» Site Navigation
» Other Sites
Old 06-27-2008, 08:03 AM   #11 (permalink)
Date registered: Feb 2005
Vehicle: 96 SL500, 97 E420
Send a message via Yahoo to gqmagic
Mine appeared to be stuck in up position, I went by my mechanic's shop to show him and when I pushed the switch down it went, its working fine. Maybe the switch was being temperamental who knows.
gqmagic is offline   Reply With Quote
Old 07-13-2008, 08:11 PM   #12 (permalink)
Date registered: Jun 2008
Originally Posted by Mercedes Mechanix View Post
Hope this will be of assistance. The gearbox and motor are not difficult to access. But, they do take patience and a little time. Hope these will be of assistance.
Keep in mind that the lubricant in the gear mechanism becomes more of a sludge, although small... it curtails the smaller supports drive gears from pulling both inward and allow lowering of the shade. This is why having aN assistant on each side can allow lowering in this case sometimes.
Following refers to back window rear shelf picture below. I also included a small schematic of the electrical if it is needed.
Robert
Rear Shelf image for removal:
Screws (1 and 2)
screw out.
Screw (5) in first aid box compartment
screw out.
Rear shelf (6)
remove toward front.
Rear shelf (6)
position while inserting tabs in recesses at rear (arrows).
Reinstall
in opposite order.
I have a '97 S320 and the rear sunshade is will not release and do down. Is there a fuse I can locate and check? Also, everyone asks about removing the rear seats to get to screws #1 and #2. Is that necessary?
dramsey633 is offline   Reply With Quote
Rear sun shade issue Sojo300E W140 S-Class 10 03-16-2008 07:48 AM
rear sun shade 89560sel W126 S,SE,SEC,SEL,SD,SDL Class 28 08-04-2007 12:09 AM
f/s rear sun shade oem new 01 to 06 juano For Sale, Trade & Wanted Items 0 11-22-2006 09:30 PM
Rear Sun Shade? CCORLEY W203 C32 AMG, C55 AMG 0 08-19-2006 09:51 PM
Rear sun shade Frank W208 CLK Class 4 07-15-2000 04:05 PM
