94 - 99 S320 Tune-Up Instructions/Guide?? - Mercedes-Benz Forum
post #1 of 24 (permalink) Old 07-03-2008, 07:28 PM Thread Starter
Vehicle: Mercedes-Benz S320
Hey Guy's!
This forum is always - and WILL continue to be THE BEST for W140 Owners !!
Hey - where are the instructions/illustrations/pics with step-by-step instructions(website?) for replacing the Spark Plugs, Wires, Coils, and Distributor Cap/Rotor for the S320 ??
Thanks! ................... You're the BEST!
BigBruce is offline
post #2 of 24 (permalink) Old 07-04-2008, 07:48 AM Thread Starter
Originally Posted by BigBruce View Post
Hey Guy's!
BigBruce is offline
post #3 of 24 (permalink) Old 07-04-2008, 08:55 AM
symbolic95's Avatar
Date registered: Aug 2006
Vehicle: 1994 s320
If you really need instruction on spark plugs i can get it done tomorrow with pix .
Don't assume ..... ,But know...
symbolic95 is offline
post #4 of 24 (permalink) Old 07-04-2008, 10:14 AM Thread Starter
Smile
Good Deal, Symbolic! Tomorrow is when I'll perform this maintenance.
You'd think there would be a website somewhere on earth with this procedure. I do know of the member whom refers to a website with step-by-step instruction/pix, but it's for the S600.
Big_Bruce
BigBruce is offline
post #5 of 24 (permalink) Old 07-04-2008, 10:30 AM
Date registered: Mar 2004
Vehicle: 1997 S600 (sold)
Quoted: 12 Post(s)
Hey Guy's!
What year S320? 95 and earlier is different from 96 and later. 95 and earlier have a distributor with cap and rotor and, I think, just 2 ignition coils (or is it only 1). 96 and later is fully electronic ignition with no distrbutor, 6 ignition coils located right on top of each of the spark plugs, and no traditional spark plug wires that you would normally replace as part of routine maintenance. A "tune-up" on 96 and later is pretty much just a spark plug change. There is nothing to "tune."
The V12 spark plug change write-up that is on v12uberalles.com, which I wrote, is for 96 and later cars. Spark plug change on a 96 and later S320 will be identical in operation, just a little different with regard to location of things.
Brett
Brett San Diego is offline
post #6 of 24 (permalink) Old 07-04-2008, 11:02 AM Thread Starter
Brett
Hi Brett! I have a '94 S320. I'm assuming that it has a cap & rotor. Won't know until I jump into the maintenance tomorrow(Saturday).
BigBruce is offline
post #7 of 24 (permalink) Old 07-04-2008, 11:50 AM
symbolic95's Avatar
Vehicle: 1994 s320
Ok this diagrams for you.I'm at work right now,if you need more info,let me know il'll snap some pictures.
One thing when you will be installing new plugs ,get yourself rubber hose that fits on the top of the plug( i got one from Autozone $1,ask for a rubber hose,about 10".)
It is for "threading" the plug,this way you will go gentle and wont ruin the thread in the head,i also use gray anti seez paste .
94 - 99 S320 Tune-Up Instructions/Guide??-plug.jpg
And one more, watch that torque!!!
Service and Repair
PRECEDING WORK
Before removing the spark plugs, the Intake air cross pipe must be removed.
This component must be reinstalled after replacing the spark plugs.
94 - 99 S320 Tune-Up Instructions/Guide??-42165462.gif
Spark Plug Replacement
REMOVAL
Turn ignition OFF.
Unclip cable duct (12).
Remove cable duct cover (5/1).
Remove guide rail (5/2).
Remove spark plug connectors (arrow).
Remove ignition coils with wires attached (T1/1, T1/2, T1/3).
Clean out recesses with compressed air.
Clean and inspect ignition cables.
Remove spark plugs (R4).
Ignition Coil
94 - 99 S320 Tune-Up Instructions/Guide??-coil.jpg
INSTALLATION
Adjust spark plug gap to: 0.8 mm (0.031 in)
Install spark plugs and torque to: 25 - 30 Nm (18.5 - 22.1 ft.lb.)
Install ignition coils. Guide pin (W) must have good connection to chassis ground.
T1 = Ignition coil.
Ta = Terminal direct to spark plug.
Tb = Terminal to ignition wire.
W = Ignition coil ground.
Ignition Wire Schematic
post #8 of 24 (permalink) Old 07-04-2008, 01:22 PM
Date registered: Oct 2006
Vehicle: 2013 Smart Fortwo... does that count? :)
Quoted: 2 Post(s)
I'm probably going to do this tomorrow, but i hesitated before buying spark plugs because i want to make sure i'm getting the best...
I was looking at Platinum 2's by Bosch but they have other plugs like Platinum +4 and the "Ir Fusion"...
What is the best plug to use? I am not looking for fuel economy, but the best possible spark/combustion possible.
Matt
1996 C220... aww yeah, base model!
mgill85258 is offline
post #9 of 24 (permalink) Old 07-04-2008, 02:37 PM
symbolic95's Avatar
Vehicle: 1994 s320
look at the post vvee12 did,when he had his plug thread stripped ,there is discussion of the plugs. I was suggested to use only plugs that were designed for your engine - single electrode and i think it was copper.
post #10 of 24 (permalink) Old 07-04-2008, 02:58 PM Thread Starter
Attachment 185206
Service and Repair
PRECEDING WORK
Attachment 185201
REMOVAL
Turn ignition OFF.
Ignition Coil
Attachment 185202
INSTALLATION
T1 = Ignition coil.
Attachment 185203
Great Job, Symbolic! When you remove the spark plug connectors, do you just pull them up with force via hand? Also, is there a Distributor Cap & Rotor ?? Autozone said for a '94 S320..... NO.
BigBruce is offline
    ML 430 Tune up instructions jrome74 W163 M-Class 4 07-08-2007 06:02 AM
    Who can i get to tune my G? Who will tune for the most HP...could this be REALLY bad for engine? sceaton G-Class 2 03-19-2006 07:25 AM
    What happens at a tune up? Hopeless W126 S,SE,SEC,SEL,SD,SDL Class 1 01-25-2006 04:40 PM
    Doing your own tune-up Prochambers W126 S,SE,SEC,SEL,SD,SDL Class 6 05-11-2004 08:39 AM
    Tune Up Guest (MBNZ) W124 E,CE,D,TD Class 3 06-26-2002 01:12 PM
