How to remove Headlight switch knob - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 07-14-2007, 11:43 AM Thread Starter
zoso's Avatar
Date registered: Aug 2006
Vehicle: 96' S500
I feel like this is a dumb question because it's so simple.
The headlight switch on my 96' S500 needs replacement. I have the part (number 14 in the graphic), but I don't want to break anything on the way to get it. Alldata shows the knob for the column up/down in/out as just pulling off. I've looked at it and gently pulled but I don't want to break the switch. Can anyone here confirm how you safely remove the knob (number 1 in the graphic).
zoso is offline
post #2 of 10 (permalink) Old 07-14-2007, 01:54 PM
Date registered: Feb 2003
Vehicle: 600SEL
Quoted: 84 Post(s)
You need to push release button with the flat screwdriver. On you picture in the upper right corner (item 2) shown with the screwdriver at the knob.
Sorry, wrong answer. You don't need to remove knob 1. Just remove screw 4 and take switch out.
Also, you can get to switch 14 from the top after removal of the AC grill
myarmar is offline
post #3 of 10 (permalink) Old 07-14-2007, 10:39 PM Thread Starter
zoso's Avatar
Vehicle: 96' S500
Thanks, I need to fix something on that vent anyway so I may try that route.
zoso is offline
post #4 of 10 (permalink) Old 07-16-2007, 12:49 PM Thread Starter
zoso's Avatar
Vehicle: 96' S500
Changed the headlight switch today with no problems. The new one has nice positive detents and the old one sounded like a baby rattler when I shook it. As Myarmar said, it is much easier if you also remove the vent register and remove/replace the switch from above. The switch is so large I don't see how you could remove it thru the hole that Alldata indicates. And also as Myarmar said, you just pull the whole column tilt switch out with knob attached to get the front fascia cover off.
Between Alldata and this forum, a guy with a few tools can save significant $.
zoso is offline
post #5 of 10 (permalink) Old 01-27-2009, 03:08 PM
Date registered: Apr 2008
Vehicle: 1995 Mercede-Benz S500
Quoted: 9 Post(s)
My headlight switch will not turn to the right... do i just pull out the knob? Because its going to get dark out and i will not have any lights on lol.
BTW: the swtched just started yesterday when i got home. i had my lights on and when i got home i notice it was kinda hard turning it off like it was caught on something. Once i turned it off it wont got back to the right.. but it will turn left. Help!~
Current:
1995 S500
1993 Volkswagen Corrado SLC VR6
hellah fresh is offline
post #6 of 10 (permalink) Old 01-28-2009, 04:14 AM
JohanSL's Avatar
Date registered: Mar 2008
Vehicle: 2015 C180, 2004 SL500,2006 ML 320Cdi Off-Road package, 2006 Boxster,
Quoted: 5 Post(s)
Send a message via Skype™ to JohanSL
Have you tried pulling it (fog lamps) and then turn it right?
JohanSL is offline
post #7 of 10 (permalink) Old 01-28-2009, 07:01 AM
Quoted: 9 Post(s)
Yes i pulled out the fog lamp and it works. Other then that when it isnt pulled it wont turn to the regular headlights. It feels like something is blocking it from going right. I can turn it but i dont want to risk breaking anything if i forced it to turn. what do you think that is bad on it?
Current:
1995 S500
post #8 of 10 (permalink) Old 03-24-2011, 12:12 PM
Date registered: Mar 2011
I have a problem with my turn signal, on the left driver side, it will stay on at all times even with the car off, you guys think this might be related to the switch???
NAVIL 300SD BENZ is offline
post #9 of 10 (permalink) Old 03-24-2011, 12:16 PM
chuckindetroit's Avatar
Date registered: Jun 2003
Vehicle: 1986 560SEL, 1986 560SEL, 1992 500SEL, 1999 S500
You again need to stop hijacking a 2 year old thread with no relation to your question--make a new post!!
chuckindetroit is offline
post #10 of 10 (permalink) Old 03-24-2011, 01:23 PM
you again?????
I dont know what you mean by you again...but anyways I'm new to this benz community, ill get used to it with time...thanks for the advice tho
    Auto Shift Knob Rattle- Remove Knob? mattb R170 SLK-Class 2 10-06-2006 02:57 PM
    HOW TO REMOVE SHIFT KNOB... roadrage R170 SLK-Class 5 04-11-2006 09:05 PM
    Headlight switch pullout-knob removal how-to? njview W123 E,CE,D,CD,TD,TE Class 2 02-24-2006 10:42 PM
    Switch next to headlight knob on Euro Spec? madmunky1 R170 SLK-Class 11 01-31-2003 10:06 AM
    How to remove the shift knob Guest (MBNZ) W124 E,CE,D,TD Class 0 06-16-2002 08:38 PM
