96 S320 ROUGH idle & running - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W140 S-Class
Old 04-28-2008, 06:49 PM   #1 (permalink)
Date registered: Oct 2007
Vehicle: 1996 S320
symptoms: really rough idle, needle jumping from 500-1200 rpm even during a slow crawl, sometime's almost dying. i replaced the egr valve, seemed to run a WEE bit better, but symptoms showed up again. ran the engine, disconnected the MAF sensor and the engine got worse, so looks like that isn't the culprit. i'm hearing a really soft electric-like sound coming from underneath the passenger-side back seat, that coincides with the reduction in rpm, kindof like an acutator trying to do something ???
i connected an obdII reader, but no codes showing up. what else can i do? i bought new spark plugs, since the car has 87k miles, and it's time for a tune-up. also changed the air filter today. i haven't changed the fuel filter yet.
please help!!
anhtuanle is offline   Reply With Quote
Old 04-28-2008, 06:59 PM   #2 (permalink)
symbolic95's Avatar
Date registered: Aug 2006
Vehicle: 1994 s320
Post
Well , i still have the same symptoms even after rewiring ETA .
Do you know someone with m104 engine ,to borrow MAF sensor and see if its gonna help?
But i tell you,wires in ETA were bare,i could not trace them with Ohm meter ,to rewire,I had to do one by one,instead of just drawing diagram,and just cutting them.
Yours is 96,so check your MAF wiring first,before digging into ETA,check Jonathan Wallin posts.
Don't assume ..... ,But know...
symbolic95 is offline   Reply With Quote
Old 04-28-2008, 07:10 PM   #3 (permalink)
Vehicle: 1996 S320
thanks.
i also forgot to add....
the rubber hose connected to the EGR valve, should that have a strong vacuum? i notice little to no vacuum when i disconnected it with the engine running.
Old 04-28-2008, 07:30 PM   #4 (permalink)
symbolic95's Avatar
Vehicle: 1994 s320
I use MityVac and 5 bars was enough to cause engine go nuts.
Anhtuanle ,can you do me a favor ,after i rewired my ETA ,its running constantly you turn the key to illuminate all lights,but dont start,and i hear this buzzing noise from ETA,sounds ,like motor is running all the time ,yo can hear it with hood open,I dont know if it was running like that before ,can you check your car and let me know if you hear noise coming from ETA ,I put my ear where air intake is going into the ETA.
Thanks.
Old 04-28-2008, 07:40 PM   #5 (permalink)
Vehicle: 1996 S320
will do. i'll have to wait to check tomorrow evening.
Old 04-28-2008, 07:45 PM   #6 (permalink)
symbolic95's Avatar
Vehicle: 1994 s320
Post
thanks,will wait for the result.
Old 04-28-2008, 09:29 PM   #7 (permalink)
HUF
Date registered: Nov 2007
Vehicle: Looking for V8 W140
Originally Posted by anhtuanle View Post
thanks.
The vacum hose to the EGR valve comes from the EGR solenoid. The EGR is disabled at idle, so the solenoid should not provide any vacuum to the EGR valve. Please correct me if I am wrong, but that's how the EGR system works on Cadillacs. Should be same on a Benz I guess.
HUF is offline   Reply With Quote
Old 04-29-2008, 03:34 PM   #8 (permalink)
Vehicle: 1996 S320
hey symbolic95, looks like your rewire is ok. i can hear the eta running when the key is in the on position, but the engine isn't running.
Old 04-29-2008, 04:59 PM   #9 (permalink)
symbolic95's Avatar
Vehicle: 1994 s320
Post
thanks man , now i can sleep well,but not idle
i'll try to trace the vacuum and see if its leaking ,will keep you posted
BTW welcome to the forum
Old 05-01-2008, 12:03 AM   #10 (permalink)
Premium Member
bayhas's Avatar
Date registered: Oct 2005
Vehicle: SL500, 300SE, ML430, Saturn SCX 1.9L DOHC.
Premium Member
Send a message via MSN to bayhas Send a message via Yahoo to bayhas
did you rewire YOUR ETA? or did you swap it on core exchange basis? if the throttle is replaced, you need a STAR scanner to code it to the PCM.
If you post to ask "is the car worth the repair?", get rid of your 129/140 and go buy a 2013 Corolla... Classic Benz is not an investment for you...
Mercedes-Benz, W140 S Class S320 (AKA 300SE)
Mercedes-Benz, R129 SL Class SL500 (AKA 500SL)
Mercedes-Benz, W163 ML Class ML430 (Designo Edition)
Triumph Daytona 955i - SSSA
Former Mercs: W140 S Class 500SEL (sold) - W140 S Class S500 (sold) - W140 S Class 500SEL (sold) - W201 190E 2.3 (sold)
bayhas is offline   Reply With Quote
Bookmarks
c280. running rough idle. akin W202 C-Class 12 11-09-2010 04:45 PM
Rough idle and running - fixed. shrimpton W126 S,SE,SEC,SEL,SD,SDL Class 11 06-17-2010 01:03 PM
Rough idle/running rich ScottinSoCal R/C107 SL/SLC Class 46 11-07-2009 04:32 AM
Intermittent rough running/idle catboy W202 C-Class 0 01-31-2005 03:55 AM
SLK320 rough running at idle pboland R170 SLK Class 5 08-12-2002 05:37 PM
