Were is the ASR relay located? - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 02-12-2008, 09:01 PM Thread Starter
tommyb2b's Avatar
Date registered: Sep 2006
Vehicle: Artic White 1995 S420
Send a message via AIM to tommyb2b Send a message via MSN to tommyb2b Send a message via Yahoo to tommyb2b
I was wondering if the problem with ASR will go away if I simply pull a fuse or a relay? Is there anyway to just deactivate it?
tommyb2b is offline
post #2 of 11 (permalink) Old 02-13-2008, 12:05 AM
Mercedes Mechanix's Avatar
Date registered: Sep 2007
Vehicle: 1914 Mercedes 28/95 hp, 83' 300SD, 93' S420, (three) 94' S420's, 95' S500 & 96' S600
Post ASR module location
Following location of components. Instead of deactavating, why not correct any issues you are encountering? Also, keep en mind that disableing one component can/will affect other systems.
Try simply removing the ASR instrumentation console/dash lamp.
Due to the possible serious integrity of a loss of the traction control systems, as Engineers we introduced a very simple measure en some of the higher operational control functions making them dependent on the resident current of their instrumentation status systems en their operational safety protocol. If resident instrumentation status lamp current (lamp burns out or es removed). Then the normal status es deemed invalid... therefore the operational system affected are disabled until a valid status returns (dash system status lamp replaced to ensure system integrity). Your vehicle may be affected with this safety item for traction system integrity...
We hope these images assist you en your efforts?
regards, Robert
Following should assist with Figure #3 explanation of components:
Figure #3
Component Name Solenoid valve relay
Component ID A7k1
Figure 4
Component ID A7/3k1
Component ID Component Name
A7...........ABS hydraulic unit
A7k1.......Solenoid valve relay
A7k2...Return pump/pressure pump relay
A7/3...ASR/ETS/ESP hydraulic unit
A7/3k1....Solenoid valve relay
A7/3k2....High-pressure/return pump relay
K26.........Wiper system relay module
N2/1.......ETR control module
N2/2.......SRS control module
N32/9.....MSC control module (with memory)
ID:	162384   Click image for larger version
retired 32+ years: Mercedes Benz Technician
Sinndelfingen Facility
Ein gut aufrechterhaltener Mercedes wird ebenso ruhig laufen wie eine Nähmaschine viele Jahre lang!
Mercedes Mechanix is offline
post #3 of 11 (permalink) Old 02-13-2008, 07:37 AM
Date registered: Jul 2004
Quoted: 294 Post(s)
That was a nice way of saying sell your ASR car and buy one that does not have ASR.
deanyel is offline
post #4 of 11 (permalink) Old 02-13-2008, 06:01 PM
600amg's Avatar
Date registered: Feb 2007
Vehicle: 2005 E55 Designo
Post Ja!
[QUOTE=Mercedes Mechanix;2741572]Following location of components. Instead of deactavating, why not correct any issues you are encountering? Also, keep en mind that disableing one component can/will affect other systems.
thanks Rob. I enjoy your experienced feedback.
600amg is offline
post #5 of 11 (permalink) Old 02-14-2008, 10:28 AM
miroxz's Avatar
Date registered: Apr 2007
Vehicle: 94 S500L every option available -yes, they work ;-)
[QUOTE=600amg;2742592]
Ditto. Awesome feedback as always Rob.
94 S500 Schwartz: One hell of a ride @ 202k-miles
96 S320 Schwartz: Had 212k on the clock..sold.
97 S500 Brilliantsilber: Hate myself for selling.
miroxz is offline
post #6 of 11 (permalink) Old 02-14-2008, 11:06 PM Thread Starter
tommyb2b's Avatar
wow I think i got the part of that lol thanx for the diagrams!
gunner likes this.
tommyb2b is offline
post #7 of 11 (permalink) Old 02-15-2010, 07:17 PM
Date registered: Dec 2009
I'm having the same problem with my 95 S500. The dealers have an edge in that They
have the diagnostic tools for the mercedes port and the extra parts to test the car.
We don't have the luxury to test a faulty relay without purchasing it, and of course
you cannot return electrical parts from most all suppliers.
Northfork Cars is offline
post #8 of 11 (permalink) Old 09-29-2010, 09:16 PM
Date registered: Feb 2009
Where is the Over voltage relay - 1999 S500
bpehkonen is offline
post #9 of 11 (permalink) Old 10-02-2010, 02:45 AM
khmer504's Avatar
Vehicle: 1995 S420, 1987 190e 2.3 16V , 2008 CBR600RR
so, is there any way to disable the ASR system? I am fine without traction control. I drive pretty safe and never need the help of traction control. I have been through many cars without traction control and never had any problem loosing control. Is it possible to equip an ETA unit that doesn't have ASR? I know they're stupid questions, but im also trying to find a cheaper way to ride myself of the ASR issue.
khmer504 is offline
post #10 of 11 (permalink) Old 10-03-2010, 06:57 PM
did you ever get an answer as to where is the OVP relay for a 1999 S500?
sbpehkonen@mchsi.com
    OK! New problem! Just fixed the asr light, today, both the asr and the abs lights has come on! Cabbe W140 S-Class 23 04-12-2015 11:13 PM
    Exactly where is the K-40 relay located NCJETSKIER W210 E-Class 17 09-27-2007 08:51 AM
    Where is the Crash Relay Located? Smokehouse69 R170 SLK-Class 7 07-03-2007 04:36 PM
    Where is the wiper relay located? Mississippi_300D W123 E,CE,D,CD,TD,TE Class 4 07-10-2006 03:58 PM
    Help with ASR relay wires benz420 W126 S,SE,SEC,SEL,SD,SDL Class 0 05-11-2006 03:23 PM
