when the temperature of your ATF is still cool you have all the normal shifting and gets rough when the temperature increase, it is a form of abnormality of the transmission and must be attended to in order to avoid other damages inside the tranny.
Another reaction towards the absence of the temperature throttle is a slow shift from 2nd to 3rd gear, there is a slight gap between shifting from this gear ratio specially when temperature of ATF is hot.
Old 07-04-2009, 02:19 AM   #10 (permalink)
Do you have a location on the car/gearbox for this ?
Or a part no at least. ?
Harsh Downgear HELP NEEDED Louie_D W126 S,SE,SEC,SEL,SD,SDL Class 6 04-17-2007 02:45 AM
harsh shifitng G7 FIFTHBENZ R171 SLK Class 20 01-26-2006 01:43 AM
ride too harsh??? asianml W163 M-Class 16 11-29-2005 08:07 AM
harsh gearchange sssammm R/C107 SL/SLC Class 0 12-24-2002 12:57 PM
Will Konis be too harsh? Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 0 02-21-2002 08:22 PM
