Old 07-08-2008, 01:01 AM   #1 (permalink)
Date registered: Dec 2007
Vehicle: 560SEC 1987 / 280SE 1967
ASR ligth stay ON
i have a big problem with my w140 600SEL 1991, the ASR ligth is ON permanent?
what is the problem, and is it possible to desactive this device ?
thank you for your help
My560SEC is offline   Reply With Quote
Old 07-08-2008, 07:17 AM   #2 (permalink)
drcharlesatlas's Avatar
Date registered: Apr 2007
Vehicle: 1989 190e 2.6 1993 500sel
You do not say if the car is driving in the Limp Home Mode with the ASR light on.
No, it is not possible to deactivate the ASR mode.
If you are not driving the car in the LHM and the light is on just cover the light with a piece of black scotch tape.
If you are driving in the LHM with the ASR light on, then you have possibly big and expensive problems and repairs.
The ASR problem is sometimes attributed to a bad brake light switch which is tied into the ASR--a simple fix; otherwise in these drive-by-wire cars the cause of the problem can be just about anything.
Good luck!
drcharlesatlas is offline   Reply With Quote
Old 07-08-2008, 12:04 PM   #3 (permalink)
the car drive in LHM mode
this is a big problem and very expensive, i know.
do you say ; the probably problem is with the wiring engine ?
Ligth Sensor Failure wadoline R171 SLK Class 4 02-25-2008 01:51 AM
back up ligth harnnes Kuzuki G-Class 7 02-08-2005 09:57 AM
srs ligth lauritor W210 E-Class 2 09-23-2004 09:42 AM
Replace Bulb of Brake Ligth? SauLV W202 C-Class 2 09-02-2004 08:58 AM
ABS /ASR Lights stay on curtdog23 W140 S-Class 0 08-05-2004 06:08 AM
