Do the w140 sedans have foglights??? - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 08-06-2008, 01:50 PM Thread Starter
tommyb2b's Avatar
Date registered: Sep 2006
Vehicle: Artic White 1995 S420
Send a message via AIM to tommyb2b Send a message via MSN to tommyb2b Send a message via Yahoo to tommyb2b
Question Do the w140 sedans have foglights???
I was under the hood replacing a fuse and I notaced that there is no fuse where it says fog lights. You can pull the dial inside the car towards you and an orange light comes on but I never figured out what that actully did. So does it have fog lights or is that only for the coupe?
tommyb2b is offline
post #2 of 12 (permalink) Old 08-06-2008, 01:53 PM
stox's Avatar
Date registered: Dec 2004
Vehicle: 1996 C36, 1995 S500 Coupe, 1985 190E 2.3
Send a message via Yahoo to stox
On the sedan, the fog lights are built into the side of the headlight assembly. On the coupe they are below the bumper.
stox is offline
post #3 of 12 (permalink) Old 08-06-2008, 02:07 PM
Premium Member
dlafever's Avatar
Date registered: Jan 2004
Vehicle: 2002 ML320, 2001 E430
Quoted: 54 Post(s)
Premium Member
Send a message via AIM to dlafever Send a message via Yahoo to dlafever
On the later US W140s late '95-on, the foglight is below the headlight in the headlight housing, the high beam is where the foglight was on the early models.
dlafever is offline
post #4 of 12 (permalink) Old 08-06-2008, 04:50 PM
W140FTW's Avatar
Date registered: Nov 2007
Vehicle: 1999 Mercedes Benz S320 Long Wheelbase.
Send a message via AIM to W140FTW
Yep, it's in the housing, below the low beams. On the sedans, if you pull the headlight switch out one click, it engages the front fog lamps, two clicks and it's the rear fog also.
W140FTW is offline
post #5 of 12 (permalink) Old 08-06-2008, 05:05 PM
z168's Avatar
Date registered: Oct 2005
Vehicle: M62
Quoted: 86 Post(s)
can you clarify this
"the foglight is below the headlight in the headlight housing" ?
Deutsche Tourenwagen Meisterschaft
z168 is offline
post #6 of 12 (permalink) Old 08-06-2008, 06:37 PM
bayhas's Avatar
Vehicle: SL55, 300SE, GL450, Daytona 955i
Quoted: 298 Post(s)
Send a message via MSN to bayhas Send a message via Yahoo to bayhas
you are describing Euro spec headlight...
Garage:
Mercedes-Benz, W140 S Class S320 (AKA 300SE)
Mercedes-Benz, R230 SL Class SL55 (///AMG)
Mercedes-Benz, X164 GL CLass GL450
Triumph Daytona 955i
Former Mercs:
R129 SL Class SL500 (passed on) - W163 M Class ML430 Designo (for sale) - W140 S Class 500SEL(sold) - W140 S Class S320(sold) - W140 S Class S500(sold) - W140 S Class 500SEL(sold) - W201 190E 2.3(sold)
bayhas is offline
post #7 of 12 (permalink) Old 08-06-2008, 09:21 PM
dmac_S500's Avatar
Date registered: Jan 2007
Vehicle: 1998 S500
Since this was new to me, I had to check it out on the car. Plus I wanted to know what the heck a rear fog light would look like!
The fronts work as described in the earlier post - no surprise there.
The rear was not easy to see at first as it is just a brighter addition to the normal tail light. I did determine that the bulb is out on one side but was not detected by the bulb monitoring system. So now I have to figure out what replacement bulb type is required.
Always something new with these cars!
Now I just need to wait until next November for a foggy night to try them out for real.
dmac_S500 is offline
post #8 of 12 (permalink) Old 08-06-2008, 10:05 PM
stox's Avatar
If you're thinking you have a bulb out because the rear fog was only on one side, stop. That is the proper mode of operation.
stox is offline
post #9 of 12 (permalink) Old 08-07-2008, 03:11 AM
bobs's Avatar
Date registered: Dec 2007
Vehicle: '97 S320 (LWB), '01 E320
Obviously some folks need to spend a little quality time with their owner's manual. So, to sum up:
-- The front fog lights are built into the headlight assemblies on sedans and under the front bumper on coupes.
-- The rear fog light is inside the driver's side tail lamp.
-- To activate, pull out on the headlight switch. The first detent activates the front fog lights, the second detent activates both front and rear fog lights.
-- The orange indicator on the switch indicates that the rear fog light is on.
Other neat things:
-- If the exterior lights were used during the drive, the front fog lights illuminate for 30 seconds after the last door has been closed.
-- There are two positions to the left of "off" on the headlamp switch. These activate the standing lamp feature, which illuminates the parking lights on either the left or the right side of the car.
Also, if you don't have an owner's manual any more, you can probably find an electronic copy here: http://bayhas.com:8080/w140manu/
"It's not about how fast you can go, but how well you can go fast."
'97 S320 (LWB), Ruby Red Metallic/Tan, 75k miles
'01 E320, Black/Charcoal, 105k miles
Gone but not forgotten. . .
'97 S420V, Smoke Silver Metallic/Tan, (RIP 22 Oct 2012, 178627 miles) He gave his life to save mine.
bobs is offline
post #10 of 12 (permalink) Old 08-07-2008, 11:17 AM
Premium Member
dlafever's Avatar
Quoted: 54 Post(s)
Premium Member
Actually this is the US version. Early US headlights had a yellow foglight inboard (toward the grille) and low/high beams in the main part of the housing. They also used the extremely crappy 9004 bulb which has a short filament that is perpendicular to the bulb glass, resulting in VERY short throw for the lamp.
The later models (late '95-on) had the high beam where the foglight was and the low beam with a new bulb that had much higher throw because the filament is parallel to the long portion of the bulb glass and could take advantage of a more complex reflector. The fogs are in the main housing below the low beam.
The Factory Xenon also had this late-style design, but the lens is slightly different.
See the pics for the early v. late.
dlafever is offline
    FS: Mercedes S550 foglights (2 pairs). MB GL foglights (1 pair). E500 A/C compressor. RomanK For Sale/Wanted/Trade/Giveaway 18 03-02-2012 10:06 AM
    Sedans iNeon Off-Topic 13 03-13-2008 09:53 AM
    Mileage wagons VS sedans DieselKraut W123 E,CE,D,CD,TD,TE Class 15 01-24-2007 11:01 AM
    How much change can I expect of '07 C Class sedans? I Never Pay W203 C-Class 18 12-15-2005 03:52 PM
    New C230 sedans..Is there anything for it? BenZc230 W203 C-Class 1 01-21-2004 01:26 PM
