hi guys
I was troubleshooting my passenger close assist on the coupe, thought I share some of my findings, and pick your brains about some other stuff
I have read Brett's excellent write up (Thanks B.), and here are some coupe specific differences
The Coupe pump does not have the air nipples for the back door at all .. They are sealed shut at the base from the factory. Also the wiring harness is different
Here is the harness colour code:
PINOUTS: (written at the back of the plug - numbered 1-10)
1 - blank
2 - YELLOW/WHITE - supposed to be for LR door (blank on the coupe)
3 - blank
4 - Green (LF door)
5 - BROWN/GREEN - Pneumatic Ctrl Module
6 - RED/YELLOW - Power (HOT when ignition on)
7 - BLUE - supposed to be for RR door (blank on the coupe)
8 - BLUE/YELLOW - RF door
9 - Black - Power (HOT at all times)
10 - BROWN - ground
there appears to be no wires for the trunk lid, trunk door handle microswitches going into this pump, although there are vac lines for it, so again I am not sure how it gets the electrical signal... and my trunk lid and handle soft close both work.
now here's a doozy ..
my LF door (driver's) works well .. so I wanted to see how the microswitch behaves .. but there is no difference in continuity or voltage when door is open/shut
When I pulled the pump out of the trunk, I noticed that the RF vac line was severed .. fixed it and reset the fuse thinking my door would now work, but nothing .. the pump does not even run after the reset which makes me think it's the RF door microswitch. But there are only 2 door switches as far as I know ..
*one on the outside that controls the inside lights/annoying buzzer
*one inside that controls the windows dropping 0.5" when door is opened (and that works)
There is no change in continuity at the pump with the door opened/closed even on the door that works, so I am somewhat stumped s to how the pump knows the door is opened/closed???
any thoughts would be appreciated.
