Old 01-13-2008, 01:56 PM   #1 (permalink)
mgill85258's Avatar
Date registered: Oct 2006
Vehicle: 1996 W140 S320L
Send a message via AIM to mgill85258
Ok, I cleaned the MAF twice, still issues...
CE Light came on, disconnected battery, cleaned MAF, let it dry, reconnected battery etc.. light went away, great!..
Light came back, again... did the same procedure, light went away for a little while, and just came back again...
Time for a new MAF I think? I'm looking for a DIY on how to replace the MAF... only thing i'm unsure of, basically, is now to properly remove the cable that is attached to it... i looked at it in question, but couldn't quite figure it out.
Thanks!
Note: I used some electronic parts cleaner on it, FIY... and the symptoms i'm getting now is irregular idle, and sometimes i even give it gas and get NO response, i have to let off, and press again (while driving)
Matt
1996 S320 Long
Black with tan interior
Mods:
Bosch Platinum Ir Fusion Spark Plugs
Previous Cars:
1995 Mercedes-Benz C220
1981 Chrysler Imperial Coupe
mgill85258 is offline   Reply With Quote
Old 01-13-2008, 06:52 PM   #2 (permalink)
Date registered: Dec 2003
how do u know CE light is triggered by MAF? did you scan it?
If you have not scanned it, irregular idle & giving it gas w/ no response is often times due to a faulty ETA
are you running an aftermarket air filter like K&N?
96 S500 Coupe. Black on black, 18" AMGs
snik is offline   Reply With Quote
Old 01-13-2008, 07:17 PM   #3 (permalink)
mgill85258's Avatar
I did scan for the code and it was the MAF... the last time i cleaned it, i sprayed it and immediately put it back together, i forgot to leave it apart to dry... and the unresponsive pedal issue came directly after i started the car the first time after i had cleaned it... so i'm thinking it must have something to do with it, never did that before...
Old 01-13-2008, 08:51 PM   #4 (permalink)
jhodg5ck's Avatar
Date registered: Sep 2002
Vehicle: 1991 560 SEC
Send a message via AIM to jhodg5ck
Did you wipe off the mirror w/ some q tips? If that mirror is @ all dirty it will throw codes.
We have been fairly lucky with inserts for the MAF's.
Jonathan
Blue Ridge Mercedes/AMG East
Offering Enthusiast Service, Restoration and Tuning.
Providing quality parts to all parts of the world.
Located in the Atlanta area
96 S600 Euro
91 560SEC ECE (for sale)
91 560 SEC 226/271 Undergoing TT conversion
89 190E 2.6 5sp
89 300TE (Mosselman TT waiting..)
88 560SEC AMG Euro ECE (parts)
89 560SEC AMG mech. lifter/68K rpm conv.
87 Hammer 6.0L 32V
86 560SEL AMG 6.0L 32V
06 Z4 M Spec 6sp
jhodg5ck is online now   Reply With Quote
Old 01-14-2008, 11:25 AM   #5 (permalink)
mgill85258's Avatar
Can you explain what you mean by the mirror? I dont understand.
1997 S600. Cleaned throttle bodies, now fast idle issues, P1580, P0507 Brett San Diego W140 S-Class 12 12-11-2007 05:57 PM
Cleaned MAF... ML430 hesitant in morning!!! SClegg42 W163 M-Class 2 05-08-2007 02:53 PM
Cleaned MAF sensor twice, no help. oledale W202 C-Class 14 04-03-2007 07:52 AM
cleaned MAF, now rougher idle peckels01 R170 SLK Class 4 01-07-2007 07:00 PM
No Kompressor after installing cleaned MAF :-( mitaci R170 SLK Class 8 04-26-2006 02:59 PM
