Old 07-03-2008, 10:40 PM   #1 (permalink)
Date registered: Jan 2007
Vehicle: 1997 S420 55K, 1994 E320 Cabriolet 13K
Sun sensor faulty
Is the sun sensor hard to replace? - does it just pop out and plug into a harness? Is it a frequently failing part? I know it doesn't really do much except vary the blower speed a little bit since I have a fault code for it I am curious about how to replace it. Thanks
JohnMichael is offline   Reply With Quote
Old 07-03-2008, 10:44 PM   #2 (permalink)
Vehicle: 1993 300SEL/S320
Whats the sun sensor? Are you sure your not talking about the fan speed regulator?
NZ Benz is offline   Reply With Quote
Old 07-03-2008, 11:16 PM   #3 (permalink)
It is on the dash in the middle right next to windshield it senses heat (from the sun) and varies the blower speed to compensate for increased air temp above dash. think it was a 1995 and later sensor. just another MB example of over engineering - really doesn't do much except speed up the fan instead of waiting for the inside temp sensor to sense temp and adjust the fan speed. It shows up frequently as a fault code when testing for AC codes.
Old 07-04-2008, 09:50 AM   #4 (permalink)
S500L's Avatar
Date registered: Aug 2003
Vehicle: S 500 L
It is very easy to replace (the sun sensor). Just pop up, unplug and replace. You have to later reset the codes at the A/C.
The sun sensor tends to fail often in some 140s, in others it works fine forever. It is just luck.
A. R. R.
S 500 L, 1998
E 320 T, 1995
S500L is offline   Reply With Quote
Check engine: 02 sensor + EGR faulty peyton300td W124 E,CE,D,TD Class 2 04-21-2008 12:28 PM
Not faulty transmission but bad sensor !! Steve (Austria) W164 M-Class 0 10-23-2007 12:58 PM
BAD SUN SENSOR KADE W210 E-Class 2 06-15-2007 09:55 AM
Sun sensor? notorious ALE W210 E-Class 0 09-29-2006 01:25 PM
Sun Sensor placement Ivarx W208 CLK Class 0 08-24-2005 11:43 PM
