» Site Navigation
» Other Sites
Old 05-11-2008, 12:19 PM   #11 (permalink)
Date registered: Apr 2008
Post Diagnosis
Gents,
I have just received a diagnostic report from the Mercedes independent garage in relation to the idle, below is what was diagnosed.
1. Computer check - several codes, but apparently no problem came out from the computer.
2. I was told they manually inspected the car and they recommended that the following parts be changed:
a. induction hose,
b. inlet manifold gaskit,
c. T.C gaskit x2, and
d. actuator gasket x2,
Also, was told that the following are the parts (part numbers in brackets) that will be required:
a. C.Y head cover gasket (part no. A120 010 01430),
b. gasket (A120 141 0280),
c. gasket (A104 141 0780),
d. pipe (A1200 102070),
e. hose (181382),
f. breather pipe (2532), and
g. engine pipe (3212)
The work has been estimated (parts and labour) to be around $936. However, they don't know if it will solve it 100%.
Should I get a second opinion?
Any help appreciated.
Thank you all in advance.
saleem3 is offline   Reply With Quote
Old 05-11-2008, 06:05 PM   #12 (permalink)
bayhas's Avatar
Date registered: Oct 2005
Vehicle: 300SE 3.2L DOHC, 190E 2.3L SOHC, Saturn SCX 1.9L DOHC.
Send a message via MSN to bayhas Send a message via Yahoo to bayhas
Originally Posted by saleem3 View Post
Gents,
a. induction hose,
e. hose (181382),
if they are not 100% sure these parts will solve the problem, why are they thinking they need replaced?
timing cover gasket does not cause the engine to misfire, but causes an oil leak. is your car leaking oil?
he found codes? what are they?
valve cover gasket is the same way, the M119 and M120 are not sealed engines, and a leak in the upper section (valve compartment area) does not cause misfire like in BMW.
my opinion is this mechanic is experimenting in you, your car has 10000 miles, so the gasket didnt get enough heat to crack.
Mercedes-Benz, W140 S class 300SE
Mercedes-Benz, W201 190E 2.3 Stock
1996 Saturn SC1 + 95 DOHC head + 96 camcover + 98 Vsprings + 02 block + 00 crank + 91 header + 01 MP2 = SCX - Soon to be turbocharged.
bayhas is offline   Reply With Quote
Old 05-12-2008, 02:51 AM   #13 (permalink)
Bayhas, thank you for the prompt reply.
The car does not leak any oil.
I have my suspicions about the mechanic. Anyway, I will scan a copy of the computer report by this afternoon and I should appreciate if you would kindly let me know what you think.
Regards,
Saleem
Old 05-14-2008, 08:22 AM   #14 (permalink)
Codes
Attached is a print out of what the garage gave me. I've tried to summarise the codes below:
LH1 - diagnosis: 0/02
013 Intake air temperature, sensor B17/6
LH2 - diagnosis: 0/02
013 Intake air temperature, sensor B17/5
EZ1 - control unit does not answer
EZ2 - diagnosis: 0/01
No fault stored
EFP - diagnosis: 0/00
160 Engine speed signal
GM - diagnosis: 0/00
No fault stored
Old 05-14-2008, 04:58 PM   #15 (permalink)
bayhas's Avatar
the codes you are pulling have nothing to do with the repairs your mechanic is suggesting.
the air temp sensors are 10 bucks a piece... and you can replace them with absolutely NO TOOLS...
tell your mechanic where to put the engine pipe... BTW... what the hell is an engine pipe??
500 SEC Rough Idle Minkoff W126 S,SE,SEC,SEL,SD,SDL Class 8 01-04-2006 01:58 PM
500 sec rough idle zulumack W126 S,SE,SEC,SEL,SD,SDL Class 3 12-23-2004 05:59 PM
88 560 sec rough idle tommtkw General Mercedes-Benz 2 05-11-2004 11:34 PM
Newbie needs help! Hard start and rough idle. djimmy31 W124 E,CE,D,TD Class 1 09-14-2003 02:53 PM
Slow/rough Idle for 85 SEC Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 3 04-04-2002 05:42 PM
