» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W140 S-Class
Old 04-06-2008, 01:58 PM   #1 (permalink)
MOS500's Avatar
Date registered: Jun 2007
Vehicle: 1997 S500V
DIY Lowering-cut springs!
Hi,
Just sharing some pix of my DIY lowering by cutting the factory springs. Not a tutorial but just a summary: rented spring compressors, used hydraulic jacks to manipulate car, used air cutoff wheel to cut 1 full looped coil which lowered it about 1.5" in the front. For the back, I adjusted the leveling valve to lowest height. I currently has a front raked look (front lower by 1/2" than back). I may cut the back in the future. I also replaced the sway bar end links and steering damper. Got a MBZ dealership internet $85 alignment special done. Alignment is spot on but they said the front lower control arm bushings are torn/tearing which explains the front end squeak over bumps. Another project in the near future.
BEFORE:
1988 Mustang LX 5.0 (500+HP)
1993 Honda Civic EX (stock)
1997 MBZ S500V (daily driver)
2003 Toyota Matrix XRS (sold)
MOS500 is offline   Reply With Quote
Old 04-06-2008, 02:00 PM   #2 (permalink)
MOS500's Avatar
Vehicle: 1997 S500V
DURING:
Old 04-06-2008, 02:02 PM   #3 (permalink)
MOS500's Avatar
Vehicle: 1997 S500V
AFTER:
What do you think?
Old 04-06-2008, 02:51 PM   #4 (permalink)
vvee12's Avatar
Date registered: Nov 2007
Vehicle: 1997 Mercedes 600 Coupe & 1995 500 Coupe, 2004 Yamaha R1 200hp 360 pounds
Send a message via AIM to vvee12 Send a message via Yahoo to vvee12
the million dollar question is how is the ride with cut springs? Is it that bouncy lowrider ride?
CL600 V12 Coupe
vvee12 is offline   Reply With Quote
Old 04-06-2008, 07:00 PM   #5 (permalink)
Date registered: Jan 2007
yah i heard cuttin' springs kills high speed cruising!
sorry won't do it!
how does she feel?
300E... Mine
CBR... Mine
FUTURE = MINE
Chilling for an 18 year old
omairtheman1 is offline   Reply With Quote
Old 04-06-2008, 08:08 PM   #6 (permalink)
MOS500's Avatar
Vehicle: 1997 S500V
After cutting the springs/coils affecting the ride is WAY overrated! At first I thought it might severely affect ride and if it did, I'd just purchase some H&R, Eibach or whatever. But if it didn't, chalk one up for cutting springs (only one coil vs. 2 or more)!
I forgot to mention in the original post that the change in ride quality and handling is negligible. My wife doesn't notice any change in ride quality. It still rides like a stock S class. I thought I might have to adjust the leveling in the Xenon headlamps but I didn't need to since they are self leveling.
Bottom line: no suspected bounciness or change in high speed handling (80mph). It rides like stock but with a look of lowering.
Old 04-07-2008, 08:02 AM   #7 (permalink)
Premium Member
bayhas's Avatar
Date registered: Oct 2005
Vehicle: 300SE 3.2L, SL500 5.0L, Saturn SCX 1.9L DOHC.
Premium Member
Send a message via MSN to bayhas Send a message via Yahoo to bayhas
wait till your shocks are worn a lil more... :S
BTW, how is your self leveling hydrolic system feeling about this? please tell me you dont have one in the rear...
Mercedes-Benz, W140 S class 300SE
Mercedes-Benz, R129 SL class SL500
Mercedes-Benz, W140 S class S500 (Sold) - Mercedes-Benz, W140 S class 500SEL (sold) - Mercedes-Benz, W201 190E 2.3 (sold)
1996 Saturn SC1 + 95 DOHC head + 96 camcover + 98 Vsprings + 02 block + 00 crank + 91 header + 01 MP2 = SCX - Soon to be turbocharged.
bayhas is offline   Reply With Quote
Old 04-07-2008, 02:47 PM   #8 (permalink)
Vehicle: 1993 300SEL
Hmm, something about cutting makes me uneasy I think your better compressing.
NZ Benz is offline   Reply With Quote
Old 04-07-2008, 07:08 PM   #9 (permalink)
le modérateur vert
Haku's Avatar
Date registered: Nov 2006
Vehicle: 1996 S320
Send a message via MSN to Haku
Exactly - for the amount gained, why not go for compressing?
~ 1996 S320 ~
Haku is offline   Reply With Quote
Old 04-07-2008, 07:30 PM   #10 (permalink)
I've seen some bad things happen to cornering ability with cut springs on other cars thats all.
finally lug nuts cut diy... mbnz230 W210 E-Class 5 07-21-2007 11:07 PM
WANTED:Lowering springs or springs from C Class Sport package... NJBNZ For Sale/Wanted/Trade/Giveaway 0 04-10-2007 09:55 AM
DIY:Changing to lowering springs janthony W211 E-Class 1 09-05-2006 05:39 PM
Anyone Cut Springs? BrabusNYC W203 C-Class 3 02-21-2006 12:05 PM
H&R CUT SPRINGS Guest (MBNZ) W202 C-Class 1 04-15-2002 12:55 PM
