Old 03-16-2008, 09:24 PM   #1 (permalink)
Date registered: Mar 2008
Vehicle: S320L
Rear Windows Sun Shade Repair.
The rear windows sun shade is refusing to go down. I did some pushes on the side supports and pulls up and down to the roler and it come down one time. I was carfull not to raise it to the maximum limits. however, I did forget one time and reaise up maximum so quickly and now it is refusing to come down. I can hear the motor running. I wish some one supply a digram and a repair steps. My car is S320L 98 model.
kfareagm is offline   Reply With Quote
Old 03-16-2008, 11:23 PM   #2 (permalink)
Mercedes Mechanix's Avatar
Date registered: Sep 2007
Vehicle: (Pride and Joy) 1914 Mercedes 28/95 hp, 83' 300SD, 93' S420, 94' S420, 95' S500 & 96' S600
Location: originally:West Germany, now reside Central Florida
Post
Hope this will be of assistance. The gearbox and motor are not difficult to access. But, they do take patience and a little time. Hope these will be of assistance.
Keep in mind that the lubricant in the gear mechanism becomes more of a sludge, although small... it curtails the smaller supports drive gears from pulling both inward and allow lowering of the shade. This is why having aN assistant on each side can allow lowering in this case sometimes.
Following refers to back window rear shelf picture below. I also included a small schematic of the electrical if it is needed.
Robert
Rear Shelf image for removal:
Screws (1 and 2)
screw out.
Screw (5) in first aid box compartment
screw out.
Rear shelf (6)
remove toward front.
Rear shelf (6)
position while inserting tabs in recesses at rear (arrows).
Reinstall
in opposite order.
retired 32+ years: Mercedes Benz Technician
Sinndelfingen Facility
Ein gut aufrechterhaltener Mercedes wird ebenso ruhig laufen wie eine Nähmaschine viele Jahre lang!
Mercedes Mechanix is offline   Reply With Quote
Old 03-20-2008, 03:50 AM   #3 (permalink)
Vehicle: S320L
I will try this today, but do i have to remove anything before removing this rear shelf. the rear seats for example?
Old 03-20-2008, 07:20 PM   #4 (permalink)
Haku's Avatar
Date registered: Nov 2006
Vehicle: 1996 S320 Carlsson Obsidian Black
Send a message via MSN to Haku
Robert
Screws (1 and 2)
screw out.
screw out.
Rear shelf (6)
Rear shelf (6)
Reinstall
in opposite order.
Brilliant!
Thanks for the diagram!
~ 1996 S320 ~
19" carlsson/lowered/crystal LED tails/crystal LED side markers/crystal indicators/S600 walnut steering wheel/S600 grille/anthracite black interior/sunroof
Haku is offline   Reply With Quote
Old 06-09-2008, 07:41 AM   #5 (permalink)
Date registered: Jun 2007
Vehicle: 96 E320, 99 S500, 07 B200T
I experienced this problem yesterday. I did not hear motor running when I pressed the switch to lower the rear shade. Mind you I am at the driver seat and may be too far away to hear whether the motor is running or not in the rear deck. The last time this rear shade works properly is when I raised it after a car wash. Now the switch will not control the movement of the rear shade. It is staying all the way up.
I should check if a fuse has blown but not sure where to look for the fuse that is associated with the rear shade mechanism. If anyone can tell me where to check for the fuse, that will be great. Mine is a 99 S500.
I hope it is not the motor or the pump(?) that has gone bad. The whole mechanism may need to be lubricate as this car is driven only on weekend for short trips.
Any ddeas what and where else should I check before I head off to the stealer for being butcher?
Thanks.
Philip
000-668 is offline   Reply With Quote
Old 06-09-2008, 11:09 AM   #6 (permalink)
Haku's Avatar
Thanks.
Philip
Mine has it's days where it will make noise and others where it will not. You will need to get someone to help you move it up and down a couple of times and if you have no success or still don't hear any noises, then follow the diagram above and give it a clean out.
Old 06-09-2008, 01:01 PM   #7 (permalink)
Mine is completely dead when I pressed on the switch. I will give the rear shade a few shake tonight to see if it make any difference. Location of the fuse is helpful if anyone can let me know where to look. Thanks.
Philip
Old 06-09-2008, 03:09 PM   #8 (permalink)
Date registered: Feb 2005
Vehicle: 96 SL500, 97 E420, 02 SL500-SA
Send a message via Yahoo to gqmagic
My E420 sunshade is stuck up also
They should be pretty similar.
gqmagic is offline   Reply With Quote
Old 06-10-2008, 01:25 PM   #9 (permalink)
so how did you fix it? Do you have to replace any parts?
Philip
Old 06-27-2008, 07:55 AM   #10 (permalink)
Fuses check out fine. Try wriggling the two metal arms that move the sun shade up and down without success. Need to remove the rear hat rack to get to check out whats underneath.
How do I remove the upper back seat to get to screw #1 and #2 (please refer to post#2's diagram)? No problem finding #5. Is this a complex procedure or just pull the seat away with force? Don't want to do something stupid and ruin the leather or anchor points for the seat. Please give me some advise or a procedure to remove the back seat. Thanks.
Philip
Rear sun shade issue Sojo300E W140 S-Class 10 03-16-2008 07:48 AM
rear sun shade 89560sel W126 S,SE,SEC,SEL,SD,SDL Class 28 08-04-2007 12:09 AM
f/s rear sun shade oem new 01 to 06 juano For Sale, Trade & Wanted Items 0 11-22-2006 09:30 PM
Rear Sun Shade? CCORLEY W203 C32 AMG, C55 AMG 0 08-19-2006 09:51 PM
Rear sun shade Frank W208 CLK Class 4 07-15-2000 04:05 PM
