» Site Navigation
» Other Sites
Old 07-21-2008, 02:42 PM   #1 (permalink)
Vehicle: Mercedes-Benz S320
Post 94 S320 Rough Idle / Black Smoke
Hello Guy's,
My 94 S320 was running great! A couple of weeks ago, I went to the service station to get fuel, and approximately 3 miles down the road it started rough idling at the light. I replaced the Spark Plugs & Fuel Pump Relay. I had the car checked out by my buddy whom services MBZ's (but he doesn't have all the test gauges/etc). He checked the fuses & Fuel Pump Pressure (it checked out at around 50 lbs) & temporarily disconnected the Mass Air & Oxygen Sensor - and they all checked out. My car is still revving up-and-down when idling & black smoke is still being emitted. Also, my car now gets about 7 miles per gallon - when it should be getting around 20.
What do you think the problem might be? Coils? Spark Plug Wires? Injectors? ECM?
Let's hear your input..................... Thanks!
BigBruce is offline   Reply With Quote
Old 07-21-2008, 03:15 PM   #2 (permalink)
symbolic95's Avatar
Date registered: Aug 2006
Vehicle: 1984 300sd_PanzeR,1994 s320-BehemotH,2004 e320 ...
Originally Posted by BigBruce View Post
Hello Guy's,
How is your engine wiring harness?Brittle?
Don't assume ..... ,But know...
symbolic95 is offline   Reply With Quote
Old 07-21-2008, 03:52 PM   #3 (permalink)
Post
Hi Symbolic!
Like most, my mechanic says that it will need replacing when we do the head gasket. Hopefully, this problem is not harness related. What do you guy's think?
Old 07-21-2008, 06:05 PM   #4 (permalink)
symbolic95's Avatar
Hi Symbolic!
Well,i was told that none of the shops that knows about wiring harness problem ,do the tune up,or even touch W140 with a ten foot pole ,if wiring harness wasn't replaced.
Just take a look at the sensors,cut your MAF insulation ,prepare to be shocked.
Old 07-21-2008, 06:24 PM   #5 (permalink)
So true, So true. I'm going to have the harness & head gasket replaced in a couple of weeks. Does anyone know the MBZ part# for the engine harness & the most cost-effective place to purchase one ??
Thanks!
Old 07-21-2008, 06:39 PM   #6 (permalink)
chuckindetroit's Avatar
Date registered: Jun 2003
Vehicle: 1986 560SEL, 1986 560SEL, 1992 500SEL
You might check out the fuel pressure regulator. If the diaghram goes bad it can force raw gas into the intake manifold bypassing the injectors and fuel management. I had a similar issue and the $35 regulator was the problem. Do a search on pressure regulator.
chuckindetroit is offline   Reply With Quote
Old 07-21-2008, 08:38 PM   #7 (permalink)
symbolic95's Avatar
Select Brand
Remember,that starter harness also has to be replaced,plus i would suggest you to rewire ETA.
scrapingscrap and JonathanWallin made posts on their rewiring,
http://v12uberalles.com/throttle_actuator_rewire.htm
http://www.benzworld.org/forums/w140...wont-go-5.html
Old 07-21-2008, 09:51 PM   #8 (permalink)
Post
Chuck, the Fuel Pressure Regulator was just replaced with a new Bosch unit.
The car still rev's up-and-down when idling.
Old 07-22-2008, 10:56 PM   #9 (permalink)
Here's the Winner(or in my case, loser). The engine wiring harness needs replacing. Mercedes-Benz should be CLASS-ACTION SUED for the B.S.
Engine Harnesses from 1991 to 1996 (all models) that were installed!
86 300e running rough and black smoke after warm up dwmoss31 W124 E,CE,D,TD Class 3 05-16-2008 04:28 AM
96 S320 ROUGH idle & running anhtuanle W140 S-Class 22 05-14-2008 10:55 AM
ROUGH IDLE, IDLE CONTROL UNIT LOCATION, TIMING & RPM verdejor General Mercedes-Benz 5 01-22-2006 08:41 PM
1983 500SEL EURO High Idle and black smoke powder comes out of exuast georgebenz04 W126 S,SE,SEC,SEL,SD,SDL Class 2 04-04-2005 12:41 PM
'95 300D Rough Idle, Smoke tirebiter W124 E,CE,D,TD Class 3 12-31-2004 09:01 AM
