I'm guessing you want to get rid of the entire door inner as one, if not, do you still have the left rear door speaker grille?
~ 1996 S320 ~
19" carlsson/lowered/crystal LED tails/crystal LED side markers/crystal indicators/S600 walnut steering wheel/S600 grille/anthracite black interior/sunroof
I'm gonna pass on the rear differential since I live in Kansas...Do you still have the A/C control module that is located behind the glove compartment?
I have an issue with the A/C, blows cold air from the center vents and warm air from the sides, I had my mechanic look at it and he said that I need the A/C control module (control flaps!!) which is located right behind the glove box...Let me know please if both parts means the same.
I had the same problem, does you central locking work? I pressed the blue switch off so both would not be lit(red l.e.d) & only then I got all blowing cold
