Old 10-09-2007, 02:33 PM   #1 (permalink)
Date registered: Aug 2006
evaporator trouble in a s420
DOES THE 1993 model s350 or 300sd have the same type of trouble with there evaporator as my 1995 S420 has. I am looking at a 1993 Diesel and was just wondering if the early model has the same problem. My wife would not be happy if I traded one problem for another. Thank you
1982 300td wagon with 424,000 miles running strong
1983 300 coupe with 279,000 not running.
1984 300sd with 200,00 running well
1995 S420 with 156,000 running well but sitting until OPEC gives me a break.
1993 Ford crewcab with new 7.3 international with 190,000 miles.
In sunny south FL. Mostly with wvo on the diesels.
curbill is offline   Reply With Quote
Old 10-09-2007, 04:30 PM   #2 (permalink)
Date registered: Mar 2004
Vehicle: 1997 S600 sedan
Yes. There are those that say the problem was never really fixed through the entire W140 model run.
Brett
Brett San Diego is online now   Reply With Quote
Old 10-09-2007, 04:52 PM   #3 (permalink)
miloking's Avatar
Date registered: Jun 2006
Vehicle: Current 1992 - 500SEL, W124 - 1989 230E (sold)
Brett
and even early W220 apparently had some issues there...
miloking is offline   Reply With Quote
Old 10-09-2007, 05:02 PM   #4 (permalink)
Vehicle: 1993 300SEL/S320
Some guys in the W220 section were saying that the first run of those cars even had a crappy wiring loom like the early W140....
NZ Benz is offline   Reply With Quote
Old 10-09-2007, 10:11 PM   #5 (permalink)
S500L's Avatar
Date registered: Aug 2003
Vehicle: S 500 L
The W140 had evaporator problems from the first day of production up the last. The only way to correct the problem is to install an aftermarket FULL cooper evap.
But going back to your original question: an evaporator on a early diesel W140 would be the LEAST of your problems. The diesel engine on these models is well documented as the worst engine ever produced by M.B. It will literally self-destruct itself and all repairs and subsecuent recalls never really fixed the problem.
A. R. R.
S 500 L, 1998
E 320 T, 1995
S500L is online now   Reply With Quote
Old 10-10-2007, 05:48 AM   #6 (permalink)
Date registered: Jul 2005
Vehicle: W140 S280 1994
I had a new evaporator fitted to my W140 about 5 years ago. I remember seeing that the old unit had corroded and then realised that it was constructed from aluminium and copper in intimate contact (at this distance I can't remember whether it was copper tubing and aluminium manifolds or the other way round). I was appalled - any professional engineer knows that this combination of metals is to be avoided as far as possible, especially where they can be in mutual contact with water (e.g. in an evaporator!). Aluminium-to-copper has a potential difference of about 1.6 volts in the electrochemical series and works like a small battery, consuming the aluminium. I don't know what precautions the manufacturer of these evaporators took - if any - but whatever they were, they didn't work. I wrote and complained to Mercedes-Benz but simply received the brush off.
MikeJT is offline   Reply With Quote
Old 10-10-2007, 06:35 AM   #7 (permalink)
Nimrodthewombat's Avatar
Date registered: Dec 2002
Vehicle: 500 SEL (W140- the King of the Road!) SL500 (My new baby!)
some of the diesels evidently are okay. My neighbour has a W140 300SD with 175,000 miles on it and claims to have never had a problem other than the evaporator
1993 500 SEL (W140-the King of the road!)
1992 500SL (My New Baby!)
You know you're German if:
You went to school in a Gymnasium
You check your shoes for candy on December 6
You have real candles on your Christmas tree
You know a Frankfurter is a person not a hotdog
Schnitzel with noodles is your favorite meal, not a song in a cheesy musical!
You drive the Autobahn in a Mercedes-Benz at the speed of sound!
Nimrodthewombat is offline   Reply With Quote
Old 10-10-2007, 01:50 PM   #8 (permalink)
the 350 is the one that has problems apparantly it's due to the extra displacement and the shrinking of the walls of the head.
Old 10-10-2007, 02:57 PM   #9 (permalink)
miloking's Avatar
Well, when it comes down to evaporators you can extend the life a bit by regualary servicing the AC system (eg. replacing the dryer to make sure there is no moisture in the system) also if the AC is inoperable due to some secondary fault and the gas/moisture just sits without moving that causes most of the corossion....
Old 10-11-2007, 02:07 AM   #10 (permalink)
The corrosion I am referring to was on the outside surface of the evaporator where the water vapour from the external air condenses. The only way to stop this is by not using the aircon - and even then it can get damp.
evaporator??????????? jjohn81602 R129 SL Class 4 07-25-2006 07:03 PM
cleaning evaporator crash1 W126 S,SE,SEC,SEL,SD,SDL Class 5 06-24-2006 07:41 PM
A/C Evaporator vdufault W124 E,CE,D,TD Class 7 09-29-2005 07:33 PM
A/C Evaporator prtdvl R170 SLK Class 1 08-30-2005 10:56 AM
evaporator bouzouki W140 S-Class 6 08-07-2005 08:05 PM
