» Sponsors
» Sponsors
BenzWorld.org is the premier Mercedes Benz Forum on the internet. Registered Users do not see the above ads.
Old 10-08-2008, 11:55 PM   #1 (permalink)
sol
Date registered: Mar 2007
1995 Climate Control Unit part #
Folks
I have 1995 S280 RHD with a faulty LCD display on the climate control unit. Though the unit works fine I cant see the number display well and would like to replace the whole unit with a used working one.
My question is how do I know if my car came with or without the charcoal cabin filter system.
I have seen a couple part numbers for the CCU on the russian site and i found it a bit confusing.
Can someone please help me with correct part number for the CCU.
My VIN # is WDB1400282A249369
thank you.
sol is offline   Reply With Quote
Old 10-09-2008, 12:57 AM   #2 (permalink)
syljua's Avatar
Date registered: Sep 2004
Vehicle: 1998, C140, CL500
From Mercedes-Benz Club Russia | Mercedes-Benz / VIN or any other prints of the DataCard;
Code:
VIN	WDB1400282A249369
Plant	50
Model	S280
Chassis	1400282A249369
Engine	104944 22 009563
Transmission	722419 03 705409
Tyres
Primary	CONTINENTAL
Order	0 4 825 00050
Lights	BOSCH
Cab	00000
Delivery date	02.02.95
Dealer	India (825)
Interior	cloth blue (062)
Paint
149	polar white (T) (с 01.01.1992)
302	folding armrest in the rear with storage tray (с 01.01.1990)
303	front folding armrest with tray (с 01.01.1990)
341	additional lamp (с 01.09.1982)
343	air cleaner with fill level indicator for dusty environments (с 01.02.1993)
483	harder springs and undershields (с 01.01.1964 по 31.07.1996)
524	paintcoat preservation (с 01.01.1964)
538	automatic antenna and front loudspeaker - without radio set (model 500SEC with loudspeaker only) (с 01.10.1989)
613	lamp unit, asymmetrical, l.h. traffic (с 01.02.1963)
640	15-hole light alloy rims (с 01.01.1990)
668
687	model plate indicating year of construction (с 01.01.1963)
731	wood trim, burred walnut root (с 01.08.1980)
828	elimination of exhaust emission control system (cat) (for r 129 only) (с 01.02.1988)
catalyst coating - deletion
883	closed aid for doors and trunk lid (с 01.07.1989)
884	trunk lid additional locking mechanism (hzs) (с 01.10.1989)
987	battery cut-off switch for vehicles to be shipped (с 01.02.1993)
It does not seem that you have the charcoal filter. A sure sign will be
the intake on hood. If you have slats in the the hood in front of the wipers,
you have charcoal. If not, you don`t.
Since you have the "343 air cleaner with fill level indicator for dusty environments (с 01.02.1993)", I guess that the climate and dust in India would have put
too large strain on the charcoal filter, which is supposed to filter out much smaller
exhaust particles.
Now, for you part number;
Каталог
I do not know which type of CCU you have, but from the notes on the parts,
we see that from the old type, 6;
1408300885 UP TO IDENT NO.: A 074422
1408302085 FROM IDENT NO.: A 074423 and UP TO DATE: A 290166 EXCEPT CODE 806 ALSO INSTALLED IN VEHICLE FROM A 290167 WITH CODE 805
The next version, part 7, says;
1408302385 860 FROM DATE: A 290167 EXCEPT CODE 805 ALSO INSTALLED IN VEHICLE TO A 290166 WITH CODE 806
Since your car is A249369, you should look for; 1408302085
Charcoal or not, is a separate button for the cars with that CCU (part 6).
br,
syljua
C140 CL500 1998
W123 230E 1984
syljua is offline   Reply With Quote
Old 10-09-2008, 03:33 PM   #3 (permalink)
sol
thank syljua for your help. much appreciated.
1995 E320 Climate Control klavinfrye W210 E-Class 9 04-12-2008 03:59 AM
1995 E320 Climate Control klavinfrye W124 E,CE,D,TD Class 0 04-11-2008 08:16 AM
Climate control 1995 420E Glenn S W124 E,CE,D,TD Class 4 11-29-2006 05:37 AM
Part # for 1996 S500 Climate Control Unit atz06 W140 S-Class 2 11-14-2005 11:56 PM
1995 E320 climate control help pblank General Mercedes-Benz 3 07-12-2005 04:34 PM
