Old 07-13-2008, 07:19 AM   #1 (permalink)
Date registered: Jul 2008
Vehicle: Changes weekly
Send a message via AIM to aubs
Need some technical help on a 1993 500SEL
I have done a few searches, but have been unable to come up with the answers I'm looking for.
I have a 1993 500SEL, and the speedometer, odometer, trip odo, and MPG meter are not working. I also am showing the ABS and ASR caution lights on the dash. Is there a possible connection or single point of failure connecting all of these? I read that it could possibly be the left front wheel speed sensor, or perhaps the over voltage fuse (which I cannot locate).
I should mention that the odometer and trip odo are both displaying a value, but neither are increasing. All other lights and gauges in the cluster are working as well.
This is less important, but I am unable to use the functionality of most of the A/C system buttons. Do they tend to wear out over time or become dirty? The system works, so I guess I shouldn't complain...
Finally, I was wondering if an OBD I sensor would be able to read the codes from the computer.
Thanks in advance,
Aubrey
Ps The vehicle is also for sale $5,499.
aubs is offline   Reply With Quote
Old 07-13-2008, 08:23 AM   #2 (permalink)
Here's a picture of the car. I just buffed out the whole body, and was surprised by how well the chrome polished up.
Aubreys Auto LLC (717) 273-3896
Mercedes and parts for sale. Give me a call.
Old 07-13-2008, 12:21 PM   #3 (permalink)
drcharlesatlas's Avatar
Date registered: Apr 2007
Vehicle: 1989 190e 2.6 1993 500sel
When the ABS and ASR lights are on does the car drive in the Limp Home Mode?
drcharlesatlas is offline   Reply With Quote
Old 07-13-2008, 01:15 PM   #4 (permalink)
Opps, I should have mentioned that.
No, it does not appear to drive any differently than I would expect it to. I have a stone lot, and I was able to get the rear wheels to spin out a bit, so I am assuming that LHM is not active.
Old 07-15-2008, 06:18 AM   #5 (permalink)
Bump.
Old 07-15-2008, 07:49 AM   #6 (permalink)
jhodg5ck's Avatar
Date registered: Sep 2002
Vehicle: 1991 560 SEC
Send a message via AIM to jhodg5ck
I would check the condition of your wiring harness to start.. I'd also recomend getting a hold of the Service DVD... One NEEDS some direction when DIY'ing a 140..
The clusters are known for problems as an aside, and the push button units do wear out with time. HAven't had much luck cleaning them.
Is the car @ all hard to start?
This is Mercedes version of ODB...check out K6JRF Auto Page
to learn about code reading.
Jonathan
Blue Ridge Mercedes/AMG East (temp down!)
Offering Enthusiast Service, Restoration and Tuning.
Providing quality parts to all parts of the world.
Located in the Atlanta area
96 S600 Euro
91 560SEC ECE (for sale)
91 560 SEC 226/271 Undergoing TT conversion
89 190E 2.6 5sp
89 300TE (Mosselman TT waiting..)
88 560SEC AMG Euro ECE (parts)
89 560SEC AMG mech. lifter/68K rpm conv.
87 Hammer 6.0L 32V
86 560SEL AMG 6.0L 32V
jhodg5ck is online now   Reply With Quote
Old 07-15-2008, 10:46 AM   #7 (permalink)
Jonathan
Thank you very much for the information.
The car starts well but idles a little rough for about 30 seconds to 1 minute; I suspect this could be a cold air sensor, MAF, etc.
If these cars sell (I think they will at the insane pricing... ) I will probably get more. Do you know where to find the service DVD? Is MB the best place to go, or are there reputable aftermarket places?
Thanks,
Aubrey
Old 07-15-2008, 11:41 AM   #8 (permalink)
jhodg5ck's Avatar
The early 140's (esp the V8's) are insanely cheap right now.. Typically because the owners have let things go a bit and nothing is more daunting $$ wise then bringing a 140 back in line!
The rough idle could be a Bunch of things..but if you have multiple lights on the cluster I'd start by inspecting the harness..if it shows any signs it Needs replacement before you do anything else.
I have the DVD's available:
Blue Ridge MB and AMG East Service Manuals/Items
Jonathan
Old 07-15-2008, 12:28 PM   #9 (permalink)
Date registered: Mar 2004
Vehicle: 1997 S600 sedan
It has been reported here that similar symptoms to yours have been caused by a blown fuse in one of the computer modules. You might check it out.
http://www.benzworld.org/forums/w140...nt-things.html
Brett
Brett San Diego is online now   Reply With Quote
Old 07-15-2008, 12:36 PM   #10 (permalink)
The ABS speed sensor is above and attached to the strut mount on the rear right. You can access it by prying out some of the trunk cladding in front and to the left of the fuse
holder. Maybe your sensor wire has come loose or the sensor is shot. Take a look. Could be a single point of failure.
1993 500SEL Help mbz500 W140 S-Class 4 07-17-2007 05:24 PM
1993 s500/500sel cesar california W140 S-Class 8 02-22-2007 07:03 AM
1993 s500/500sel cesar california General Mercedes-Benz 2 02-21-2007 01:55 PM
1993 500sel DaveR W140 S-Class 7 12-06-2006 10:43 PM
1993 500SEL is finally done! 93500sel W140 S-Class 9 05-22-2006 02:40 PM
