Whereabouts of Safety Fuel Shutoff Switch? - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 07-19-2007, 07:31 AM Thread Starter
Date registered: Jul 2005
re my original posting
1993 SEL600 wont start - again!
I'm at my wits end with this car now! went to start car up today, motor turns over without problems or strange noises but engine just wont fire up (not even trying to fire up). Last time this happenned was about a couple of months ago and car miraculously "fixed" itself after being left alone for a week. Since then car has run fine, used daily running 200 - 300 miles per week, starting first time, smooth to drive and with good (18mpg) economy. In last 2 years both ETA's replaced, engine and air mass harness replaced, new battery 2 months ago yet still this occasional problem persists (it's happenned about 10 times in all over the last couple of years). HAS ANYONE ANY IDEA WHAT COULD BE WRONG WITH THIS CAR? all reply's appreciated. TIA.
Terence
It has now been established that it is the Safety Fuel Shutoff Switch that is the cause of the problem. Does anyone know whether this is a part of a module or a seperate part and where it is located?
TIA.
Terence.
terence is offline
post #2 of 6 (permalink) Old 07-19-2007, 11:58 AM
Date registered: Mar 2004
Vehicle: 1997 S600 (sold)
Quoted: 12 Post(s)
Sorry, I can't answer your question directly, but I would like to hear how your diagnostics determined that the problem was a fuel safety shut-off switch. Are you certain that the car has one? I've not heard of one on my car, but it is a different fuel injection system.
This info could be educational to others.
Brett
Brett San Diego is offline
post #3 of 6 (permalink) Old 07-19-2007, 03:04 PM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T and others
I have only heard of a ful pump pressure switch, when you turn the key the pumps come on, but shut off if the car does not start within 10 seconds or so. Has anyone checked the pressure in the fuel rail, and to see if there is spark. also the crank shaft position sensor!
Peter Guenther is offline
post #4 of 6 (permalink) Old 07-23-2007, 03:58 AM Thread Starter
My local MB specialist had car on his diagnostic computer and that stated Safety Fuel Shutoff Switch as faulty. He then cleared faults and this item came back as fault again. Sorry I dont know which diag equipment he uses. Also, his system doesnt tell him the location of that component, or whether its a single component or part of a module, hence my original question.
terence is offline
post #5 of 6 (permalink) Old 07-23-2007, 04:07 PM
Date registered: Feb 2003
Vehicle: 600SEL
Quoted: 83 Post(s)
There is a safety microswitch in the driver side throttle actuator. Did you have you engine wiring replaced? On 600SEL you need to replace main harness, Air mass sensors harness, and at least check both throttle actuators wiring. I have 92 model and my TA are fine, but engine main harness and AM harness had to be replaced.
Here is a page with description of the safety fuel cutoff.
Mike
myarmar is offline
post #6 of 6 (permalink) Old 07-24-2007, 04:08 AM
AlexanderZwo's Avatar
Vehicle: Mercedes 300 SE (W140)
Great and interesting information...tks! New one for the "hidden talents" thread...
Best regards
Hubert
300 SE, EZ 10/91, 97.000 km, Originalzustand, 4-Gang-Automatik, blau/schwarz, Leder schwarz, Sitzheizung, Klimaautomatik, ASD, Servoschließung, Schiebedach, Parameterlenkung, Becker Grand Prix, Mittelarmlehne mit Box, Wurzelholz, Colorverglasung, Einbruch- und Diebstahlwarnanlage o.I., 8-Loch LMs, Winterräder mit Originalabdeckung, original Feuerlöscher, abnehmbare Anhängerkupplung, komplette Dokumentation
AlexanderZwo is offline
    fuel shutoff valve skitzy.sht W201 190-Class 23 03-21-2007 04:18 AM
    Neutral safety switch cbx79 W124 E,CE,D,TD Class 0 04-19-2006 01:40 PM
    99 E300 turbodiesel fuel leak, electrohydraulic shutoff box bhowell_10 W210 E-Class 3 10-01-2005 03:46 PM
    fuel shutoff solenoid ggenovez Vintage Mercedes-Benz 2 07-16-2005 02:27 AM
    560 Fuel Shutoff?? jcantor W126 S,SE,SEC,SEL,SD,SDL Class 0 09-18-2002 05:14 AM
