Old 06-24-2007, 03:44 PM   #1 (permalink)
dmac_S500's Avatar
Date registered: Jan 2007
Vehicle: 1998 S500
Check the Door Checks!
I just replaced both front door checks on my '98 S500. Was not too difficult with great instructions from article on MercedesShopWiki: MercedesShop - Do It Yourself.
One side was making horrendous noise (door sounds from a horror movie) and the other was starting to sound the same. I noticed on both of them that the two mounting bolts accessible when the door is open were loose (do not need to take off the door panel). On the very noisy door the mounting flanges for the door check (secured by those mounting bolts) were broken off which I believe was caused by the loose bolts. The check for the other door was not internally damaged and I think that just tightening up the mounting bolts could have definitely helped.
Something easy to check and fix if your doors are acting up.
dmac_S500 is online now   Reply With Quote
Old 06-24-2007, 04:44 PM   #2 (permalink)
Vehicle: 1993 300SEL/S320
Apparnatly another sign is that the chrome along the window ledge on the doors does not line up straight along the length of the car, replacing the door checks is supposed to address that issue.
NZ Benz is offline   Reply With Quote
Old 06-24-2007, 05:57 PM   #3 (permalink)
dmac_S500's Avatar
Vehicle: 1998 S500
Clarification
The door checks I am referring to are the devices mounted inside the door which prevent the doors from opening too wide and also provide a smoother, more controlled opening (spring-loaded ball bearing slide arrangement). I do not think that there is any way that they could impact the alignment of the door.
Old 06-24-2007, 06:03 PM   #4 (permalink)
Really? I was sure that over time due to the weight of the door the doors can get out of alignment and droop ever so slightly as the check gets stressed, perhaps it's another part.
Old 06-24-2007, 07:21 PM   #5 (permalink)
dmac_S500's Avatar
Vehicle: 1998 S500
I'm pretty sure that when the door is closed (and thus the mis-alignment visible) the door check is mechanically out of the picture. And the door check is relatively free to flex in the vertical direction which wouldn't restrain the door from sagging.
Old 06-25-2007, 06:37 AM   #6 (permalink)
gartracescort's Avatar
Date registered: Nov 2006
Vehicle: 1995 S500 ex diplomatic car; 2 1/2 years, 2 MoT passes! Ponton 220S to be restored. LDV bus
Hinge pins wear will cause droop. Lightly oil at each service. Lithium spray grease on the check slides.
gartracescort is offline   Reply With Quote
Old 01-14-2008, 06:13 PM   #7 (permalink)
pdpjp's Avatar
Date registered: Dec 2007
Vehicle: 97 S320 & 2000 ML320
Have the same problem that came up. The internal portion of the check broke and when I closed the door it put an outward facing ding on the outside of the door. (Window only opens partway) Going to open it up and order the parts tommorow. (never ends)
pdpjp is offline   Reply With Quote
Old 01-15-2008, 10:42 PM   #8 (permalink)
W140FTW's Avatar
Date registered: Nov 2007
Vehicle: 1999 Mercedes Benz S320 Long Wheelbase.
Send a message via AIM to W140FTW
I had 'em do my driver's door check strap at the dealer. It was making a lot of noise since I bought it, and I was told that if the strap goes, it'll put a dent into the inner panel of the door. Definitely not a good thing.
W140FTW is offline   Reply With Quote
Chavez may soon write hot checks Botnst Off-Topic 17 12-29-2006 10:28 AM
Fix for clicking/snapping door checks. (pics) Brett San Diego W140 S-Class 9 09-15-2004 09:45 PM
Teaser for how to fix your creaking/clicking door checks. Brett San Diego W140 S-Class 1 09-04-2004 04:40 AM
Any help removing pin holding door check strap? I want to replace a loudly creaking check. Brett San Diego W140 S-Class 4 08-25-2004 02:57 PM
REMOVING PAINT CHECKS ON AN SLK. Allen Chase R170 SLK Class 0 09-24-2003 05:10 AM
